Spackle Over Caulk
Old 04-08-2006, 10:37 AM   #1
cynthiann's Avatar
Trade: trim,paint,clean
Spackle Over Caulk
I assisted a friend one time who was running behind. He had mitered two baseboard pieces together with about a quarter inch gap in between. I cringed, but he said he could fix it. First, he threw some caulk in it. After it dried and shrank, he put spackle in it and leveled it off. After it was painted, you couldn't tell it was there with a manifying glass.
His reasoning is that the spackle won't crack when the wood expands and contracts because it's not touching the wood...there is a layer of caulk between them. Does this make any sense to you guys?
cynthiann is offline
Old 04-08-2006, 11:28 AM   #2
phinsher's Avatar
Trade: Paint and wallpaper
Re: Spackle Over Caulk
Not really sure, but i tried the same thing for a customer about 5 years ago. It was a curved riser going up a stairway. Where 2 pieces were mitered together there was an obvious crack. She said 4 different painters had repaired it and it always came back. the problem was this million dollar house was about 30 yards away from a train track. We dug out the crack, spread in caulk with a putty knife, then skimmed with a hard spackle/putty then primed and painted. After a month it still hadn't come back and i've never heard about it since then.
phinsher is offline
Old 04-08-2006, 06:36 PM   #3
CarlW's Avatar
Sure it makes sense. It's the same theory we use when filling drywall cracks that keep coming back with caulk and then floating over that with drywall mud.
CarlW is offline
backsplash caulk fast pasquale Remodeling 9 03-29-2007 12:50 PM
Caulk flat panel doors in cabinets? cstrombe Painting & Finish Work 8 02-25-2007 06:04 PM
wood filler vs. caulk for trim fabiano Painting & Finish Work 13 07-29-2006 03:09 PM
Ceder siding to caulk or not to caulk??? Dave Mac Painting & Finish Work 10 05-26-2006 09:33 PM
How to get caulk in a real tight spot ProWallGuy Painting & Finish Work 19 04-11-2006 06:04 PM
