Semi-Gloss Question
Old 11-17-2008, 09:52 AM   #1
bujaly's Avatar
Trade: Commercial interior super
Semi-Gloss Question
What's the secret to painting inside corners when it comes to semi-gloss..?? I've used numerous brands of semi-gloss paint, but in the end, when cutting the inside corners, the brush never lays the paint down like a roller, and I am sometimes painting the inside corners like 5 times.. UUURRRGGGHH!!! WTF????
What am I doing wrong and how do I fix this..?? Different applicator, the brand of paint, extra primer in the corners.. ??
"Relentless in Reliability and Satisfaction!"
Oh yeah, 1 other thing...
Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
bujaly is offline
Old 11-17-2008, 10:26 AM   #2
A bit abrasive.
WisePainter's Avatar
Re: Semi-Gloss Question
Anything above an eg~shel/satin finish and there will be visible roller into cut in lines no matter what applicator you use.
My first thought is to use a mohair roller, however the job would be too annoyingly slow for me to wrap my mind around.
Maybe if you sprayed the walls and back rolled with the mohair?
excuse the smoke pouring from my ears...
Semi~gloss on wall is a head scratcher to me unless it is a commercial environment.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 11-18-2008, 01:18 PM   #3
bujaly's Avatar
Thanks Wise... MOHAIR...????
ANyone else out there have a tip or 2?
bujaly is offline
Old 11-18-2008, 03:53 PM   #4
NAV's Avatar
Trade: commercial building restoration
I don't think i would use a mohair with latex. you should probably use a 1/2 inch nap roller (not the cheap one) and just roll tight. if you are picture framing in you can try cutting twice and then rolling but I think that if you roll tight to the corners you will be fine.
NAV is offline
Old 11-19-2008, 06:30 PM   #5
A bit abrasive.
Flotrol!
Old 11-20-2008, 02:44 AM   #6
1day@aTime
Thedford's Avatar
There are a couple ways you can approach it.
You can get a 3/4 Purdy Super Fab which is designed to cut inside corners.
Just cut everything out with the brush like you normally would (including corners), and just roll the corners out. when you roll out the first side, the other will get swirl marks, just roll as close as poss on the other side and with the corner already have a first coat it will be hard to tell the difference; thus leaving no brush marks with plenty of paint.
or
you can just go to walmart and get the sure-line cutting pad thingamajig, which I do use to run all my wall to ceiling cuts when painting apt. and let me tell you something, it might look like a beginners tool but when you have alot a painting to do, it will do 75% of the work that consumes the most time which is cutting in. There is a niche to it though and will take some practice.
But when run I those ceilings, I can do a 1414 sqft house in about 30 min.
You get a 2-3' spread per dip when you first start and then when you get the technique down, you can run it longer, you just have to learn how to control the paint better.
Thedford is offline
Old 11-20-2008, 07:32 AM   #7
NAV's Avatar
I can't believe someone uses that painters pad after they got suckered into trying it once.
no offense but any one of my guys will cut a room twice as fast as you using a brush. especially when you have to cut it twice since your painter pad didn't cover.
I have never used one, but i assume its like smearing the paint on the wall with a rag.
NAV is offline
Old 11-20-2008, 08:28 AM   #8
Steve Richards's Avatar
Trade: hack painting
Are we talking about that thing with the two little rollers at the top...that roll along and cut-in the ceiling for you?
ha...yeah,those rule.
Steve Richards is offline
Old 11-20-2008, 04:45 PM   #9
painterdude's Avatar
Trade: painting contractor(semi retired)
yea, I've seen where homeowners use those wheel thingies. I especially like the wheel marks from dipping the wheels in the pan) an inch in on the ceilings. Priceless. pd
painterdude is offline
Old 11-20-2008, 06:02 PM   #10
LRG WoodCrafting
Leo G's Avatar
What about one of those inside corner rollers? Cut it in with a brush and texture it with the roller. Should look similar.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 11-21-2008, 09:41 AM   #11
bujaly's Avatar
That Shure-line thingamajig is THA SH$#... I love it.. I use it on door and window trim as well. As for you all that say its a HO tool, keep using a brush..
bujaly is offline
Old 11-30-2008, 06:27 PM   #12
blackstonepainting.com
blackstone's Avatar
Trade: Painter
I agree with 'wisepainter'
Flotrol will definately help. Also, try using a self-leveling product...
blackstone is offline
Old 11-30-2008, 11:05 PM   #13
johnthepainter
johnthepainter's Avatar
just cram the roller into the corner, and flatten out the snail trails with the brush.
www.johnthepainter.com
johnthepainter is offline
Old 12-07-2008, 11:50 PM   #14
RayGoerdt's Avatar
Trade: Residential building/Remodeling
Send a message via AIM to RayGoerdt
or
I have also used this with great results, I don't do alot of painting, but when I do this thing works for me.
RayGoerdt is offline
satin or semi gloss??? tyler durden Painting & Finish Work 6 07-14-2008 08:59 PM
Latex semi gloss over latex semi-gloss? send_it_all Painting & Finish Work 3 10-01-2007 10:59 PM
latex semi gloss over oil semi gloss - can it be done? Zeebo Painting & Finish Work 13 09-05-2007 06:38 PM
Semi gloss on walls?!?!what do you think?? lornmastro Painting & Finish Work 21 02-16-2007 10:52 PM
Any complaints with BM Aqua Glo Semi Gloss? Richie-C Painting & Finish Work 8 06-06-2006 09:15 PM
