Refinish Wood Garage Doors
Old 05-26-2007, 10:43 AM   #1
maddmaxum69's Avatar
Trade: painter
has anyone refinished oak stained and poly finish exterior wood garage doors didnt know to use liquid strippers or sand any help thanks
maddmaxum69 is offline
Old 05-26-2007, 10:48 AM   #2
My custom title
Brushslingers's Avatar
Re: Refinish Wood Garage Doors
Not sure if you said -
Has anyone refinished stained oak doors with a poly finish, this is exterior, and didn't know how to use strippers?
Or -
Has anyone refinished stained oak doors with a poly finish, this is exterior, and didn't have to use strippers?
Benn
Originally Posted by Brian
Brushslingers is offline
Old 05-26-2007, 10:58 AM   #3
Teetorbilt's Avatar
I've done a lot of wood entry doors. I'd strip with something like http://kwickkleen.com/ , a bio-friendly stripper. Bleach (if required), seal (if required, probably not on oak), sand as required, stain (if required) and start stacking on a quality MARINE varnish (oil and not the stuff that they sell at the box stores).
Reduce the first 2 coats by about 20-25% for penetration and then go to the appropriate brushing/spraying thinner. Sand or steel wool lightly between each coat. 5 coats total will get you quite a few years of protection.
Albert Einstein
Teetorbilt is offline
Wood panels on an aluminum garage door? gregsatt Windows, Siding and Doors 4 12-23-2010 05:19 PM
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
garage doors aspenpainting Painting & Finish Work 22 08-19-2006 05:42 PM
Refinishing stained and varnished garage and front doors kelsey944 Painting & Finish Work 2 04-01-2006 09:34 PM
Roll down garage doors.... FireballBrick Windows, Siding and Doors 5 11-26-2005 02:01 PM
