Trade: interior paint contractor and window treatment workroom
Semi Gloss On Walls?!?!what Do You Think??
went to job to give an estimate for interior painting job(3 bedrooms and a family room)for a interior decorator i am starting to work for. she started recommending to the customer that she might want to use a semi gloss finish on the walls...i let her know my reservations about using semi gloss on the walls(i hate the look,i think it cheapens the look of the walls)...later she told me that bm and sw is recommending it because of the light refracting off the wall/and something about the color yada yada yada. anyone ever heard of this and what is your opinion on the subject?
Re: Semi Gloss On Walls?!?!what Do You Think??
An Interior decorator recommended semi-gloss??? Usually they are the ones that constantly recommend flat for walls, while I like shinier walls like eggshell or satin finish. Are you sure she recommended semi-gloss? She probably wants one of those matte finishes, and read how its scrubbable like a semigloss - and then got the lingo confused in her head. Semi-gloss? Are you sure?
-plainpainter |
Trade: Paint & Tile
my interior decorator friend is the same way s.gloss on the walls. ive expressd myself over and over again. but for the money she pays me anymore i just get it done
Trade: Painter
That is yet another reason they should be refered to by their proper title: Interior Desecrator.
yes i didn't hear wrong...it was semi gloss...yuk...at least i know she not the only one who has bad taste!!hopefully she will change her mind!?!?!
painterofeverything
look on the bright side, at least you are getting paid to do it..quit bitching and do it !
#7 | |
Pro Painter
Bah...I'd charge extra if it's semi on walls. Ignorant in my opinion, but what do I know, I'm not a designer.
Trade: Painter
Decorators usually want semi on the wall if they are doing a faux over it.
Otherwise, I just give them what they want. |
Deck Cleaner
Trade: Deck Cleaning, Staining, Restoration
The light refracts beautifully into every bump and imperfection. Make sure your prep is near perfect.
Trade: Painting Contractor
Is'nt that the truth. Touch up on any wall where sunlight hits will be about impossible to touch up. I would recomend eggshell giving some sheen and washability. Semi-gloss in bathrooms and kitchens are ok... Yet if she is paying you, give her what she wants. As mentioned before make sure your walls are as close to perfect that you can get.
Trade: painter
most interior decorators will recomend semi-gloss or pearl finishes for the reflectivness of the paint....
it can look real good if walls are perfect!! its your job to charge them for the prep!!!!
#12 | |
Trade: Remodeling contractor
Re: Semi Gloss On Walls?!?!what Do You Think??Quote:
Back in Maine Dubbin' Around Doin' good stuff ...... |
Trade: Painter
Some companies' semi isn't as shiny as others.
For semi, I do a quick coat and go over the walls with a fine tooth comb. Make it right and finish it up. Nothing like getting it done and then finding something you'd like to fix. |
Bah Humbug!
I'm not a painter by any stretch of the imagination. HOWEVER, I purposely put semigloss on my walls. I know every painter told me not to do it, but here is why I did. 1) The only room with overhead lights in my condo is my kitchen, every other light is a floor lamp. Thus light is usually dim, so I wanted the semi gloss for reflectivity. 2) Flat paint just sucks for cleaning, and it's almost like you are better off just touching up every smudge and blemish rather than bothering to try to clean it...
When I re-rodeled my kitchen, I used flat paint. I used flat paint because it has more than ample lighting, however I am going to re-paint the kitchen with egg shell for cleaning purposes. Flat sucks to clean. |
#15 | |
Zip-Ah-Dee-Doo-Dah of
IMO, satins are more than enough except for kitchen and baths. Cleanability comes with paint quality. I also think Grumpy needs to have his decorator sell 'em a lighting package. |
Trade: Painting & Remodeling
Now I think in a properly decorated room a semi can look real cool. Esp a high quality paint. Cashmere Medium lustre is like semi only the orange peel is not as pronounced. I recently painted my own bathroom HIGH gloss pink (very mellow pink) to go with the existing tiles and it looks pretty slick.
#17 | ||
My custom title
Benn Quote:
#18 |
Trade: Painter
Zip, I cannot believe it. I would never have guessed you to be a semi-gloss on walls guy. I only use satin on walls in kitchens and bathrooms if customers twist my arm. In my area, everyone wants the washable flats (Graham's mostly). I sometimes will use an eggshell in the deep reds for regular room walls.
#20 | |
| latex semi gloss over oil semi gloss - can it be done? | Zeebo | Painting & Finish Work | 13 | 09-05-2007 06:38 PM |
| Any complaints with BM Aqua Glo Semi Gloss? | Richie-C | Painting & Finish Work | 8 | 06-06-2006 09:15 PM |
| high gloss paint help | Duncan | Painting & Finish Work | 7 | 11-12-2005 08:53 PM |
| Spraying primer and flat, 3rd coat semi gloss? | Tonkadad | Painting & Finish Work | 5 | 08-12-2005 02:33 AM |
| Painting over Semi Gloss | Unregistered | Painting & Finish Work | 3 | 04-13-2004 09:44 PM |
