Sealing Nicotine - Painting & Finish Work - Contractor Talk
Sealing Nicotine
Old 11-20-2017, 09:29 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 2,244
Sealing Nicotine
Since it dates to the 90's for my sealing for smokers, a time when I applied solvent-based bin or kilz, I need to ask how the 'newer' latex solutions hold.
On walls, stomped ceilings, OSB floor.
These perform or merely hype?
artinall is online now
Old 11-20-2017, 12:49 PM   #2
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,482
Re: Sealing Nicotine
I dont believe so, I stick with the oil base sealers.
Ohio painter is online now
The Following User Says Thank You to Ohio painter For This Useful Post:
artinall (11-20-2017)
Old 11-20-2017, 07:11 PM   #3
artinall's Avatar
You have a preference?
Old 11-20-2017, 07:20 PM   #4
tjbnwi's Avatar
Rewards Points: 4,932
Try Kilz Max.
tjbnwi is offline
Old 11-20-2017, 07:36 PM   #5
Either SW Problock or kilz.
Old 11-20-2017, 07:57 PM   #6
artinall's Avatar
Originally Posted by tjbnwi View Post
Try Kilz Max.
Kilz Max I have not tried. Maybe I will.
Have used problock for other priming, wasn't aware it could handle nicotine.
I'm doing my best to avoid digging the respirator out from storage, and setting up the 440 just for a single room (oil in the line) for a small job likely coming on.
Maybe I could price it two ways? One latex and one solvent. You don't know until it dries.
That solvent stuff makes me �� Normally I avoid this type of work but with winter rearing who knows.
Old 11-20-2017, 08:00 PM   #7
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
Sorry, got to go oil or shellac. If you can smell it, your respirator isn't working. Shave to get a better seal on your face.
www.callbathdoctor.com
Driftweed is offline
The Following User Says Thank You to Driftweed For This Useful Post:
Old 11-20-2017, 08:01 PM   #8
tjbnwi's Avatar
Wash the room with Krud Kutter. Use a sponge mop.
Prime with what ever.
tjbnwi is offline
artinall (11-20-2017), SmallTownGuy (11-21-2017)
Old 11-21-2017, 12:12 AM   #9
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,356
Nothing but shellac or oil will work. Everything else will bleed.
You need to allow the primer to dry overnight to finish curing sometimes as well if the nicotine is really thick.
Metro M & L is offline
Old 11-21-2017, 12:53 AM   #10
Unger.const's Avatar
Rewards Points: 2,850
Talk about timing. I'm working on a place that a guy smoked in for like 30 years. Place is a wreck. Mold grease. Nicotine........I worry no primer will stand up to it all. The owner dropped of a bucket of latex kilz 2 and I never had luck with it before.
Was wondering what would be the ultimate stain hides for this
Unger.const is offline
Old 11-21-2017, 01:13 AM   #11
avenge's Avatar
Rewards Points: 3,140
Don't waste your time with Kilz 2 or any water base, BIN shellac is your best bet.
avenge is online now
The Following 2 Users Say Thank You to avenge For This Useful Post:
hdavis (11-22-2017), Unger.const (11-21-2017)
Old 11-21-2017, 08:20 AM   #12
tjbnwi's Avatar
Wash the place.
tjbnwi is offline
Old 11-21-2017, 08:58 AM   #13
Wash the place.
With a bulldozer?. It's a sad unit. I have been cutting down the heavy grease build up like in kitchen. I don't think the structure would hold up if sheetrock was replaced. It's in an area where most of these older places are leveled and built with new
Old 11-21-2017, 09:42 AM   #14
artinall's Avatar
That reminds me of that last place I did. Nicotine sagging heavily on the windows. The whole place sticky with that odd sweet smell. Mice corridors packed behind the pulled based cabs. But looked new almost when I was done.
Ever since I've had not too much of a desire for a sequel.
The Following User Says Thank You to artinall For This Useful Post:
Old 11-21-2017, 10:02 AM   #15
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
I avoid jobs where HO's are or were heavy smokers. The stench makes me gag.
kirkdc is offline
Old 11-21-2017, 10:17 AM   #16
VinylHanger's Avatar
Rewards Points: 8,200
My last big nicotine job, we had to wash the ceiling ten times to get it off. TSP substitute is your friend. Luckily, it was only the basement ceiling.
We also had to shoot the basement twice with Kilz. Two mist coats is better than one thick coat. Kilz can reactivate the nicotine, as well as other stains, if it is put on too thick.
VinylHanger is online now
Old 11-21-2017, 10:26 AM   #17
artinall's Avatar
Originally Posted by VinylHanger View Post
...Kilz can reactivate the nicotine, as well as other stains, if it is put on too thick.
That I did not know.
I stay away from washing flat/drywall ceilings.
What about Kilz odorless. Is it worth anything?
Old 11-21-2017, 10:38 AM   #18
tjbnwi's Avatar
Cleaner mixed in water. It's a by gone concept I guess.
Sometimes cleaning and prep is the best answer. You'll probably save time over fighting with a bad surface to work with.
I use Krud Kutter.
tjbnwi is offline
hdavis (11-22-2017)
Old 11-21-2017, 10:43 AM   #19
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 1,718
Is it better than TSP for nicotine?
SmallTownGuy is online now
Old 11-21-2017, 10:45 AM   #20
artinall's Avatar
I use Krud Kutter.
I like your ideas but what about the OSB - the nicotine is down in it, went through the carpet and pad and its been lifted (another chain smoker) - would you get the wood wet with cleaner? I've seen what wetness can do to OSB.
I'd hate to see the lungs.
Ipe sealing wayne3434 Decks & Fencing 1 07-24-2014 02:40 PM
Sealing Stamped Concrete Bill Butler Masonry 1 06-02-2013 04:51 PM
Sealing all sides of hardwood decking DeckPros Decks & Fencing 56 02-16-2013 01:27 PM
Sealing Metal Valley Section artinall Roofing 20 11-07-2012 12:18 PM
Sealing decks MAC2PAINTING Painting & Finish Work 2 10-21-2009 06:21 PM
