Smooth Over Painted Block Wall
Old 05-05-2008, 08:07 AM   #1
karma_carpentry's Avatar
Trade: carpenter
Hi... I'm remodeling two condos. One of them has a lot of block wall that's been painted. I want to smooth out the wall to get rid of the 'institutional' feeling. (See the picture.)
I've been learning about parging. I have parged before, on an exterior foundation wall, but nothing interior. My thought was maybe to first rough up the existing paint and maybe use a BondKote or "liquid sander" something to give it tooth, then parge on a fine mortar, and then plaster it up.
But then I thought maybe some sort of faux Venetian plaster paint product would work alright, even if it takes two coats. Or maybe is there some basecoat thick paint-type product that would take up the dimples and fill the joints?
In most cases like a basement finish job, I would fur out the walls with 1 1/2" and put in rigid insulation, but in this case there are baseboard heaters and receptacles and intersections with door and windows, and it would be a heck of a job more than it's worth.
So I am turning to you wall finishing experts for some opinions. Help appreciated. Thanks.
PS - Yes, I know there are crack in the block wall. The building has structural problems but the location is excellent, even in this market, it will sell for a pretty penny with some basic TLC. I'm not looking for magic, but just to cover up the cracks for a while. Someone in the 70s put up this building without any concern except for saving a penny, and I can't fix the world in a day, just make my dollar and help the current owner.
Build on a good foundation.
karma_carpentry is offline
Old 05-05-2008, 08:25 AM   #2
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Smooth Over Painted Block Wall
Check out Flexi-Wall products. Paperhangers use this stuff to smooth over cinder block to hang new wallcoverings. Can be painted also.
ProWallGuy is offline
Old 05-05-2008, 10:55 AM   #3
Motorboatin' son of a ...
BKFranks's Avatar
I'd have the stucco/plaster guys skim coat the wall. You'd probably have to sandblast the wall first to get the paint off. They could put a smooth finish just like a smooth stucco finish on the outside of a house. I've had them cover over a red brick fireplace and one house last year they did a shower and bathtub surround for an industrial look.
BKFranks is offline
Old 05-05-2008, 10:11 PM   #4
plazaman's Avatar
Lath and a 1 coat stucco job?
plazaman is offline
Old 05-06-2008, 08:01 AM   #5
Frankawitz's Avatar
Metal lath then scratch coat and then sand finish coat or smooth plaster finish depending on the look you want.
www.frankawitz.net
Frankawitz is offline
Old 05-22-2008, 07:58 AM   #6
Trade: carpenter
Thanks for the advice, fellows. What I ended up doing was a basecoat of Structo-lite and and veneer plaster over it.
I was nervous about adhesion, so I tested a small section first, and the Structolite stuck very well. The blocks are rough enough, even with the paint, for good keying in.
I'm not a great plasterer, so after the plaster, I knifed in joint compound and sanded down smooth, to fill the holidays from my plaster job.
I probably should have called in a plasterer, but it was not bad work, and I enjoyed it mostly.
Glass block shower wall Soul-tez Kitchens & Baths 9 03-27-2011 10:22 AM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Block basement wall bed joint crack BreyerConstruct Masonry 4 02-14-2008 09:48 AM
smooth wall questions/frustrations Cummins Painting & Finish Work 23 08-16-2007 10:37 AM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
