Repair & Paint A Rusty Metal Door
Old 10-18-2017, 09:34 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 974
Usually I sand off with emery cloth and then either red oxide or rust convertor on top.
But here we're talkin, a deep scale situation. Seems to the touch, it can easily punch thru in spots. This is an exit door with high exposure (deck balcony) that has a separate, fixed pane attached, both largely glass.
These metal skin doors -- I'm trying to convince the owner into a kickplate at the base of the door where it's at. Won't go for it.
If the skin totally pokes open, can a patch even hold?
artinall is offline
Old 10-18-2017, 09:50 PM   #2
rustyjames's Avatar
Rewards Points: 1,464
Re: Repair & Paint A Rusty Metal Door
I would have to think that any patching isn't going to hold up, especially on a door. You'd need X-ray vision to know where it'll break through after you patch the obvious.
rustyjames is offline
Old 10-18-2017, 10:18 PM   #3
tjbnwi's Avatar
Rewards Points: 1,742
Lead it.
tjbnwi is online now
Old 10-18-2017, 10:24 PM   #4
artinall's Avatar
Rewards Points: 974
Originally Posted by tjbnwi View Post
Lead it.
Come again?
artinall is offline
Old 10-18-2017, 11:02 PM   #5
Workingmanvan's Avatar
Trade: Carpenter-Renovations/Repairs
Rewards Points: 272
My usual solution is to tell the homeowner they need a new door, and then proceed to put one in.. for some reason if that wasn't an option.. I dunno, I've never tried to repair a metal door that has rust right through.., get rid of the rust and use bondo? sand and paint..
Workingmanvan is online now
Old 10-18-2017, 11:17 PM   #6
tjbnwi's Avatar
Originally Posted by artinall View Post
Come again?
Body soldier. Make sure you clean well, acid treat.
Old 10-19-2017, 07:45 AM   #7
This space for lease
RangoWA's Avatar
Trade: Tool jocky
Rewards Points: 3,172
A kickplate would just be a bandaid temporary solution. It's either that or a new door. How is it your problem?
RangoWA is offline
Old 10-19-2017, 09:36 AM   #8
Fishindude's Avatar
Trade: Industrial
Rewards Points: 242
You just need to tell them that the door is shot and should be replaced. Tell them you will clean it up and paint it one more time, but can't guarantee how long it will hold up. You can probably buy them a couple more years of use, so not all bad.
Fishindude is offline
Old 10-19-2017, 07:15 PM   #9
artinall's Avatar
Rewards Points: 974
I happen to live there.
artinall is offline
Old 10-19-2017, 07:49 PM   #10
RangoWA's Avatar
Trade: Tool jocky
This threw me off...
"I'm trying to convince the owner into a kickplate at the base of the door where it's at."
Answer is the same though, a new door or what is likely to be a temporary solution until then.
RangoWA is offline
The Following User Says Thank You to RangoWA For This Useful Post:
artinall (10-19-2017)
Old 10-19-2017, 07:56 PM   #11
artinall's Avatar
Rewards Points: 974
I live with the owner, and we both looked at the door when he bought the house last spring.
By an oddball coincidence, the house I currently have a contract to work on has (2) rusty doors, but the rust is not as severe... I seem to attract them, or they me.
artinall is offline
Old 10-23-2017, 07:45 PM   #12
DiaperRiot's Avatar
Trade: Painting, Landscaping, & Fence Installation
Rewards Points: 148
paint can only do so much. time to pony up and buy a new door.
DiaperRiot is offline
Old 10-23-2017, 09:48 PM   #13
artinall's Avatar
Rewards Points: 974
The door is obviously on borrowed time. Decided to red oxide and bondo.
Which might hold for a couple years since I was aggressive sanding and digging the rust out.
Wish a new door could go in but that's just now happening, beyond me.
