#1 | |
Pro Painter
Removing Popcorn On A High Pitch Ceiling
I have a job to bid that includes removing the (painted) popcorn from a LR ceiling that pitches from 7' to 18' at the high side across a 16x20 room. I'm guessin to get to all the popcorn I'm going to need something like two 6' stackable scaffolds to be able to reach safely and effectively remove the popcorn, which will most likely be replaced by a knockdown finish. How would you tackle this ceiling? Using just ladders it would be difficult to reach the entire ceiling me thinks......
#2 | |
Pro Painter
Re: Removing Popcorn On A High Pitch Ceiling
BTW, I'm only needing advice on reaching effectively......I don't own any scaffold as of yet, so I may have to rent it. What's avg rental cost for interior scaffold? As far as the actual removal, I have done it many times...it's just reaching this whole ceiling and being able to do it in a timely manner is what I'm perplexed about.
SAGE
Trade: Remodeler and Finish Carpenter
Your an the right track, Bakers are safer and you can work much faster. If I were in your situation I would not rent, Buy.(if it's financially possible) Scaffolding seems like something that should permanently be in a painters tool bag. I'm no painter, just my opinion.
6x6x30'' - stackable baker, about $50 a unit per week. Hope that helps.
-Lead from the front, or dont lead at all- |
Back from the dead...
Trade: Paperhanger/Painter
Yep, go with the scaffolding. Lots of great deals on scaffolds on ebay. If you choose to rent, check for cost, and mark up on your price. If you get the skinny kind, make sure to get outriggers and a safety rail. I dern near tipped one of those over in a living room.
Systems Fanatic
We've used tall step ladders in this situation. One advantage to the step ladder versus scaffolding is ease of clean up and the room can be used at the end of the day by the customer. There is a more limited reach, but in some situations the step ladder has worked better.
Brian Phillips |
Trade: paint
We use the narrow Baker style. I've seen them at about $275 from national ladder. What year house? Your probably aware that around 1984 and before, some "popcorn" makers used asbestos in it.
I would be interested in reading exactly how one goes about removing a popcorn ceiling. If not here on another thread perhaps.
Thx
#8 | |
Pro Painter
Warrior, it's pretty easy believe it or not. Except on the above mentioned ceiling, lol. I usually mask everything, walls and floor. Then I go in with a garden sprayer, or on large jobs I'll run water through the spray rig on low pressure with an old tip. Anyway, soak down an area real good with water and let it sit for a few mins, then just scrape it off with a 12" knife. I think it was teetor that mentioned adding a blade to the shop vac attachment and suckin it all up at once, but I haven't tried that as of yet. (gonna have to give that a whirl one time) I've used four foot shields on some ceilings, and even a snow shovel once. Anything with a long flat blade will work and the stuff just falls right off with minimal effort.
Trade: general remodeling
If the room was unobstructed I'd use 2 sections of regular scaffold w/wheels. This should put the peak maybe a foot over your head. When you get to the lower sections use only one section or a ladder. I like to use 3- 2x10's and 3/4"plywood for the work platform or 2 of the manufactured "picks". You'll almost need a ground man to push the thing around.
...jammin
Trade: Rock Disciple
Double A, are you alone on this?
I can't remember if you've got guys or whatever The reason I ask is that I don't own scaffolding either, and I don't have the means to transport or store it if I did Nor do I need it often enough to warrant the expense at this point Aside from the few times where it worked out for me to borrow some, I've rented That worked out well, but I either had to pay them to deliver and pickup, or again borrow a vehicle And still I had to put it together I found that with the time it took me to scramble help/vehicle/assemble etc. it cost me the same amount of money to rent a push-around (interior cherry picker) They drop it off at 8AM, and I can start at 8:05 Call'em when I'm done If I was doing this by myself I would get one for sure |
#11 | ||
Pro Painter
Re: Removing Popcorn On A High Pitch CeilingQuote:
...jammin
No not a scissor
More like an extension ladder type I get them from United...or did before I moved Whoa, another thing I'll have to find a new source for... The smallest on the United site is a 30 footer, but they have a 20 footer (18 I think) It's a push around so it's pretty light (comparably) I've brought them up elevators, but not stairs I think I have a PDF, let me check... Here: http://www.midwestaerials.com/AWP%20SUPER%20SERIES.pdf Check it out It's kind of a general description of that line, but you get the idea The one I use is the li'lest one If you need a model # I'll check last years receipts |
#13 | |
Pro Painter
Wow...I've never seen one of those before to tell you the truth. Looks like a cool little gadget, and would surely handle that ceiling rather swiftly....Thanks for the tip. The customer has changed their mind (price) and wants it just painted (thank heavens)!! I think I can handle the painting from the floor with a long pole. I'll just have to climb up once to cut it in.
I will keep that little lift in mind though....what a timesaver that could be.
Chief Toilet Mover
Trade: Bathroom Remodeling
I've got almost the identical task ahead of me, I was talking to a painter about scaffolding and ideas - he told me scaffolding my ass, all you need is an extension ladder. His take was you wedge the feet of the ladder in the corner of the floor and the highest wall and extend it up to the ceiling and lean it into the ceilding. It can't fall because the ceiling wedges it.
#15 | ||
...jammin
If it cost me $75 more and saves me 2 hours of...horsing around p/u, d/o, assembly, etc. (@ the 47.50 hr I charge myself Putting together scaffolding by yourself.... < grumbles > grrr...I add the expense (+markup) into the invoice One of the few things I'll itemize on an invoice |
#16 | ||
Pro Painter
carpenter and builder
Trade: carpenter and builder
Wow, that lift is amazing. My biggest problem would be finding a big enough space in the garage to hide it from the wife !
#18 | |
#19 | |
...jammin
(j/k) |
#20 | |
...jammin
...I wouldn't |
| Painting popcorn ceiling | rocco | Painting & Finish Work | 14 | 08-01-2007 10:52 PM |
| removing ceiling fan | navco1390 | Carpentry | 14 | 07-01-2007 01:49 PM |
| Popcorn ceiling falling | dumplin1078 | Drywall | 35 | 11-08-2006 06:00 PM |
| Popcorn Ceiling | cowtown | Painting & Finish Work | 12 | 03-30-2006 11:00 PM |
| 30 year old popcorn | boardslinger | Drywall | 12 | 12-25-2005 10:40 PM |
