Sherwin Williams Loxon XP
Old 08-08-2005, 09:22 PM   #1
Nathan's Avatar
Trade: Founder of Contractor Talk
Rewards Points: 2,000
Has anyone used Sherwin Williams Loxon XP yet?
I took a tour of the Sherwin Williams plant in Orlando last week and they were making some pretty huge claims about this product.
Streches 350% to bridge cracks like elastomerics but it breathes and doesn't fade or attract dirt like elastomerics do.
Just wanted to see if anyone was using this product. If you are using this... how do you apply it? How many coats, what primer (if any), and how thick do you put it on? I think they said it needed to be applied at 15 mils and then dries to 7 mils in one coat.
Nathan
Ran off to make great mobile software for contractors. Leveler.com
Nathan is offline
Old 08-08-2005, 10:32 PM   #2
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Rewards Points: 1,000
Re: Sherwin Williams Loxon XP
Yeah, Loxon is good stuff! :Thumbs: It's mainly used for masonry/stucco...Used it at another company in new construction. We applied the Loxon concrete conditioner 7 days after it's put up, and painted right over it without even having to wait for the concrete to cure. Their official coating systems catalog recommends two topcoats, but we only used one....sprayed and backrolled. Always had good results with it too...
Weathered Wood Restoration LLC
Deck Staining & Restoration Jacksonville, FL
Pressure Washing Jacksonville, FL
AAPaint is offline
Old 08-08-2005, 10:40 PM   #3
plumguy's Avatar
Trade: plumbing and heating
Rewards Points: 250
AA, would that Loxon be good for a basement (cement)floor?
plumguy is offline
Old 08-08-2005, 10:45 PM   #4
Nathan's Avatar
I've used Loxon for a while... but Loxon XP is new and very different than the old Loxon.
Nathan
Nathan is offline
Old 08-08-2005, 10:53 PM   #5
Pro Painter
AAPaint's Avatar
Doh, in my zeal to respond my pea brain failed to hear anything but "loxon"....hmm! I honestly can't say I've used the new stuff, but I hear good things allready...
AAPaint is offline
Old 08-08-2005, 11:00 PM   #6
Nathan's Avatar
If applied as SW tells you to, it actually qualifies as a Water Proofing system that Sherwin Williams backs up. Since I'm down here in Florida thats a great promise to be able to make!
Nathan
Nathan is offline
Old 08-08-2005, 11:03 PM   #7
Pro Painter
AAPaint's Avatar
No, I wouldn't use this on a basement floor. I'd be looking into something like ArmorSeal® 1K Waterbased Urethane Floor Enamel...but you've gotta have a dry slab. Or ArmorSeal 1K TreadPlex Waterbased Acrylic so it can breathe a little....If the slab is wet and you're trying to seal it, then it's over my head, heh!
AAPaint is offline
Old 08-08-2005, 11:09 PM   #8
plumguy's Avatar
Rewards Points: 250
No, it's dry! and thanks for info. :Thumbs:
plumguy is offline
Walmart paint made by Sherwin Williams? KellyPainting Painting & Finish Work 54 01-18-2011 10:55 PM
question about sherwin williams Wensdy Drywall 2 11-15-2008 07:43 PM
Sherwin Williams question Wensdy Painting & Finish Work 8 04-13-2007 09:22 PM
A Ben Moore Guy uses Sherwin Williams Part IV slickshift Painting & Finish Work 15 08-24-2006 07:47 PM
Sherwin Williams primers ChuckEA Painting & Finish Work 15 05-14-2006 04:39 PM
