Removing Stain From A French Door Or Replace?
Old 03-10-2004, 09:34 AM   #1
Mike F
Guest
Mike F's Avatar
Posts: n/a
I'm in the process of replacing all the old wainscotting in a study with really nice alder raised panels. The problem I have is the wooden french doors in the room. I imagine they are made of poplar. They are stained, and the new woodwork is not going to match the old stain on the french doors.
Is it possible to remove this old stain and restain to match the new woodwork? They have multiple glass panels. I can't imagine sanding these doors, trying to get into the detailed spaced among the panels would be a night mare. If it is possible to get rid of the stain, can it be done chemically?
Old 03-10-2004, 09:39 AM   #2
General Contractor
hatchet's Avatar
Re: Removing Stain From A French Door Or Replace?
I've seen articles on using bleach to mute the effect of stain - it doesn't totally remove it but gets it pretty close. Do a search for Sam Maloof - one of the best finish guys around. I'm pretty sure he wrote an article on it somewhere.
This article isn't bad - http://www.easy2diy.com/cm/easy/diy_...ge_id=35694244
Rich
WIT Construction Co.
Superior MT Contractor
hatchet is offline
Old 03-10-2004, 08:03 PM   #3
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
I've seen it done, but wouldn't do it myself. It involved using a gel-type stripper to remove the poly/varnish finish, and scrubbing with fine steel wool repeatedly, slowly removing the stain. Then using a wood bleach to lighten it up. Never will get it back to 'bare wood'. And it was a messy procedure. It would work though if you needed a lighter stain than the existing one.
And I'm not sure, but I know there are companies that dip old doors and windows to strip paint, maybe one in your area can do it for stain too.
Good luck.
ProWallGuy is offline
Old 03-11-2004, 07:58 AM   #4
Custom Builder
Glasshousebltr's Avatar
3 M makes a great jell striper, and its not as much work as it sounds. Pull the door pins and set up on some saw horses. After apply the striper and wait about 45 minutes (time varies according to hummidity). Use a just little water with the steel wool to re-activate the striper as you go. Repeat the process until your happy with it. Then sand it down good. I use a dremel a lot at this process. Bob
Glasshousebltr is offline
Old 03-11-2004, 11:46 AM   #5
Mike F
Guest
Mike F's Avatar
Posts: n/a
Since posting this I have been looking at these french doors some more and I came up with a solution that is kind of cheating.
I could easily sand all the flat surfaces of the doors, the fronts surrounding the glass, the top edges and sides, and even the door jams, after removing the molding that acts as the stops, (that could easily be replaced with some alder).
Then I could cheat buy painting the inset molding around all the windows a dark color. I think I could get away with that and it wouldn't look obvious why it was done.
However, I would really like to do it right.
I have contacted one dipper, and they said they can only dip for paint removal, something about the age of the stain and how it won't react?
The bleaching makes some sense, but I don't think it would effect the stain until I got the varnish/poly layer removed first, which brings me back to the sanding problem I think.
The gel stripper is for stains? not just paint? It seems paint is rather easy to get rid off, there are so many products for that, but stains seem to be more specialized and there are less solutions.
Old 03-11-2004, 02:50 PM   #6
BM Retailer - Pro Painter
Mark's Avatar
Send a message via ICQ to Mark Send a message via MSN to Mark
If this was a true historical restoration I would say put your nose to the wheel and watch the hours add up, but if you have a customer footing the bill and its nothing you can't replace then by all means its probably cheaper to change out. Getting totally rid of stain can be a very messy and labour intensive deal.
Mark
www.benmoorestore.com
Mark is offline
Old 03-22-2004, 10:46 PM   #7
tcb_iii
tcb_iii's Avatar
The method I would use is shelac stain they used it in the old days You would add the shelac chips until you have the desired color or shadow. they have differant basesyou have to match your new base stain
tcb_iii is offline
tips on removing oil based stain from hinges davidanbess Painting & Finish Work 10 07-10-2007 02:25 AM
French drain question 72chevy4x4 Construction 4 11-01-2006 10:46 PM
Stain b/4 or after installation??? pitterpat Painting & Finish Work 10 10-09-2006 07:15 AM
Stain trim b/4 or after installation pitterpat Carpentry 3 10-08-2006 11:09 PM
French door paint and stain Luke's Dad Painting & Finish Work 6 02-23-2006 09:57 AM
