Removing Old Blue Tape.
Old 07-28-2007, 06:32 PM   #1
Teetorbilt's Avatar
Another personal project (painting the house) that was side-lined for too long (about 3 mos.) has resulted in blue tape that is stuck like a barnacle to the drip-edge flashing.
Any ideas on how to remove it?
Albert Einstein
Teetorbilt is offline
Old 07-28-2007, 06:41 PM   #2
Tom R's Avatar
Re: Removing Old Blue Tape.
Heat-gun??
Tom R is offline
Old 07-28-2007, 07:06 PM   #3
Guru
paint_booger's Avatar
Trade: Union Paint & Drywall
Denatured Alchohol
paint_booger is offline
Old 07-29-2007, 08:19 AM   #4
Steve Richards's Avatar
Trade: hack painting
What's the difference between denatured alcohol and rubbing alcohol?
I use denatured all the time for cleaning up my paint messes.
I've had people ask me what the difference is, and I have to either make stuff up like I know what I'm talking about, or pretend to pass out... (like John Cleese in Faulty Towers)
Steve Richards is offline
Old 07-29-2007, 09:21 AM   #5
mikenewman@fron's Avatar
Trade: Painter
Try xylene. It's a slow drying solvent that will give you more soak time. Mike
mikenewman@fron is offline
Old 07-29-2007, 11:19 AM   #6
Dustball's Avatar
http://www.newton.dep.anl.gov/askasc.../chem00102.htm
Rubbing alcohol, these days, is synthetically produced isopropyl alcohol
diluted with water to 70% strength. This is not fit for consumption.
Denatured alcohol is ethanol (a.k.a. ethyl alcohol, grain alcohol, etc.)
that would otherwise be fit for mixing libations EXCEPT that it has been
altered by the addition of a chemical that makes it particularly unfit for
consumption. One common denaturant causes blindness when consumed, while
another imparts a strongly bitter taste. The point of denaturing alcohol is
that ethanol has usefulness outside of consumption for intoxicating effects.
These other uses need not bear excise taxes for beer, wine and liquors, so
it is altered to preclude its being diverted to this sort of use. Denatured
ethanol is also regulated by ATF and requires extensive record-keeping and
licensing for someone to use or to store the material. While the consumable
ethanol is produced by fermentation of sugars, the material that is
denatured for other uses is usually produced synthetically.
Dustball is offline
Old 07-29-2007, 04:40 PM   #7
Guru
Hmmmm
I'm thinking passing out is the best option.
If rubbing Alch is 70% ... and Bacardi is 151 proof ... wouldn't Bacardi be stronger (75.5%)?
I'll go with Flaming shots of 151 with the home owner as the answer here.
Old 07-29-2007, 08:24 PM   #8
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
Ok ....... so other then going blind and tasting bad, is there any reason why i couldnt make Hairy Buffalos with my denatured alcohol, I mean everything has its price right.
If you get that tape off you can come try to get the tape off of my sons bedroom window, it has been on there 3 years. My wife has been nagging me lately to get it off, I told her you cant even see it from the street.
Maybe I will just save myself some hassle and break the glass ...... but then again I do hate glazing windows ........... maybe I will just move instead.
ModernStyle is offline
Old 07-31-2007, 07:42 PM   #9
Now I get it...
"de -natured" meaning if it was "natural" I could drink it!
Not that I would...
probably
Man I learn a lot here
Loose Drywall Tape hanover Drywall 7 12-03-2009 11:43 PM
New light blue tape Richard Painting & Finish Work 6 04-27-2007 09:11 PM
Paper Adhesive tape. jstrand23 Drywall 1 03-07-2007 06:02 PM
blue tape painterofeveryt Painting & Finish Work 27 02-16-2007 01:09 AM
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 52 09-08-2006 09:22 AM
