Smooth Wall Questions/frustrations
Old 08-12-2007, 11:11 PM   #21
Paint Pro/Faux Artisan
Da Vinci's Avatar
Trade: Painting Contractor/Faux Finisher
Re: Smooth Wall Questions/frustrations
Originally Posted by Cummins View Post
Bill, no offense taken. If you use a roller, let it dry, step back and look, you can see every path the roller had taken. The spray rig was used by the drywall company that sprays mud on the wall, just like an airless sprays paint, it puts the mud on evenly.
I understand about perfection, and you are probably correct about being obsessed with it. I know perfection cant be achieved, but a good quality job is not expecting too much.
If an airless sprayer is used, then you can see the overlapping edges that the spray gun makes.
Yep- Slickshift is exactly right. There are only a couple of reasons you're having these problems- if your paint quality is not good, or primer is not correct, or painter's technique is not good (sounds like he's over-rolling it - causing it to dry out and stipple. Roll once or twice quickly and leave it alone.Most guys over think smooth wall and overwork it which is worse than under working it with level 5).
I used to be a "perfectionist" but realized that I was just being obsessive and never satisfied. Now I follow this creed, "Strive for perfection, settle for excellence". I am happier and so are my customers.
I'm not there and can not see what you see, but I do hear the "nothing less than perfect" warning sign. I do not mean to insult you or discount your need for top quality, but do step back and examine what you are asking for: perfection or acceptable excellence.
I couldn't have said it better myself DaArch- There is no such thing as perfection because a perfectionist will always be able to find something else to fix- I use to drive myself crazy this way- patching fixing painting, oops- something else- patch fix paint- oops one other thing, etc, etc,etc.
Still sounds a lot like application error...
Bay Area Painting Company
Da Vinci is offline
Old 08-12-2007, 11:55 PM   #22
Cummins's Avatar
Trade: plumbing contractor/general contractor
Guys, I cannot thank you enough for the help. Now that we have identified the possible causes, how do you guys propose the problem get fixed?
Is it feasible to re prime and start over? Do we switch roller types to what we know to be the best available and go over what is already done?
Or do I switch to a different brand of paint and respray everything? Do we only paint in the morning when it is cooler?
I truly am at a loss to all this, so do know that all of your input and advise is taken to heart. Again, I do thank all of you for the help.
Cummins is offline
Old 08-13-2007, 03:01 AM   #23
Joewho's Avatar
Trade: Painter
Originally Posted by MarvinWilleyJr View Post
They use a product they call equalizer as a final coat for level 5 around here. It's not mud but kinda like that. They spray a heavy coat of it, then we put primer over that.
As for the all one dirrection thingy.......sounds great but, I don't believe that's a big deal.....if you can roll, you don't need to make one pass down then....another pass down....and so on. Seem as though that's a big waste of time.........unless you can't roll right.
Thanks for the info about equalizer.
Half the time I use a merino skin and it does matter which direction if you're going to have light on it at an angle.
For a flat ceiling, this shouldn't be a problem at all. He could even be dryrolling.
Joewho is offline
Old 08-16-2007, 10:37 AM   #24
Classic Professional
George Smed's Avatar
Trade: High End Painting
Hello,
I'm pretty sure I read all the posts and I haven't seen anyone mention the art of sanding the walls between coats of paint. After the primer coat, and after the first coat of finish. This helps take down brush strokes and roller marks and leaves a smooth finish. I also make sure I cut the wall in then roll. This helps hide and shrink the brush mark width (Picture Framing). If someone else has already mentioned this. Sorry for stepping on toes.
George Smed is offline
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 07:16 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
Best way to smooth wall over knockdown texture dforeid Drywall 10 02-01-2007 07:36 AM
moving centennial wall stacker Masonry 4 10-20-2006 12:12 AM
