Satin/Eggshell Paint?
Old 01-26-2006, 07:55 AM   #1
SuperiorUnlimitedPainting
SuperiorPaintin's Avatar
Trade: Painting-Interior/Exterior,Drywall, special and texture finishes,pressure cleaning and water damages
Hey, Can you guys please help....
People are saying that you can't touch up satin or eggshell because it comes out a different tone, Is this true??? Please help!!!
SuperiorPaintin is offline
Old 01-26-2006, 08:47 AM   #2
Home Repair & Improvement
GEB7678's Avatar
Trade: Home Maintenece and Repair
Rewards Points: 75
Re: Satin/Eggshell Paint?
I've never had that experience, unless your dealing with a cheap paint. As long as the prep work is done, the surface is clean, and the method of application is the same then the finish should blend like it was never touched to begin with.
One call to fix it all
www.gebconstruction.com
GEB7678 is offline
Old 01-26-2006, 09:26 AM   #3
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Rewards Points: 1,000
I think what you're hearing about is a difference in sheen. Often times touching up walls with low sheen products can cause flashing, or a difference in the sheen level of the paint. Usually when I see this problem its because a patch wasn't primed and the hold out of the paint is different in that area causing a sheen difference. If that happens, re-prime with a good sealing primer and then touch up....all should be good then.
Weathered Wood Restoration LLC
Deck Staining & Restoration Jacksonville, FL
Pressure Washing Jacksonville, FL
AAPaint is offline
Old 01-26-2006, 10:12 AM   #4
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Rewards Points: 7,510
That is the key. method of application needs to be the same. I've had the best luck in matching sheen levels using a small lambswool or mohair roller, like this one.
ProWallGuy is offline
Old 01-26-2006, 03:19 PM   #5
Thanks! You guys are very helpful!!!
Old 01-26-2006, 05:37 PM   #6
GEB7678's Avatar
Rewards Points: 75
good point on the primer
GEB7678 is offline
Old 01-26-2006, 05:44 PM   #7
...jammin
slickshift's Avatar
Trade: Rock Disciple
Rewards Points: 2,000
The best help I can give to is:
Stop listening to those people (people who are saying that you can't touch up satin or eggshell)
Listen to these people (ContractorTalk)
Oh and I've never had a sheen/flashing problem touching up eggshell or satin
Unless it's going over a joint compound patch, in which case I spot prime first
...but again, that's not really a problem, just proper prep
slickshift is offline
Old 01-26-2006, 10:41 PM   #8
benjmo's Avatar
Trade: Painter/Ben Moore retailer
I had a customer today asking the same questions ..He bought a QT of eggshell to touch up a job he did last year,,Same paint same exact color ..He came back saying that the egshell I sold him was wrong.. that I sold him flat..even thought the can he had in his hand was eggshell..LOL After some questions ...He finally admitted he didn't primer before he painted.. I told him that was his problem..he didnt belive me and wanted to call Ben Moore to complian about the paint and wanted a refund for his quart.. I gave him the phone and dialed the number after a bit he hung up and went home .grumbling something about... i should have primered ...LOL
benjmo is offline
why is latex paint peeling?? Zeebo Painting & Finish Work 24 05-28-2009 06:59 AM
Short Review Of Aura Paint Riverside Paint Painting & Finish Work 30 03-07-2009 07:50 PM
blistering paint GWHRsuperhero Painting & Finish Work 9 03-06-2007 07:43 PM
paint coming off the ceiling lornmastro Painting & Finish Work 6 06-02-2006 12:31 PM
Dealing with flaking paint....help!!!! Zeebo Painting & Finish Work 9 11-28-2005 10:03 PM
