Spray Gun For Spraying Latex Paint Indoors
Old 12-07-2005, 11:03 AM   #1
aoc's Avatar
Right now I am using a Accuspray 19c gun for spraying trim, doors and molding.
There is a little to much over spray and the pattern with latex is heavy in the
middle. Any advise on guns would be helpful. The compressor puts out 8cfm at
40 psi.
aoc is offline
Old 12-09-2005, 01:00 PM   #2
Farmall's Avatar
Trade: Trim finishing, Painting
Re: Spray Gun For Spraying Latex Paint Indoors
A bit more information regarding your process would be good.
I have the 19c gun and it sprays beautifully, you need to be using a 1.5 or 1.8tip for the latex depending on how heavy a material it is. You also need to thin latex down with a bit of water and use Floetrol to recondition and help with the flow and leveling of the material. Floetrol will help your spraying patterns greatly with latex. You need to use around 3oz of water and 3oz of Floetrol per quart of paint. Start there and give it another go, you will find that you can lower the pressure and still get the great spray pattern that the 19c is capable of doing.
For another option I also use a Asturo BBS HVLP gravity gun, it sprays every bit as good if not even nicer than the 19c and uses around 7cfm. your compressor is probably a little to small for this gun though it would work fine for intermittent spray, you may even be running out of air with the 19c if the jobs you are doing require extended spray times.
good luck
Farmall is offline
why is latex paint peeling?? Zeebo Painting & Finish Work 24 05-28-2009 07:59 AM
latex semi gloss over oil semi gloss - can it be done? Zeebo Painting & Finish Work 13 09-05-2007 06:38 PM
SW Latex Paint taking long to dry plazaman Painting & Finish Work 9 08-10-2007 08:20 PM
Determining if latex or oil base paint gary lee Painting & Finish Work 6 07-31-2007 01:02 AM
