Set-Up For Spraying Cabinet Doors
Old 02-18-2013, 02:58 PM   #41
tjbnwi's Avatar
Rewards Points: 1,744
Re: Set-Up For Spraying Cabinet Doors
Would have been hard to shoot the first 2 on the flat.
(Table created by Chuck Kiser of Knollwood Construction, I'm only doing the finish)
Set-Up for Spraying Cabinet Doors-image-2007613617.jpg   Set-Up for Spraying Cabinet Doors-image-3469668213.jpg   Set-Up for Spraying Cabinet Doors-image-498317461.jpg
tjbnwi is online now
Old 02-18-2013, 03:08 PM   #42
KAP's Avatar
Trade: Custom
Rewards Points: 24,354
Well now, that's not a door now, is it?...
Love the cans... lol... been there, done that...
KAP is offline
Old 02-18-2013, 03:50 PM   #43
r4r&r's Avatar
Trade: Contractor
That's one high tech booth ya got there. Same type I would have if I need one.
r4r&r is offline
Old 02-18-2013, 03:58 PM   #44
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 568
Originally Posted by Leo G View Post
On a quality job I spray 3 coats on the front and 2 on the rear. Start on the front and then flip after it dries and continue until you have the 5 coats on. The face should always be the last coat. That way no chance of damage.
On a price job 2 coats each side, use nail boards. Spray the back and then put the nail board on the door and flip it, spray the front. Put in rack to dry, repeat again.
Leo, what do you mean by nail board? Sorry for the rookie question.
I can't compete with hacks.
donerightwyo is online now
Old 02-18-2013, 07:13 PM   #45
Kent Whitten's Avatar
Rewards Points: 2,040
Nail boards have 3 or 4 nails or screws poking through a board (I have used 1/2" ply scraps). You start with the good side down on the points (very gently of course) and spray the back side first, no edges. Then flip the door over carefully laying the freshly sprayed door face on the points and quickly finish the sides and good face.
By the time it all dries, it is pretty difficult to see the pin holes. You can touch those up pretty easy though.
I used to do the nail board, but don't anymore. I spray one side at a time.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 02-18-2013, 07:36 PM   #46
Rewards Points: 568
That's what I thought. I guess I was confused when he said he put the nail board on the door and then flipped the door. I would of thought that you flipped the door and set it on the nail board. Thinking about it now though I can see how it would be easier to hold the door(with out touching the wet finish) and with less risk of dropping it on the nails. That Leo is pretty sharp
Old 02-08-2018, 09:06 PM   #47
tjbnwi's Avatar
I was PM'd a question, can't link photos there.
The benches are MFT-3's.
The paper roller is 2" PVC, I use a closet flange as the wheel, had to reduce to fit the 2" PVC.
Axle for new paper roll is 1/2" EMT.
Set-Up for Spraying Cabinet Doors-img_0356.jpg   Set-Up for Spraying Cabinet Doors-img_0357.jpg   Set-Up for Spraying Cabinet Doors-img_0354.jpg   Set-Up for Spraying Cabinet Doors-img_0353-1-.jpg
B.Johnson (02-09-2018)
Old 02-08-2018, 09:16 PM   #48
dale rex's Avatar
Trade: painting and carpentry
Rewards Points: 169
Thanks Tom. Nice setup. How do you ventilate the filtered intake behind the table?
dale rex is offline
Old 02-08-2018, 09:23 PM   #49
tjbnwi's Avatar
Rigid air mover.
This is the only picture I currently have of it.
I'm shooting one door so I didn't have the bench setup and the air mover connected to it.
Old 02-08-2018, 09:45 PM   #50
tjbnwi's Avatar
Travis, do you have a picture of the air mover connected to the bench?
Old 02-08-2018, 10:34 PM   #51
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 406
These are a couple of your setup.
Dale, they are connected with starting collar takeoffs for hvac available at your hardware store.
Xtrememtnbiker is online now
Old 02-09-2018, 05:30 AM   #52
dale rex's Avatar
Rewards Points: 169
Is that 4" or 6" tubing? How did you connect to the intake of the air mover?
dale rex is offline
Old 02-09-2018, 08:03 PM   #53
Rewards Points: 406
6
In the first picture you can see a small piece of foam with a takeoff in it. That piece fits to the side of the air mover. I tape off the intake on the other side so all the air will pull through the duct work.
Old 02-09-2018, 08:57 PM   #54
tjbnwi's Avatar
If I remember I'll get a pic next week of the connection. Travis and I use the same process for connection.
Old 02-18-2018, 10:16 PM   #55
dale rex's Avatar
Rewards Points: 169
Thanks Tom. I love the setup. Going to build myself something similar, maybe not as large, when I get some spare time. Cant always find the extra time for improvements like this, business has been good this winter so far. If you get the chance I would like to see the hookup to the air mover. Also been looking at cylinder type portable air movers, might be an easier connection for intake and they come with an exhaust tube.
dale rex is offline
Old 02-19-2018, 09:43 PM   #56
Rewards Points: 406
The suction holds the adapter on when you turn the air mover on. Overall this is an inexpensive setup that performs better than having no air filtration and exhaust.
Old 02-19-2018, 09:51 PM   #57
dale rex's Avatar
Rewards Points: 169
Thanks for all the pics. Definitely worth the effort for me to build a setup like yours. Do you use airless or HVLP? It looks like it should grab most of the overspray from either type.
dale rex is offline
Old 02-19-2018, 10:00 PM   #58
Rewards Points: 406
I use an HVLP in the shop with this setup. I'm not sure that I would say it gets most of the overspray, but it certainly cuts down on it. There isn't enough CFM when you're spraying larger pieces such as cabinets.
If you're spraying doors and drawer fronts, pieces, etc on the bench, it does pretty well. If we get a job I just submitted a bid on, I'll be getting a more appropriately sized fan for the job because I'll be spraying a lot of pieces.
Old 02-19-2018, 10:04 PM   #59
dale rex's Avatar
Rewards Points: 169
What type of fan are you thinking about upgrading to get more CFM?
dale rex is offline
Old 02-19-2018, 10:16 PM   #60
tjbnwi's Avatar
Thanks for getting the pictures up Travis.
Mortar in Fireplace doors 6stringmason Masonry 8 07-12-2012 09:23 PM
Hidden hinges for traditional cabinet doors Panzer5 Finish Carpentry 6 06-13-2012 07:30 PM
bamboo cabinet doors? chris klee Finish Carpentry 47 06-08-2012 06:12 PM
Cabinet doors and drawerfronts. New MDF beaded UpNorth Carpentry 15 10-10-2010 11:12 AM
making cabinet doors world llc Finish Carpentry 44 04-19-2009 10:11 PM
