Rust Problem
Old 10-04-2007, 11:04 AM   #1
lpp's Avatar
Trade: Project Management
Send a message via Yahoo to lpp
Rust Problem
Hey guys. We are painting the steel beams on an RV port that was previously painted about a year ago. The primer used was SW chem-kromik (which is an industrial marine primer) and was topcoated with an acrylic latex paint.
The problem our client is having is that rust spots are now bleeding through the topcoat. We have looked into using a rust neutralizer, but that can't be applied over the existing paint. We have found two products that sound like they might work, but I have never heard of them and hate to spend so much on an expensive product that might not be all they claim to be. Those two products are called The Rust Doctor and Rust Bullet. Anyone ever have any experience with either of those products?
Our SW rep said to use the chem-kromik again by applying 3 additional coats and then topcoating with DTM 2 coats. I have my reservations about that simply because it didn't do the job the first time. That is an extremely difficult product to work with (like painting with glue) and if it doesn't work the labor wasted would be outrageous.
I can't seem to get ahold of the industrial/marine division of SW to get their recommendations so I figured I'd tap the knowledge of you guys. Any ideas?
lpp is offline
Old 10-04-2007, 05:14 PM   #2
Painting Contractor
JMGP's Avatar
Re: Rust Problem
Check out the Devoe Coatings.. Bar-Rust system
www.devoecoatings.com
JMGP is offline
Ventilation problem with an indoor pool frostbitten1 Roofing 10 05-27-2009 09:16 PM
Well problem paintr56 Plumbing 10 02-09-2007 09:20 AM
Strange Fly Problem johnnymac Plumbing 4 09-07-2006 02:30 PM
Electrical problem? Brian Electrical 5 12-27-2005 11:16 AM
Rust coming thru pex lines? housedocs Plumbing 12 11-06-2005 08:57 PM
