Painter S.Illinois
Trade: Painting Contractor
Spray Booths
Considering building or buying a pre fab spray booth to spray doors and trim packages....Local lumber Co wants me to paint 75 interior six panel doors a month. Any one ever do this?
#2 | |
Professional Painter
Trade: Owner/Operator
Re: Spray BoothsQuote:
I was also the paint department supervisor in a restoration company and had the pleasure of using the HVLP spray booth for all the trim that got restored. I think it had around 9 filters recycling all of the air in the room every 2 minutes. It was sick! So, yes...I have used booths, but no.....I havent actually purchased prefab ones......but good luck~sounds like a fun job are they paying for the booth? I think they are quite pricey and where will you put it? I also thought they were quite large...
Rich Last edited by Richard; 10-02-2006 at 06:35 AM. |
Back from the dead...
Trade: Paperhanger/Painter
Re: Spray Booths
If you have a garage, or decent storage building, you could make one easier and cheaper than buying one.
Trade: Paint Contractor
Re: Spray Booths
If you want to buy one cost around $4000.00 to $5000.00 w/no assembling. But if you have a nice room you can dedicate one as a spray both. You will need good fluorescent lamps, air filter and exhaust fan. You can used a old a/c handle unit, remove the coil and install a good HEPA filter.
Put your money on a nice spray gun, a Graco 4900 PROCOMP HVLP Sprayer will make your work easier. Good look Art |
Painter S.Illinois
Re: Spray Booths
NO I have to purchase or pay for it my self....found a prefab basic booth with lights, exaust fan & filters for 3,900.00. 27 L by 12 W.
have to install in my garage....could build one for around 1,500.00. The local wood store will pay me 40.00 a door (blank) and around 50-70 doors a month so it wont take to long to recoup my money...but have to insulate and heat the garage and it gets cold in Illinois, figured I could install a mobile home furnace pretty cheap. Any way then I would be set up to paint trim packages and doors for customers. |
Trade: Painter
Re: Spray Booths
Go for it. Not only do you have an account to justify the cost, you can start doing more work in the booth. Great selling point, best quality.
I worked at a shop that had a heated booth, with chains to hang the doors on. The chains were attached to wheels on a rail at the top. The rail made a circle around the room, so we could hang a lot of doors, do both sides and edges and then slide them around the room. I like the booth idea because it's dust free. I rented a shop once with the idea of taking trim paks from construction sites. this would free up space on site for the gc and it would let me do my thing without interrference. Downside is that gc's don't want to let the materials off site for fear of not getting every single piece back. Also, sometimes there is hardware involved. Hope this helps. |
#7 | |
http://www.speedpainting.com/ |
#8 | |
I've used these door deckers before- they do make work with doors SO easy
Rich |
#9 | ||
LRG WoodCrafting
If you are going to be doing this without regulations in mind a garage with a fan in the window and the garage door open slightly will do a fair job. Plan on spending a mint to keep it warm with the air flowing through it though.I've done a lot or research and built a good spray room if you need to ask any questions I'm your guy.
Sawdust Follows Me Everywhere http://lrgwood.com Custom Cabinets in Hartford County Connecticut Last edited by Leo G; 10-10-2006 at 10:29 PM. Reason: change 17,400 to 17,000 CFM wrong number |
Painter S.Illinois
Re: Spray Booths
Can you post any pics of your booth.......and where did you buy your fan and filters?
#11 | |
LRG WoodCrafting
http://www.woodweb.com/galleries/shop/posts/225.html I got my fan through Grainger.com I bought the 3HP 36" tubeaxial fan with the hazardous location fan. It pulls about 17,000CFM. http://www.grainger.com/Grainger/wwg/productIndex.shtml I can't remember the name of the company I get my filters through right now, I have the catalog at my shop and I'll try to post it for you tomorrow. Oh wait a second brain fart relieved.... Camger is the company name, and here is the info I have when I got my filters. You can call Jim Zervins at Camger and he will give you a hand with your filtration needs as he did for me. Good guy.From: j.zervins@camger.com (Jim Zervins) Hi Leo; I'm the equipment manager @ Camger and would like for you to call me @ 508-528-5787 to discuss your filter needs.
Re: Spray Booths
Leo,
That's one nice set up you have there. The cherry entertainment center is most excellant. Good job! |
#13 | |
LRG WoodCrafting
Take a look at my website/portfolio: http://www.hometown.aol.com/lrgwoodcrafting/index.html
Re: Spray Booths
You have skills. Nice work. How did you get those kitchen cabs to have that "distressed" look?
LRG WoodCrafting
Re: Spray Booths
You bang'em up a bit then you use a bunch of layered oil base paints that are rubbed through to look like wear and tear. The cabinets have about 9 coats of paint/primer on them and as you put them on (after they dry) you rub off certain areas with steel wool to let the layer below show through. Lots of time and patience. The paint job cost about as much as the cabinets.
![]() As for skills---I made the website myself too. Now I'm just braggin' (but I did do it myself). See what happens when you tell me I do good stuff. I try to stay with the more modern finishes, you know resin alkyd stains and dyes that dry in 10 minutes, pre-cat lacquers and conversion varnishes because of speed of drying. The finish on those cabinets took weeks to get done because of drying times. Patient clients.
Sawdust Follows Me Everywhere http://lrgwood.com Custom Cabinets in Hartford County Connecticut Last edited by Leo G; 10-10-2006 at 11:40 PM. |
Painter S.Illinois
Re: Spray Booths
Leo
Thanxs I see now what a proper spray booth should look like and what elemets that need incorporated.......... |
#17 | |
LRG WoodCrafting
This is probably overkill for what you have in mind but the basic elements are there for you to draw upon. Good Luck
| eliminating spray gun splattering | saucedo80 | Painting & Finish Work | 11 | 11-02-2010 02:47 PM |
| Painting Exterior EIFS Home / Spray Gun Setup | plazaman | Painting & Finish Work | 9 | 06-18-2007 11:03 PM |
| spray, brush, or roll doors? | Traditions | Painting & Finish Work | 13 | 03-31-2007 10:20 AM |
| regarding spray painting | gregferd | Painting & Finish Work | 1 | 03-05-2007 08:34 PM |
| spray rig | wink | Painting & Finish Work | 6 | 08-25-2006 09:17 PM |
