Unregistered
Guest
Posts: n/a
Repaint; Should I Prime?
I'm going to repaint the interior of the house.
The paint thats on the walls has bit of sheen to it, I'm not sure if it's eggshell or satin, but it's kind of shiny. Do I need to prime it before I repaint it? I'm putting eggshell back on. |
paper hanger,painter
Re: Repaint; Should I Prime?
As long as the surface is clean,all you need to do is a quick and light sanding.
Bah Humbug!
I'm not a painter but I'd prime if you did any patching and/or if you are going over a dark color. No matter what I encourage you to sand first! I am sure the pros will agree with me.
Back from the dead...
Trade: Paperhanger/Painter
Yep, what they ^^^ said. Be sure that its latex you are going over and not oil.
Wash the walls first and then a light sanding and a wipe down with "swipper" cloth. If you are not covering dark paint and going to a light color, use a primer with a 1/2 tint and then the finish coat.
Slinging paint-grab tarps
Agree with the above...
If you are patching any nail holes or larger...be sure to prime the finish work. Give a light sand, wash the walls down. If you are a DIY(do it yourselfer), do not listen to any paint supplier about a wall pre cleaner. So far there is only one cleaner on the market at present that doesn't leave a film on your wall, Mr. Clean.
But He was pierced for our transgressions, He was crushed for our iniquities; the punishment that brought us peace was upon Him, and by His wounds we are healed. :Thumbs: |
Sunny Southern California
What do you all consider light sanding?
You just want to scruff up the surface.
#9 | |
Unregistered
Guest
Posts: n/a
Re: Repaint; Should I Prime?Quote:
| New outside trim....to prime or not to prime | Flikka | Painting & Finish Work | 11 | 07-06-2007 07:15 AM |
| prime before texturing...just do it | Richard | Painting & Finish Work | 9 | 03-27-2007 09:12 PM |
| prime marks on wall | lornmastro | Painting & Finish Work | 37 | 11-12-2006 03:12 PM |
| prime or not to prime | trumps101 | Painting & Finish Work | 4 | 04-09-2006 09:44 PM |
| Need advice to estimate a big repaint | painterman67 | Painting & Finish Work | 1 | 11-20-2005 09:06 AM |
