Replacement Inlet Hose For Graco Sprayer?
Old 11-08-2017, 09:07 PM   #1
RMDailey's Avatar
Rewards Points: 266
The suction/inlet hose on my paint sprayer is shot. No one local has one instock and they're expensive only. It looks like a section of waterhose to me. Anyone see a problem using a section of old garden hose instead?
Buy the time I order one have have it rushed to be here by monday I'd be out $35... I have an old hose on hand
RMDailey is offline
Old 11-08-2017, 09:37 PM   #2
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
Re: Replacement Inlet Hose For Graco Sprayer?
You might want a stiffer hose that won't implode, like a radiator hose.
www.callbathdoctor.com
Driftweed is offline
Old 11-08-2017, 09:40 PM   #3
tjbnwi's Avatar
Rewards Points: 1,178
Which model sprayer? Is it a stand airless, hand held, HVLP?
If you don't know the number a picture of the unit will do.
tjbnwi is online now
Old 11-08-2017, 09:45 PM   #4
RMDailey's Avatar
Rewards Points: 266
It's a Graco Magnum Pro LTS 17 (Pro 7x).
Driftwood I like the radiator hose idea. The problem i'm having is it the current hose developed a kink and it collapses.
I think I'm going to try it. Worst case I have to go rent a sprayer and order the parts. I only do painting occasionally
RMDailey is offline
Old 11-08-2017, 09:57 PM   #5
tjbnwi's Avatar
Go to a hardware store, they should have 3/4" clear reinforced hose.
Garden hose repair fitting and hose clamp for the screen fitting.
Advantage to the clear is no worries about rubber contaminants.
Unger.const (11-09-2017)
Old 11-09-2017, 12:07 AM   #6
Unger.const's Avatar
Rewards Points: 2,424
Melted one of mine the other day. Spray shop gave me a black hose with end (like garden hose repair kit for an end). Which was like a radiator hose. Just used the same rock screen.
Like said above of hardware store had the stiff clear with reinforce thread in it. And a male hose end.
Unger.const is offline
Old 11-09-2017, 12:20 AM   #7
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,304
This happened to one of my sprayers years ago, a guy I know put a piece of stiff rubber and some duct ties around the kink. Kept it from kinking and held up for years after.
SuperiorHIP is offline
Old 11-09-2017, 07:17 PM   #8
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 6,794
You may have to take your losses. The replacement part would probably be a third of the price unit, if Graco even cared to make it.
Caslon is offline
gas powered sprayer and winter use Ohio painter Painting & Finish Work 5 12-20-2016 07:20 PM
Quick Plank Replacement Tip PrecisionFloors Flooring 5 05-23-2013 08:20 PM
Airless sprayer hoses VinylHanger Tools & Equipment 6 07-03-2012 02:20 AM
Airless sprayer operation and tip question Ohio painter Painting & Finish Work 2 06-07-2012 07:59 PM
Finish Sprayer mattsk8 Tools & Equipment 27 03-09-2012 03:21 PM
