Old 07-22-2006, 09:07 PM   #1
Dream Maker
Mr. D's Avatar
Trade: residential construction
Removing old worn finish on log home
I'm looking into doing a re-stain on a log home. The original finish was put on five years ago. some cheap oil I believe. The h.o. said it was $50 for 5 gal. Anyhow, It looks like most of it is gone except up on the gables and a bit under the covered porch. Do you think I'll be able to use a wood brightener and a power wash to remove what's left. Or should I use a stripper.
Lots of the home is about to start greying so, I'm gonna use a brightener before I apply the finish anyhow.
Also, it's about 1800 sq. ft. of surface. How does $5040.00 sound for three coats stain. I bid a lot of staining but, rarely get them. Does my price sound whacked?
Thanks guys & gals.
Mr. D is offline   Reply With Quote
Old 07-22-2006, 11:41 PM   #2
painterofeverything
Trade: residential painter
Send a message via Yahoo to painterofeveryt
stripper,and a brightener imho
painterofeveryt is offline   Reply With Quote
Old 07-23-2006, 07:40 AM   #3
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Uhh.....double post.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline   Reply With Quote
Old 07-23-2006, 09:12 AM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
I'd strip/clean (whichever it needs)
Then brighten
Not sure why you'd need 3 coats stain
And that's a lot of work for $5K
Granted, I don't see a lot of log cabins here lol, but that price sounds crazy low for 1800sq for:
1) Applying stripper/cleaner
2) PWing off
3) Applying brightner
4) PWing off
5) Applying stain
6) Applying stain
7) Applying stain
Signature Quote
slickshift is offline   Reply With Quote
Old 07-23-2006, 10:24 AM   #5
Jonesey's Avatar
Trade: Painting and Finishing
Hard to guess without pics, but yeah, that's pretty low to strip it completely. 3 days to strip and clean, 1 day to brighten, 3 days to stain.
Sounds pretty tight to me. But hey, you know your cost.
Steve Jones
steve@jonespaintingonline.com
Jones Painting Feel the difference service makes
Jonesey is offline   Reply With Quote
Old 07-23-2006, 01:36 PM   #6
Pro Painter
AAPaint's Avatar
Thanks for taking care of my extra posts...I dunno what happened to make me have 3 posts, but whoever did it deleted the one with the actual info I posted. So, here goes again......
The price, I would agree is a little low. You'll need between 20-30 gallons of stain alone for two coats....three would certainly be more, but the wood probably won't take 3, and doesn't need 3 coats either.
Also, be careful power washing log homes. You can have serious issues with water intrusion through the chinking in between the logs. I haven't done any log homes myself, but the only other alternative is media blasting to remove the old stain. Corn cob blasting is what is frequently used on log homes to strip old stain because of the water penatration issues.
For media blasting you need expensive equipment that I am not sure if you can rent or not, and your price would need to change accordingly.
Good luck, have fun, and give that wood the care it deserves!
-AAPaint
Jacksonville, FL.
-James Madison
Old 07-23-2006, 05:25 PM   #7
Dream Maker
Mr. D's Avatar
thanks for the input fellas,
that price was for staining labor only, had about 1680 figured for stripping and cleaning labor.
the 3rd coat is a satin top coat. recomended by stain manufacturer.
I think that should put me in the ball park. I'll let ya'll know how it turns out.
Old 07-23-2006, 07:55 PM   #8
Trade: Log Home Services
what's up Mr.D,
...All I do is restore log homes, so I'll try and offer a bit of advice. First, if you can get that price for staining only 1800sf, look out, because you've got a competitor headed up to the U.P. If that is with you buying the stain, it is a little more reasonable, as I am quite sure I know what product you are referring to, as you referenced a "satin topcoat". That product is very expensive. Other things: If you strip/wash these walls, they are going to felt. Are you going to de-felt? Better clear that up ahead of time with the customer. Ahead of time, make sure they are aware water is going to come into their home like crazy. Not stripping soffits,etc, areas that aren't worn?? Be aware the new stain won't blend in these areas. Good luck on the project,
Jon F is offline   Reply With Quote
Old 07-25-2006, 02:35 PM   #9
SSP
I agree with Jon I would not introduce moisture in to the wood siding.
I would also reccommend a moisture meter before I apply any stain
Haven't did many log homes but usually the "grey" color is usually wood rot and very soft. Not sure ....havent seen it ...but at 2.78 per sq ft sounds do-able.
SSP1 is offline   Reply With Quote
Old 07-25-2006, 05:27 PM   #10
How'd ya end up Mr. D??
Old 07-25-2006, 08:23 PM   #11
Dream Maker
Mr. D's Avatar
submitted the bid, sat down with him and gave him the speil. i think he's impressed with my thouroness. (probably spelled that wrong) he's waiting for a couple more to come in. I was the last to show up and the first to get a bid to him. so i've got promtness going for me
Old 07-26-2006, 02:08 AM   #12
Where's the Grease
Michigan Exhaust's Avatar
Trade: Michigan Restaurant Vent a Hood Cleaning Company
All right Jon Fife said we could head up to northern michigan now. Wait how far north I need my 7-11 coffee
Michigan Exhaust Cleaning
Your First Step in Restaurant Duct Fire Prevention
http://www.michiganhoodcleaning.com
Dave Ott 248-577-4042
Michigan Exhaust is offline   Reply With Quote
Old 07-26-2006, 12:33 PM   #13
Awesome Mr.D!! You oughta have TONS of this work around you with all of the cabins and short work season.
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 03:41 PM
Custom Home Building wackman Business 2 03-16-2007 04:08 PM
Called home depot today... Grumpy Off Topic (Non Trade) 23 07-05-2006 08:53 PM
Drug caches found in Home Depot vanities HandyAl General Discussion 1 06-14-2006 07:14 PM
Removing stain from a french door or replace? Mike F Painting & Finish Work 6 03-22-2004 10:46 PM
