Round 2- What Do You Other Pros Use To Putty Nail Holes Prior To Painting?
Old 04-22-2009, 09:09 AM   #21
StefanC's Avatar
Trade: Prep Nazi
Re: Round 2- What Do You Other Pros Use To Putty Nail Holes Prior To Painting?
We used to use Crawfords, but after spraying the trim we'd still see some dimples here and there.
www.sccustompainting.com
StefanC is offline
Old 04-22-2009, 09:48 AM   #22
A bit abrasive.
WisePainter's Avatar
Crawford's is a product that takes some getting used to, adding white to it helps.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 04-22-2009, 10:39 AM   #23
Trailer park boy
shanekw1's Avatar
I like Fast'N Final, it swells a tad
when it dries, and just a swipe or
two and it's sanded.
Fast'N'Final as well, or One Time.
shanekw1 is online now
Old 04-22-2009, 01:21 PM   #24
Organic Painter
Mr. Mike's Avatar
Trade: Painting Contractor
Originally Posted by Mr. Mike
I always give two prices for this one a High price for Elmers Wood putty and one cheaper price for the painters putty method.
Oops, I use a wood filler and I think it is an elmers product all I know is it has to be sanded, and my cheap price is for putty. Putty shows and the wood filler does not.
Mr. Mike is offline
Old 04-22-2009, 02:36 PM   #25
boman47k's Avatar
Originally Posted by Mellison View Post
Elmers Wood putty.
Dries fast, sands easy, no shrinky.
Ditto.
boman47k is online now
Old 04-22-2009, 05:31 PM   #26
vandy
vandyandsons's Avatar
Trade: painting, decorating, wallcovering
Originally Posted by Frankawitz View Post
Painters Putty that's what it was made for, glazing leaves oil spots and takes longer to dry.
work some powder durabond into that glazing putty ball...no more oil spots. i used straight glazing putty by itself once and every hole burned right through.
i find that painters putty shrinks too much vs. glazing putty that doesn't shrink at all, and when flopped around in some durabond powder, won't bleed through.
vandyandsons is offline
Old 04-23-2009, 10:58 PM   #27
capital city's Avatar
Trade: painting
I used the glazing and powder mix today. I was using straight glazing before. Makes sense and appeared to work, will see when I go back and paint tomorrow. Thanks for the tip
capital city is offline
Old 04-24-2009, 05:21 PM   #28
vandy
the key is to periodically flop that putty ball in the powder to keep it dry, yet workable. it sure is nice not having to sand out the trim.
let me know how it worked.
Old 04-26-2009, 06:43 PM   #29
katoman's Avatar
Trade: carpenter
I'm not a painter, but always have one following my work. I thought you were supposed to prime first so the nail hole/head is primed, and then fill the hole. Comments?
katoman is offline
Old 06-21-2009, 08:33 AM   #30
Work of Art Painting
BryanG's Avatar
In track houses we use the glazing compound mixed with a little bit of Durabond to make it easier to work with. I've done alot of high end residential, and we do the glazing compound for the first coat and then we come back and put woodfiller over top of the compound to prevent shrinking! The problem with the glazing compound is that it does shrink and you will sometimes get "fish eyes" in your trim work!
BryanG is offline
Old 06-21-2009, 01:51 PM   #31
Workaholic's Avatar
Crawfords
Sean
Workaholic is offline
Old 06-21-2009, 02:38 PM   #32
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Wrigleys, flavors lasts and works with both oil and latex paints.
silvertree is offline
Old 06-21-2009, 08:21 PM   #33
CTDiesel's Avatar
Trade: Paint & Drywall
Never had any problems with One Time.
CTDiesel is offline
Old 06-21-2009, 09:25 PM   #34
Crock's Avatar
Trade: Fan of Bodger
Originally Posted by rbsremodeling View Post
a wet sponge. It shrinks the holes around the nail and it disappears
and throw some sawdust at it.
Crock is offline
Old 06-22-2009, 12:05 AM   #35
jmda
jmda's Avatar
Trade: Painter
I usually use glazing mixed with some whiting or quick set powder
But also use MH Ready Patch, which I sometimes use to fill shallow dents and scratches in trim.
jmda is offline
Old 06-26-2009, 01:48 PM   #36
Youngster
Cache's Avatar
Trade: Builder / Consultant / Designer
Originally Posted by We Fix Houses View Post
Most of my work is remodeling / repair and I paint most of it. The customer is going to look at the work pretty closely. I use Durhams Rock Hard Wood Putty. Mixes easy and dries in 45 min. Touch it with some #80 or #100, done. No dimples.
Additions, larger work I've used latex painters putty in a ball. But not doing those now. I go into McMansions and see dimples all over the trim. I heard about Crawford's on these forums and would use it for the next med sized job. I can get it at SW.
Not a painter, but my painter is.
Anyway, if you do anything high end I would stay away from Crawfords if you don't have time to get used to it. MANY nail holes left visible after using it, even with a decent amount of practice. Your first few jobs you'll almost certainly end up refilling a ton of holes.
I guess some people don't mind a bit of a dimple showing through on every hole, but for my houses, it is completely unacceptable. For this my guy uses fast n final.
Cache is offline
Old 06-26-2009, 01:50 PM   #37
Youngster
Cache's Avatar
Incredibly correct post.
Cache is offline
Old 06-26-2009, 03:31 PM   #38
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
I'm with RBS, and silvertree, thoes are the old school methods we used to use, but now we gradutated it one step further, we just shoot our nails perfectly flat with the wood. No filler needed. Works real gooder.
Mike Finley is offline
Old 06-26-2009, 03:58 PM   #39
RickS's Avatar
Trade: Carpentry/Handyman
In my experience, that's easier said than done. But, if it works for you, then kudos!
RickS is offline
The Following User Says Thank You to RickS For This Useful Post:
Crock (06-26-2009)
Old 06-26-2009, 04:11 PM   #40
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Nail holes? What nail holes? Blind fastening is the way to go.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
interior trim painting sprayer48 Painting & Finish Work 14 08-06-2011 01:47 PM
painting over enamel stripes mfrancis Painting & Finish Work 2 11-17-2008 10:30 AM
Painting Crew in Ohio looking for winter work corky Help Wanted or Looking For Work 0 11-16-2008 10:46 PM
CHAUK or Wood Putty? Two Brothers Finish Carpentry 20 03-04-2008 05:10 PM
Looking for the absolute best nail hole filler Dorman Painting Painting & Finish Work 19 10-28-2007 02:23 PM
