Removing Water Stains
Old 12-18-2006, 06:56 PM   #1
quality app's Avatar
Trade: paint contractor
I have a raw mahogany ext. door that has been badly waterstained it looks to have been installed for months. anyway I sanded and cleaned it with denatured alcohal but some stains remain around the bottom of the jam.It is getting a natural finish. any Ideas?
quality app is offline
Old 12-18-2006, 07:33 PM   #2
New York City
eastend's Avatar
Trade: historic woodwork restorations
Re: Removing Water Stains
try cleaning with oxalic acid. it will pull the water stains out. be careful not to get any on you, and make sure you wash it off after it's done.
eastend is offline
Old 12-18-2006, 07:39 PM   #3
axnjoe's Avatar
Trade: Interior contracting
I was told that mahogany is much like teak.
The biggest diference was that teak will hold it reddish hue and it will fade then silver up. That is why it is used so much for patio furniture and that if mahogony is used it's natural red pigments will leach out and leave red stains on floors before silvering up.
Not sure if this bit of info is helpful. Or if any wood guru can verify this.
From whay I understand is that this is more like a severe tannin bleed.
axnjoe is offline
Old 12-18-2006, 09:05 PM   #4
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Read my website and follow the same type of 2-step procedure. The FAQ section will give you some more hints.
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 12-18-2006, 10:55 PM   #5
Joewho's Avatar
Trade: Painter
whink
Joewho is offline
Old 12-18-2006, 11:13 PM   #6
Deck Cleaner
The cleaners we sell have many more ingredients and expensive surfactants but if you got the hint like Joe did, you know what to use.
Ken Fenner
Pressure Washing PA
Old 12-19-2006, 06:21 PM   #7
Joewho's Avatar
Trade: Painter
I learned about whink when working at a antiques resto shop.
It won't remove all water stains, but its' a first, safe step in that direction.
I didn't go into the faq's of your site yet.
Joewho is offline
Old 12-19-2006, 06:59 PM   #8
Teetorbilt's Avatar
Mahogany with water stains is tough. Don't expect to get them all out, you should have refinished before letting it get so far.
Mahogany and Teak are like oil and water, literally. Teak is full of oil and tends to reject most finishes, oiling is best. Mahogany is generally a softwood and soaks up finishes, and water, like a sponge.
Albert Einstein
Teetorbilt is offline
Removing a hot water base board heater Mike Finley Plumbing 8 01-23-2007 07:51 PM
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
Mixing mortar with sump pump water mdshunk Masonry 13 01-25-2006 04:58 PM
