Sanding Sealer On Windows ?
Old 10-21-2008, 10:34 PM   #1
sprayer48
sprayer48's Avatar
Trade: General Contractor, Remodeling.
Hey guys,
Looking to stain interior double hung windows for new construction.
I've always used wood conditioner, oil stain, two coats of an oil poly satin finish.
Some other painter at the sw store told me he uses sanding sealer then a coat of poly on top of that. Or even two coats of sanding sealer.
I thought you couldnt put poly ontop of sanding sealer ( all oil ).
Any suggestions ?
mark
I know its two thirsty or beer thirty somewhere !
sprayer48 is offline
Old 10-21-2008, 10:44 PM   #2
harness's Avatar
Trade: painter
Re: Sanding Sealer On Windows ?
i do new const. i stain then spray pre cat laquer this way their is no need for a sand and seal you spray pre cat wait 45 min or untill dry sand ,dust, then finish with 1 or 2 more coats use airless and a fine finish tip 311 or 313
harness is offline
Old 10-22-2008, 08:54 PM   #3
A bit abrasive.
WisePainter's Avatar
Originally Posted by sprayer48 View Post
Hey guys,
Any suggestions ?
mark
For new windows:
Stain
Sanding sealer
Sand the raised grain
2 lacquer coats
Done
More than 2 coats of lacquer will cause "alligatoring" when the temperature fluctuates.
That is my technique.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 10-22-2008, 09:34 PM   #4
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
Originally Posted by WisePainter View Post
For new windows:
Stain
Sanding sealer
2 lacquer coats
Done
Ever have a problem with the laquer peeling if it was exposed to moisture?
I like laquer because it dries fast and is pretty easy to spray, but I have had trouble with it in bathrooms and around windows sometimes if there was heavy moisture. I have used Spar varnish before in bathrooms and places that I would guess to be pretty moist, just wondered if you ever had any issues like that.
ModernStyle is offline
Old 10-22-2008, 10:23 PM   #5
sprayer48
sprayer48's Avatar
thanks harness.. but it seems that there would be a lot of taping off for double hung windows.
mark
Old 10-22-2008, 10:31 PM   #6
sprayer48
sprayer48's Avatar
For new windows:
Stain
Sanding sealer
2 lacquer coats
Done
hey almighty wise painter, thanks for the technique. Is the sanding sealer a lacquer sanding sealer ? also doesn't the lacquer gum up the brush.
I used to spray lacquer , but would not think of brushing it because it used to dry so quick. unless you cut it with something.
let me know ?... I need to get in stain, two coats finish and out in two days.
mark
Old 10-23-2008, 09:44 AM   #7
A bit abrasive.
mark
Flattery will get you everywhere!
But I digress.
Yes the sanding sealer is a lacquer sanding sealer. Do not apply it too heavily because you really only want to raise the wood grain in order to knock it down. I had to use it a few times to get the hang of it because when I spray I am usually applying a top coat, not so with the sealer.
Brush?
No brushy.
Spray the sealer, flush the pump (not as much as you would for storage) then run your lacquer.
Sealer dries as quickly lacquer so the turn around time is as fast as you can run Lacquer through the pump.
With a crew of 2 (and long days) you should be able to complete the job in two days.
Unless you have a large number of windows...add crew accordingly.
I had 38 windows in the Administrative offices of a Fire Department. we started at 3 p.m. building tents to contain the over spray.
Stained, sealed/sanded, and started shooting Lacquer at 3 a.m.
Out by 7 a.m.
That was with 2 guys.
Two very tired and buzzed guys.
Old 10-23-2008, 06:45 PM   #8
harness's Avatar
Trade: painter
the maskeing is worth the time saved and the finish product in my experince
harness is offline
Old 10-24-2008, 12:10 AM   #9
A bit abrasive.
The Devil is in the details.
I hate masking for 5 hours only to spray for 1 hour.
It is hard to stretch the joyous hour that I am spraying.
Bliss truly is a short lived thing.
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Windows - Blind Inside? MHMConstruction Windows, Siding and Doors 12 02-20-2010 01:50 PM
Sanding Sealer plumbco Painting & Finish Work 12 09-01-2008 03:25 AM
Windows - Blind Inside? MHMConstruction Remodeling 9 10-06-2007 04:53 PM
Sanding sealer help birdog Specialty Coatings 5 07-11-2007 09:05 PM
