Old 09-30-2006, 06:11 AM   #1
Trade: Painting and wallpapering
Removing painted over grasscloth
HI guys! New to the site.Has anyone ever encountered trying to remove painted over grasscloth . Its on what appears to be painted drywall , and has been hanging for about 10-15 years.HELP!
hrybzdad is offline   Reply With Quote
Old 09-30-2006, 08:06 AM   #2
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Have you tried to remove it using the regular stripping techniques?
If its a flat paint, it could absorb water fairly easy, and come down without a hitch. You might even be able to dry-strip the grass layer from the backing because it is solidified/strengthened by the paint.
Sometimes it's not as bad as you think.
Then again, sometimes it can be a nightmare.
But you need to attempt it before you can determine if it will come off or not.
ProWallGuy is online now   Reply With Quote
Old 09-30-2006, 08:31 AM   #3
Moderator
Double-A's Avatar
Lol, this can be said about most things in this line of work.
New York Times, July 20, 2006
Double-A is offline   Reply With Quote
Old 09-30-2006, 09:03 AM   #4
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Have you tried to remove it using the regular stripping techniques?...
This is what I suggest, as well. 'Grasscloth', from what I remember is simply wallpaper with tiny tiny bamboo/grass on the surface? I could be wrong, but I think that's what we're talking about here. I removed it once by scraping to remove as much of the 'grass' as I could, and then it was a normal wallpaper removal....
Rich
Richard is offline   Reply With Quote
Prep wall after removing wallcovering davidanbess Wallpaper 1 04-30-2007 05:27 AM
Bubbles when taping over painted surface? theworx Drywall 19 08-19-2006 01:52 PM
painting painted paneling cessnapilot Painting & Finish Work 4 03-21-2006 06:21 PM
Removing popcorn on a high pitch ceiling AAPaint Painting & Finish Work 22 02-02-2006 09:53 AM
Removing stain from a french door or replace? Mike F Painting & Finish Work 6 03-22-2004 10:46 PM
