Sanding Between Coats
Old 09-09-2006, 01:05 AM   #1
Painting & Restoration
GoodPainter's Avatar
Trade: Painting Contractor
Just wondering what everyone does as far as sanding between coats for semigloss?
I would always sand in between coats but is it really nessesary? Some people say no but some say yes, doing a large area could use alot time to sand between.
Right now im using BM semi on Exterior and for windows i sand between
But for ceilings and trim and others, is it overkill waste of timeor doesnt matter?
To much to ask,
Robert
Robert Good
It's Your Life-Make Fun Of It!
http://www.robertgoodpainting.com
GoodPainter is offline
Old 09-09-2006, 02:27 AM   #2
Don
donb1959's Avatar
Trade: Paint Contractor
Re: Sanding Between Coats
On trim, I sand the trim first, then dust it, then paint it, I don't sand between coats.
I fish therefore I am
http://www.shimmerz.biz
donb1959 is offline
Old 09-09-2006, 07:01 AM   #3
painterman's Avatar
Trade: Historic Restorations
On trim I sand first then sand again before second coating. I never sand a ceiling. On walls I will sand the original finish and the between coats.I always use a 5 inch orbital palm sander to do this.This does two things for me,knocks down the surface evenly and puts me up close and personal with the wall. That way I can easily see any defects in the wall .This method my take a little longer but the results are great...not to mention the HO wont believe his eyes when they see you palm sanding the walls.
Stan
painterman is offline
Old 09-10-2006, 02:26 PM   #4
Woz the Painter's Avatar
On higher end work all walls should be sanded between coats,whether primer or finish coats to remove pimples small roller splatter, etc. The method I use is a sanding pole or sanding head attached to an extension pole, using 100 or 120 grit paper...
Woz the Painter is offline
Old 09-10-2006, 09:58 PM   #5
George Z's Avatar
We do the same.
George Z is offline
Old 09-10-2006, 10:48 PM   #6
Pro Painter
AAPaint's Avatar
Yup, I've been pole sanding a long dang time.....I need to get one of those drywall doo-hickeys with the round head that doesn't skip, flip over, and tear up the wall, or just come unscrewed while you're working with it.....
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 09-10-2006, 10:57 PM   #7
Painting Contractor
DelW's Avatar
And I thought that only happened to me..
If love is blind, why do they make Lingerie?
DelW is offline
Old 09-11-2006, 01:55 AM   #8
Moderator
Double-A's Avatar
My Pol sander. He never comes unscrewed, but he has gotten wound up a few times.
New York Times, July 20, 2006
Double-A is offline
Old 09-11-2006, 04:52 PM   #9
...jammin
slickshift's Avatar
Trade: Rock Disciple
Don't think I've done semi- on a ceiling...
Interior trim I sand in between coats
Usually not on exterior, but that can depend...
Signature Quote
slickshift is offline
Old 09-12-2006, 12:09 AM   #10
My custom title
Brushslingers's Avatar
Depends on the texture here... almost everything is either hardcoat or orange peel in Tally, so no walls but yes on trim. Always after prime when removing paper.
Benn
Originally Posted by Brian
Brushslingers is offline
Post-a-Quote donb1959 Painting & Finish Work 131 04-21-2009 11:09 PM
Drywall Sanding Sponges? Abrasive Dan Drywall 6 06-14-2007 05:35 PM
2 coats or one coat saucedo80 Painting & Finish Work 38 03-02-2007 08:23 PM
Am I outrageous? AAPaint Painting & Finish Work 39 02-16-2007 12:58 AM
