Should I Prime These Soffits Or Just Paint?
Old 04-14-2009, 01:32 AM   #1
Entrepreneur's Avatar
Hey I am going to be scrapping some loose paint off some soffits which are covered and outside of the rain etc.
Theres going to be bare would, but seeing as how they are not exposed to the sun or elements do I really need to oil prime to seal up the wood first?
Or can I just paint over top with an acrylic paint.....
Thanks!
Entrepreneur is offline
Old 04-14-2009, 02:10 AM   #2
Knowledgeable Tinter!
Faron79's Avatar
Trade: Painting/Hardware Retail
Re: Should I Prime These Soffits Or Just Paint?
Yep, use an Exterior Oil primer on ALL surfaces, once all dust is cleaned-off.
This ensures even bonding & gloss-levels of your new paint.
Of course, you need to feather-sand all scraped areas, so no "ridges" are visible.
Then...prime, and apply 2 coats of your exterior Satin or Semi-gloss paint.
Faron
Faron79 is offline
Old 04-15-2009, 02:55 AM   #3
Organic Painter
Mr. Mike's Avatar
Trade: Painting Contractor
DEFINITELY Prime...
Wrong!
You do not need to prime, use a top of the line lifetime warranty self priming paint and get this done with one coat! And that is no joke.
Mr. Mike is offline
Old 04-15-2009, 04:30 AM   #4
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
Lifetime warranty paint? Joke
Self priming paint,joke.
One coat? Bigger joke.
As Faron said,do it the right way, not the hucksters way.
chris n is offline
Old 04-15-2009, 05:23 AM   #5
genecarp's Avatar
a painter asking how to paint hmmm
genecarp is offline
Old 04-15-2009, 11:17 AM   #6
Organic Painter
Mr. Mike's Avatar
Chris,
As Faron said,do it the right way, not the hucksters way. Today 02:55 AM
Your Joking right? Cause that's all I use is Lifetime self priming paint!
Mr. Mike is offline
Old 04-15-2009, 01:40 PM   #7
StefanC's Avatar
Trade: Prep Nazi
You can use a self-priming lifetime paint and it will probably last just fine. I normally hit any exterior bare wood with some oil primer just for good measure though.
StefanC is offline
Old 04-15-2009, 06:29 PM   #8
Ace Texture & Paint
jd6387's Avatar
Send a message via Skype™ to jd6387
Hey Mr. Mike,
What paint are you using to one coat with no primer??
jd6387 is offline
Old 04-15-2009, 08:44 PM   #9
Organic Painter
Mr. Mike's Avatar
lifetime paint
Hey Mr. Mike,
  1. Sherwin Williams: Duration
  2. Benjamin Moore: Aura
  3. Porter Paints: Permanizer
Mr. Mike is offline
Old 04-15-2009, 09:58 PM   #10
Ace Texture & Paint
jd6387's Avatar
I appreciate it. I know those paints, just making sure you didn't have another I missed or was new. I'm in Dallas, but my wife and I are from Louisville. still got property at land-between-the lakes. Thanks.
jd6387 is offline
Old 04-15-2009, 10:11 PM   #11
Professional Instigator
rbsremodeling's Avatar
Whose house is it?
rbsremodeling is offline
Old 04-16-2009, 12:56 AM   #12
Faron79's Avatar
Even if it's C2 Exterior, Aura, Duration, ......
(and we SELL C2)
Priming will only help, never hinder.
The risk of sheen-variation is just too great, especially on bare wood portions...
MY little saying..."Priming SOLVES many problems, but creates NONE."
Faron
Faron79 is offline
Old 04-16-2009, 05:05 AM   #13
chris n's Avatar
If you are comfortable using these products on exterior bare wood,good for you. I will stick to the PROVED method of slow dry oil primer and 100% acrylic top coats
chris n is offline
Old 04-16-2009, 08:05 AM   #14
Organic Painter
Mr. Mike's Avatar
Faron and Chris don't trust the can.;lol
Mr. Mike is offline
Old 04-16-2009, 09:59 AM   #15
Organic Painter
Mr. Mike's Avatar
Here's one can for you...
Exterior Paints
Duration® Exterior Acrylic Latex
Product Literature (PDF 1416KB)
Our advanced exterior formula features PermaLast® technology for the most durable, longest-lasting exterior coating available for resisting peeling and blistering.
Features:
  • One-coat, self-priming performance on repaints, two coats on new work
  • Superior hide
  • Thicker, more flexible coating
  • Maximum resistance to blistering and peeling
  • Guaranteed to last (see label for warranty information)
Flat Data Sheet MSDS Satin Data Sheet MSDS Gloss Data Sheet MSDS
Mr. Mike is offline
Old 04-16-2009, 10:41 AM   #16
Organic Painter
Mr. Mike's Avatar
I give everyone an awesome warranty to go with these products and services I provide them.
http://www.mrmikespainting.com/paint...ouisville.html
Mr. Mike is offline
Old 04-16-2009, 07:28 PM   #17
capital city's Avatar
Trade: painting
Duration is not proven? Ive proven it over and over again with no call backs. Duration has made me alot of money and allowed me to keep busy with all the hacks low-balling everything. Ive been able to skip the priming step and cut cost a little. It does cover in 1 coat in some situations but most of my exteriors get 2. Mr Mike I'm right over here in Frankfort, if you got any Duration exteriors you want to sub out give me a call.
capital city is offline
The Following User Says Thank You to capital city For This Useful Post:
Mr. Mike (04-19-2009)
Old 04-18-2009, 06:43 PM   #18
DRC's Avatar
Trade: painting
prime it with an acrylic bonding primer. the days of oil are on the way out.
DRC is offline
Old 04-19-2009, 01:30 AM   #19
Organic Painter
Mr. Mike's Avatar
These primers you guys speak of are way over rated. Acrylic or oil.
Mr. Mike is offline
Old 04-19-2009, 02:17 AM   #20
Smart phone? Scan me!
nEighter's Avatar
Trade: Painting/Framing/Drywall
only time I have ran into problem priming anything is when I have used wood filler Bondo (R) to fill spots. It is actually better to apply that to the wood it's self, vs. priming it and then applying. For what ever reason, it likes the raw wood better than the primer. It pops right off the primer. If raw, prime, if any type of factory primer/paint is there, scuff and paint and you should be fine. Really all primer is is a layer that will accept paint. Previous paint layers/factory primer is okay, just make sure there is something that the new coating can bite into. 1 coat paints are a marketing ploy. You ALWAYS have to go REALLY thick, or 2 coat with them... that is if you really care about what you are doing.
nEighter is offline
Need paint help silvertree Painting & Finish Work 22 04-17-2009 09:53 AM
Short Review Of Aura Paint Riverside Paint Painting & Finish Work 30 03-07-2009 08:50 PM
cabinet paint of choice world llc Finish Carpentry 8 12-31-2008 08:43 PM
Paint needham Painting & Finish Work 2 03-02-2007 07:17 AM
Roof paint Teetorbilt Roofing 3 05-07-2004 05:47 PM
