Old 02-13-2008, 08:44 PM   #1
Trade: Painting and Decorating
Removal of paper border a nightmare
Hi, took off a paper border today in a bathroom, it was a nightmare to come off, it has left a glue like residue.
tomorrow I will be trying to get it off with some dif and if not I will seal it with oil primer and skim coat over it.
Would this be the course of action you guys would take, if not what would you recommend.
Thanks in advance D/B
davidanbess is offline   Reply With Quote
Old 02-13-2008, 08:50 PM   #2
Fentoozler
Celtic's Avatar
Vinegar and water...a little elbow grease with a putty or spackle knife.
Celtic is offline   Reply With Quote
Old 02-13-2008, 08:55 PM   #3
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
Seal and skim the edges, I don't know about the glue used, but I have one right now that I soaked for hours and I can't even peel the edges. Tried vinegar and I smelled like a salad all day, the border must of loved the vinegar because it's still stuck up there.
silvertree is offline   Reply With Quote
Old 02-13-2008, 09:16 PM   #4
Trade: Painter
I had this before and I think homeowners used border adhesive instead of wallpaper paste. From what I understand, border adhesive is designed for putting borders over vinyl paper and does not come off walls easily. I had to sand it off.
DeanV is offline   Reply With Quote
Old 02-13-2008, 10:59 PM   #5
Thanks everyone, I actually found the same dilemma over in the wallpaper section.Should have went there first I suppose
Old 02-14-2008, 06:32 AM   #6
Trade: Painter
One thing to try, it is a long shot, but I once took off some old wallpaper that seemed to have a clay adhesive on the wall but hot water and DIF would not touch it. I believe I even tried wiping the wall with a solvent like lacquer thinner or Wil-Bond with no luck. I happened to have some Challenger along for cleaning the cabinets and spray that on the walls, and it came off extremely easy with Challenger. Never had that work again for me though.
Old 02-15-2008, 07:51 AM   #7
Trade: FLOORING/REMODEL
If You Can Peel The Paper Off And Leave The Backing I Use A Fruit Srayer With Hot Water It Works Like A Champ Be Careful Of Cabinets Sometimes The Water Will Stain It
REMODMAN is offline   Reply With Quote
Old 02-17-2008, 01:59 PM   #8
well guys after giving a rub down I just brushed on some Gardz and then skimmed out, rubbed down again and then applied a primer and 2cts of latex and bobsyouruncle
Regards D/B
Old 02-17-2008, 07:55 PM   #9
ohhh noooo, it's ...
daArch's Avatar
Trade: Wallcovering Installation
Many borders, even pre-pasted ones, are installed with VOV (Vinyl over Vinyl) or Border adhesive. These are not starch based adhesives like normal pastes but have polymers.
Safe and Simple of Pasedena, CA (www.safeandsimple.com) makes a stripping solution specifically designed for border adhesives - their # 826
http://safeandsimple.com/new/826.htm
It will still take time to dissolve the paste, but it does work.
daArch is offline   Reply With Quote
Old 02-19-2008, 08:39 PM   #10
4thGeneration's Avatar
Trade: Custom Repaint craftsman/Deck Restorer/Soft washer
We are completing a job that has wallpeper all over including border. Double border actually. My wife used the paper tiger lightly. Then she sprayed plain hot water over it. She then peeled a edge and while pulling she sprayed behind the paper and it came off. For the glue stuff left she re-wet and used a large spackle knife to scrape it off. A total pain, but she removed it all.
4thGeneration is offline   Reply With Quote
Old 02-22-2008, 11:10 AM   #11
Trade: interior paint contractor and window treatment workroom
DaARCH was wondering if you use this safe and simple on all you wallpaper removal jobs?? It seems costly at $89/bottle.
lornmastro is offline   Reply With Quote
Old 02-23-2008, 05:39 AM   #12
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Send a message via Yahoo to chris n
You only use 2 oz per gallon of water, I do a fair amount of removals and I only use about 2 gals a year, at $89 this is cheap and at least IMO the best out there.
chris n is offline   Reply With Quote
Old 02-23-2008, 08:25 AM   #13
ContractorTalk Flunkie
dayspring's Avatar
We use Downy fabric softener, with excellent results most always. Just spray it on with a spray bottle or garden sprayer for larger, stubborn jobs
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline   Reply With Quote
Old 02-23-2008, 07:17 PM   #14
Thag
Trade: Home improvements
Dude, you must arm yourself with every possible method there is to use when taking down wall paper. When one method does work move on to the next. Guaranty you would have that off if trying all methods.
Thag is offline   Reply With Quote
Sheet rock down to brown paper backing, botched wallpaper removal? atv71 Drywall 33 09-07-2007 11:38 AM
Type of Paper Under Hardwood CharlieDaw Flooring 2 04-12-2007 09:43 PM
commercial wall paper removal rservices Wallpaper 1 06-28-2006 08:58 PM
Wall paper removal nightmare juliepe Masonry 4 09-11-2005 09:01 PM
Wall Paper removal nightmare juliepe Drywall 0 09-11-2005 07:50 PM