That's a bygone concern for now -- with a rusty door can come what? A rotted outer lower jamb leg. I thought this was covered when I made the post, but the epoxy patch I put in afterward isn't curing. This is a problem, given the lower temps and rain arriving ... calling abatron, their patch when it ages in the pail takes longer to cure. How was I supposed to know, I don't think it's stated anywhere? The jamb is sealed from the rain but that's temporary. If it gets wet its all over and I can't put a dryer on it. Looks like this might be a late spring project
artinall is offline
Old 10-27-2017, 01:43 AM   #14
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 6,794
You are asking for advice on rust that never sleeps on a door that your owner is too stupid to replace, on which you will try and uselessly repair and hope it lasts a year, which the owner will find you to blame if it doesn't. How much sympathy and advice here do you deserve?
Caslon is offline
Old 10-27-2017, 01:48 AM   #15
Caslon's Avatar
If you can't persuade/convince him to replace the door...then...???
Secure a cheap metal sheet over the rust and paint it. Rust never sleeps. That should do it. Right? We're not talking freaking car body work, right?
Caslon is offline
Old 10-27-2017, 07:38 AM   #16
artinall's Avatar
Rewards Points: 974
You might want to to take it easy, the owner has advanced dementia, and is without the needed funds...
btw I guess some of us post here for different reasons. Myself, I post both as an O.P and responding to others in the hopes that the exchange of ideas can lead to an improved synthesis for everyone. Rather than being about positioning, or influence.
To the extent that you tried to help, appreciate it.
As a 2nd btw, I used to paint in CA.
artinall is offline
Old 10-27-2017, 07:53 AM   #17
RangoWA's Avatar
Trade: Tool jocky
The owner has no money and isn't capable of making a sound decision anyway? The story keeps getting more and more involved. You were saying you were trying to convince him of doing this and that and he has advanced dementia? You should be talking to his legal guardian. Something isn't right here.
RangoWA is offline
MarkJames (11-03-2017)
Old 10-27-2017, 08:06 AM   #18
artinall's Avatar
Rewards Points: 974
"something isn't right here?" You wouldn't believe some of the customers I've had, including psychologists, physicists, and others, and some of the ways they try and carry out things, to their own intent. The psychologist being especially notable for trying to work the game in their own favor, even beyond what is morally or ethically right. The lying, their deceit, and willingness to collude can be among the worst.
Some people with dementia like the one mentioned aren't willing to give up control to a guardian. And yes, this does present a problem I can tell you that. But rather than go into this level of detail, I was trying to keep it simple and stick to the door itself... although someone sniffed the scent.
btw - I'm not getting referrals from the guys in white coats, though it may seem that way.
This project is on hold now until next spring, at the earliest.
artinall is offline
Old 10-27-2017, 08:19 AM   #19
RangoWA's Avatar
Trade: Tool jocky
"something isn't right here?" You wouldn't believe some of the customers I've had, including psychologists, physicists, and others, and some of the ways they try and carry out things, to their own intent. The psychologist being especially notable for trying to work the game in their own favor, even beyond what is morally or ethically right and wrong. The lying.
Some people with dementia like this one aren't willing to give up control to a guardian. And yes, this does present a problem I can tell you that. But rather than go into this level of detail, I was trying to keep it simple and stick to the door itself... although someone sniffed the scent.
Yeah, that helped a bunch, thanks.
RangoWA is offline
artinall (10-27-2017)
Old 10-27-2017, 08:44 AM   #20
hdavis's Avatar
Rewards Points: 4,583
I've done some illogical work for people, usually old people, but people who lost their spouse can have some quirks as well. It may be tear down and haul to the dump situation, but the owner wants a fix/ restoration.
Also, people can become disoriented if something like the front door is changed, they may think it isn't their house.
hdavis is online now
Cut Metal Door Frames ? We Fix Houses Flooring 4 07-05-2016 07:57 PM
Prepping Metal for Paint Advice MTN REMODEL LLC Painting & Finish Work 17 07-22-2014 12:20 AM
Metal Roof - Rain Diverter artinall Roofing 3 08-13-2012 12:00 AM
How to paint typical aluminum Garage Door IHI Painting & Finish Work 2 12-28-2009 08:58 AM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
