Removed Border With Dif And Left Streak Marks
Old 08-24-2006, 02:52 PM   #1
lornmastro's Avatar
Trade: interior paint contractor and window treatment workroom
removed a border with dif and the drips left some streak marks on the bottom portion of the wall. primed where the border was taken off and painted the wall with a light coffee color. after 2 coats the streaks where still showing and would get less noticable as the paint dried. after 3-4 coats on those spots it was fine 1)question 1 whatwould have caused that?? question 2 had another job in a similar color that after 1 coat of white primer and 2 coats of paint the paint still diddn't cover that well. are these problems about the light coffee color, the dif, or ?????
lornmastro is offline
Old 08-24-2006, 03:13 PM   #2
My custom title
Brushslingers's Avatar
Re: Removed Border With Dif And Left Streak Marks
Diff, most times you need to wipe it down on painted surfaces, then prime/paint... the diff will streak on paint but not on sheetrock, your border was removed but the diff ran down into the painted part is all.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 08-24-2006, 04:36 PM   #3
lornmastro's Avatar
just to clearify... with dif i need to wipe the whole painted wall to remove the dif from what ever it touched and then am i have to prime??on other job...question 2 why after 1 coat of bm primer and 2 coats of bm paint did that light coffee color not completely cover...it went over builder white...is it the nature of the color?? inquiring minds what to know!!! ok...not inquiring minds...just me
Old 08-24-2006, 04:43 PM   #4
My custom title
1 Yes.
2 It will happen will other colors as well, Diff is a chemical so it will bleed.
Hope that helps.
Benn
Old 08-24-2006, 04:59 PM   #5
KellyPainting's Avatar
Trade: Painting Contractor
Next time save your money and use liquid fabric softener mixed w/ water
the dollar store stuff is fine and the streaks paint over nicely.
KellyPainting is offline
Old 08-25-2006, 06:21 PM   #6
lornmastro's Avatar
thanks for the advice ....lorna
