Repair Hole In Hardboard Siding
Old 05-11-2007, 09:38 AM   #1
cowtown
Guest
cowtown's Avatar
Posts: n/a
I'm looking for suggestions for repairing a hole in hardboard siding. The hole is about 2 inches wide. I would like the finish to be flush with the siding and blend in as much as possible. I'll prime and paint to finish it off.
Thanks for your help.
http://www.contractortalk.com/images...es/thumbup.gif
Old 05-11-2007, 11:49 PM   #2
Brushslingers
Guest
Brushslingers's Avatar
Posts: n/a
Re: Repair Hole In Hardboard Siding
Stared at this five times.. dunno what to tell you, i'll assume you are talking hardiplank, should be replaced if there's a two inch hole in it. Other than that, maybe a latex exterior putty would work, but two inches..................
Old 05-12-2007, 08:27 AM   #3
Richard
Guest
Richard's Avatar
Posts: n/a
...or maybe the minwax 2 part epoxy filler
hard as a rock in 10 minutes
I'm sure you've already called an installer and asked them what to do
if not...get on that
Old 05-12-2007, 09:27 AM   #4
tcleve4911
Guest
tcleve4911's Avatar
Posts: n/a
WTF Replace the piece of siding!!!!!
Old 05-12-2007, 01:32 PM   #5
Joewho
Guest
Joewho's Avatar
Posts: n/a
Remove firring strips on either side of the panel, pry it out and replace with a new one.
Invest in a cats paw.
Old 05-12-2007, 11:29 PM   #6
Terrence
Guest
Terrence's Avatar
Posts: n/a
I agree with replacing the siding piece, but...
sometimes there is some reason not to, and you could cut the hole into a square, and then plug it with a piece of wood that is epoxied in place. Then just belt sand it smooth.
Just a thought.
Old 05-23-2007, 02:48 PM   #7
Tmrrptr
Guest
Tmrrptr's Avatar
Posts: n/a
if it's not in a hi viz area, get a backing in behind it and use some bondo. on the 2nd pass, texture it a bit to match the siding. prime & paint it r
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE Grumpy Help Wanted or Looking For Work 4 05-26-2009 03:51 PM
Foundation repair (New business) Help! crosshair66 Business 10 05-18-2008 09:19 AM
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
vinyl siding repair N.E.Bldg&Rest.LLC Windows, Siding and Doors 17 08-20-2005 11:19 PM
