Trade: Painter
Roller Marks
I am so stressed!!
We have just recently finished painting a house and we were very pleased on how it turned out...looks great....but the customer is complaining about roller marks...this is a new one for us as we take great pride in our work...she said when the sun is shining it is really bad and now wants them repainted...this is not new construction, it is a repaint...the walls are far from perfect can see taping seams, ect..14' high and 18' long, sand in color and milk chocolate feature wall, eggshell finish, general paint...this house is full of direct sunlight...my questions are; How to deal with this customer? How to reroll the walls and not have any roller marks? Thanks to all for any input!!! |
#2 | |
...jammin
Trade: Rock Disciple
Re: Roller Marks
1) Exactly what paint did you use?
2) Exactly what roller sleeves did you use?
Signature Quote Quote:
Sharp Improvements
Re: Roller Marks
I have done a few paints and I usually inspect the walls for bad tape jobs,holes,nubs, ect. I will point them out before painting and ask the customer if they want to pay to them cleaned up. If not, the wall condition is up to them. As far as painting, I usually use high quality paint(BM) and tends to blend better without streaks afterwards. Some times they go to H.D. and Behr and it does not cover as well. I usually persuade them to find the same color at BM and it is better for everyone.
Did you use a good paint? What kind? Did you go over the condition of the walls with the customer? Hope it all works out. |
Trade: Painter
Re: Roller Marks
the paint is breeze by gp and a 10m purdy
Trade: Painter
Re: Roller Marks
this house is through a designer who has been good to us...
we washed and pole sanded primed pole sanded 1st coat gp breeze pole sanded finish coat general paint is designers choice has been for 28years..suck ass!!imo if i repaint should i use a 18" roller? i don't believe the whole house will be a repaint..cross our fingers! so lets say the livingroom, lots of sunshine and her master bedroom also lots of sunshine, could i maybe switch paint brands just for the 2 rooms? |
#6 | ||
...jammin
Re: Roller Marks
Well, I can tell you the three biggest reasons for roller marks are:
1) Poor (or at least sub-par) quality paint 2) Poor (or at least sub-par) quality sleeves 3) Poor (or at least sub-par) quality technique Usually if two out of three are top notch there's no problems I don't know how long you've been painting, lets assume your technique is at least OK Purdy makes different quality products, but even their contractor grade is horrible GP...I have no idea, never heard of it yeah...good for them...they are not doing the application Have you used GP before? How would you rate it really? ...crappy, so-so, not bad, good...? Quote:
...unless it's your technique, I think I'd suggest ditching the paint also...unless you say it's an alright paint
#7 | |
Sharp Improvements
Re: Roller MarksQuote:
Sharp Improvements
Re: Roller Marks
Slickshift...da_n you. You seem to be a step ahead me on this thread.
Trade: Painter
Re: Roller Marks
i'm from alberta canada, and sometimes i forget most of you guys are from the states so products are different....general paint is a step up from lowes, home depot...i'm not so familar with the product as i have only used it a dozen times...but i can hoestly say i hate it....strong smell of amonia, impossible to touch up, have to repaint from clean breakoffs, and eggshell is more like a satin/semi gloss...if i have to repaint i we be demanding higher end products and will use higher end sleeves.
Can you please recommend a good paint...we have sw, bm and ici? Should i mix in a conditioner? What kind? From where? Should i let it cure for 30 days before repainting? What is the best kind of sleeve you recommend? As for wall repair we did more then usual, we don't bring out our 10inch for a repaint; they had a taper there redoing the cieling and a half a dozen new seems where new walls were built so if they wanted there walls to be perfect they had the man there but no! |
Trade: Painter
Re: Roller Marks
Thanks for the link but it is under construction...could you briefly tell me what i would find on that link?
Oh by the way have i mentioned that we are starting a new high end house for them this monday, highest bid i have put in with them, flat painted cielings and lots of south and west windows; the kicker i have to use gp, this scares me now, we are spraying this one do you think that will be a difference maybe? |
Sharp Improvements
Re: Roller Marks
I would really try to persuade them to use a better paint. It will not be that much more for the quality you will get. A better paint will show. I use high end BM and my customers always notice how luxurious it looks. I think the designer needs a realty check when it comes to paint. My great grandfather told my mother who told me...buying cheap is expensive. I think this pertains to your designers' choices and now you are doing more work than necessary.
I am not sure on the spray situation. i have never sprayed, so I am no expert on that. I always roll and think it covers better from what I see from the spray before I got there. |
Trade: Interior Decorator/Painter
Re: Roller Marks
I'm from Canada too.....never heard of that GP paint. Maybe it's only in Alberta? I'm a decorator and have done most of my own painting to date and would never ever spec a low grade paint. I have also done work for other decorators and designers and they have always always deferred to me in paint choice. Colour, of course, was their's but brand was all about me. As professionals you should both be respecting each others strengths. Even though she has recommended this paint you are the fall to guy when something goes wrong. Stick up for yourself in the future.
I would never recommend that you spot touch the walls with a better quality paint. It will make a difference and the difference will show. On high light walls I would use flat especially when the walls are in the shape you say they're in. If it were me I would take partial responsibility having them pay for the paint and me painting for free......unless I had told them before the job started that I wasn't responsible for the finished product do to the quality of paint. With your new job on Monday.....why is a high-end home using a poor quality paint? Again, your reputation is on the line so stick up for yourself. State your concerns in your contract before using this paint. Good luck Mary |
Allrounder Home Services
Trade: Painting, Remodeling, Handyman
Re: Roller Marks
Even on a huge job, the price difference between cheap paint and high quality paint is usually small when you actually look at the numbers.
A good paint store should be happy to match the colors that the designer specs into a paint that you are confident in. |
Trade: painter
Re: Roller Marks
I would rec. using either bm's aura or sw duration, use a good quality 3/8 nap roller cover and fix any problem area's on wall first...I would use aura matte finish for light color and there eggshell for the dark if they still want a sheen, if not use the matte also...
Trade: Painting Contractor
Re: Roller Marks
General Paint is a major brand.
Second largest in Canada. They are now part of the Comex Group Flikka, they were the biggest in the West, they are all over Toronto now (bought the IDEAL brand). Their top line is superior to SICO's or PARA's. They have all lines from industrial to 4 lines of differnt quality. The Breeze line is their second line and superior to many companie's first. So, the quality of paint is not an issue. We used a lot of that product with great success. Using a 10 ml Purdy over possibly a porous surface and large walls could be an issue.
Toronto Painters Commercial Painting Commercial Painting Toronto Toronto Office Painters Painting Toronto Blog Last edited by George Z; 03-06-2008 at 09:28 AM. |
Trade: Finsh Carpenter, Taper, Painter, General contracting
Re: Roller Marks
Try back rolling
| One more airless power roller question | steve-in-kville | Painting & Finish Work | 5 | 09-19-2008 11:09 PM |
| Trouble with roller lines using 18" wooster | KJLinden2002 | Painting & Finish Work | 16 | 01-01-2008 09:55 AM |
| Titan power roller... My first impressions | steve-in-kville | Painting & Finish Work | 0 | 06-17-2007 11:22 AM |
| Roller marks in dark paint. | cutnroller | Painting & Finish Work | 10 | 08-03-2006 11:09 PM |
| Just a roller! | yikkle | Painting & Finish Work | 8 | 07-21-2006 06:20 AM |
