Old 08-22-2007, 05:06 PM   #1
rusty metal pitched roof
Anybody have experience with 'Rustnox' (sp)for rust on roofs?
Local paint dealer claims you can use it as an effective rust blocker first coat then topcoat finish. $22 gal (~400sq ft) and dries silver which is what is wanted.
An option I guess is to use 'Reformer' that says it will convert rust back to its iron/steel makeup. Though cost runs about $65 gal (~300sq ft) and dries black.
One problem is that the boxed gutters are caving and there is no real lower access if needed. A roof hook clamped on the ladder is out. So I'm figuring 50' articulating boom. At rental prices of ~$270/day plus pickup/delivery, insurance. When all is said it is over $300 day just for access. So sanding or wire brushing isn't much of an alternative.
Which is why the emphasis on the material.
Viewed from the ground, there is a near complete rust layer and it is second story (with one side obstructed at ground level by the 1st story porch.) 45 degree pitch. roughly 500 sq ft surface area
Anyway, if anyone has experience with these paints would like to hear.
Do they really seal/convert rust and not allow for bleed thru?
artinall is offline   Reply With Quote
Old 08-22-2007, 06:10 PM   #2
jackrabbit5's Avatar
Trade: Paperhanger/painting contractor
We did a rusty metal roof 3 years ago. We did zero prep, no washing, no sanding, no wire brushing, no nothing. Just 2 brushed on coats of Diamond Vogels V-cote 200 acrylic latex maintenance primer/finish. It looks as good today as it did the day we finished. Here are before and after pics.
jackrabbit5 is offline   Reply With Quote
Old 08-23-2007, 02:01 AM   #3
nice, jackrabbit5
would never guess acrylic pulling this off.
who carries this - any of the big name paint outlets?
btw - what's that guy up there doing?
Old 08-23-2007, 07:48 AM   #4
Originally Posted by artinall View Post
nice, jackrabbit5
Diamond Vogel is a regional paint company based in Orange City, IA. They also make the Old Masters line of wood finishes. Unless you live in the midwest, you're prabably out of luck with finding it, but I'm sure other companys have rust inhibiting latex primer/finishes.
The guy on the roof is my brother and he's positioning a ladder.
Stacy
S B Bolson & Sons
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 12:30 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Metal Roof tied to a Shingle Roof? JackOfAllTrades Roofing 2 11-15-2005 12:00 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
