Sanding Walls With 80 Grit Paper On Orbital Questions
Old 12-17-2008, 09:44 PM   #1
plazaman's Avatar
Guys I recently started a fairly large rehab project where the walls are in bad condition. The budget doesnt allow for skimcoat nor new drywall so spackling is the only alternative. These walls have layers of paint, bumps, previous patches, etc.. In the past, we usually give it a quick scrape , spackle bad spots, sand, prime, and paint, comes out ok.
I Have the PC sanding system in my garage, I thought if i could sand these walls down smooth, i could achieve better results.
I plan on having my guys sand the entire walls with the sander with 80 grit paper. Then come back, do my spackling, sanding, and painting. My biggest concern is that I dont want swirl marks on my finished product.
I plan to prime with Sherwin Williams High Hide Primer, and paint with 2 coats Kualiquote Eggshell.
plazaman is offline
Old 12-17-2008, 10:07 PM   #2
Sean
SLSTech's Avatar
Re: Sanding Walls With 80 Grit Paper On Orbital Questions
Buy a crap load of paper - skim coat maybe cheaper
Just my .02
SLSTech is online now
Old 12-17-2008, 10:10 PM   #3
Workaholic's Avatar
Trade: Painting Contractor
If you are worried about swirls then start out with a higher grit. 120 is probably to weak but 100 might be just right. Then again the 80 might be necessary. Hard to say without seeing.
Sean
Workaholic is offline
Old 12-18-2008, 09:30 AM   #4
boman47k's Avatar
I have the same situation here in a smal foyer. It is going to be either a fine skim coat and a fine sanding or a rough sanding with pole or vibrating sander going to a fine sanding.
boman47k is offline
Old 12-18-2008, 10:04 AM   #5
Burby's Avatar
Trade: Remodel / repairs / Certified Mold inspector, Remediator
Send a message via AIM to Burby
On my porter cable drywall sander I use both 80 & or 100 grit sanding pads.
Painted walls I use 80 & it works fine, then again the finish is flat, eggshell is a bit different and is where I would use the 100 grit.
Just let them start with light pressure and go from there. You will see & know if you need a finer grit. Sanding the complete walls will take time so the faster the better as long as the deisred results are met.
Depending on the wall condition, (not seeing or being there) I would start with 80, see how it looks, if needed go over with the 100 and stay with the 100. The pressure applied & what is presently on the walls will make a difference.
Power sander vs hand sanding = priceless
Proud to help make a house your Home
Never judge another by one's own intelligence
Burby is offline
Old 12-19-2008, 04:01 PM   #6
boman47k's Avatar
Is 100 grit the highest you go before painting?
boman47k is offline
Smooth Finish Heavy Textured Walls riccog Drywall 5 03-10-2009 11:57 AM
Cork Flooring Questions.... SBI Flooring 3 12-12-2008 04:18 PM
sanding sealer on windows ? sprayer48 Painting & Finish Work 8 10-24-2008 12:10 AM
Drywall Sanding Sponges? Abrasive Dan Drywall 6 06-14-2007 05:35 PM
Type of Paper Under Hardwood CharlieDaw Flooring 2 04-12-2007 10:43 PM
