#41 | |
Trade: Prep Nazi
Re: "Real Painters" Don't Use TapeQuote:
I agree! Much easier to give it a quick tape rather then taking the time to cut a line then have to worry about roller splatter later antway. |
#42 |
Trade: painting
Why not just paint the baseboard. It makes the job look so much better with a fresh coat and I can paint the baseboard in the same amount of time it takes to tape it (yes 10 min). I also paint the baseboard last, which Im sure will start another discussion. But I like to paint casings first.
#43 |
Organic Painter
Trade: Painting Contractor
Capital that is the correct way, and I make sure to let the HO know whether thay pay me to paint the base or do it their selves it needs to be done last.
#44 | |
A bit abrasive.
If that is the case how do you get the trim color (usually light colors) to cover the dark wall colors that have spattered in one pass? Also, with a high sheen for the trim won't all of the little spatters eventually become visible? I too will run a coat of trim paint after rolling, but only on the top to lessen any large areas where paint crept up underneath the tape due to uncontrollable circumstances; like an ugly caulk bead, or boogers that prevented the tape from sealing properly. Neither of those things occur regularly, but with repaints one is constantly fighting the work of previous contractors.
My advice: Hire a real painter to do it. |
#45 |
Side Effects May Vary
Trade: Professional Painting
If you cant paint the base in a room in the same ammount of time it takes me to tape it ................
#46 |
Trade: Prep Nazi
I always do a rough tape job then just recut the tops of the base after the walls are done, it's very annoying to try covering dark red splatter with white SG. Every job I do- Either I just did the trim or the trim paint is new enough that a quick cut blends and looks perfect.
#47 |
Trade: Painter
Re: "Real Painters" Don't Use Tape |
#48 |
Steve
For me, it comes down to one simple question. What's gonna take longer, taping it or trying to clean it. If it's something that cannot get paint on it, or as mentioned above, too hard to clean/cover, tape it. Otherwise, no tape.
#49 |
Trade: Painting, flooring
You guys are a bunch of hacks. I paint the base, mask it, paint the walls, drop plastic from the ceiling and use an airless to put down (up) the top coat. I can knock out a 10x10 room bottom to top in no more less 19 hours.
Well I've always done it that way since I heard some yokels talking about 'top coats.' |
#50 |
paper hanger,painter
#51 | |
Trade: painting
#52 |
Trade: painting
#53 |
Trade: Prep Nazi
Everyone has there own way of doing things guys!
#54 |
Trade: painting
Thats true, thats one reason I get on here to learn how other people do things in other areas and maybe incorporate it with what I do. We have had the baseboard discussions before and then it was also mentioned that people paint the baseboard first and find it easier to trim in the wall to the trim last. I have tried both of these other ways and personally dont get it, with the tape I found you usually have to go back and trim the base again anyways and when you paint the base first you have the chance of a splatter problem but I also find it harder personally to trim in the wall last.
#55 |
Trade: Prep Nazi
That's the thing, it's really a trade-off. All of my high end new homes I spray all the trim first. It's always beneficial for me in these cases to tape the base and go back to cut the top base line after the walls are done. I can't paint over roller splatter in these homes and I would have to cut the line if doing the base afterwards anyway.
On the other hand, in a small res. repaint with similar color base and walls I may not tape..
www.sccustompainting.com |
#56 | ||
A bit abrasive.
Then I get to trundle over and walk behind the client as they literally "rub" every inch of trim in order to show me that the trim has "millions of tiny bumps that show". yay. Quote:
I honestly hope that is not the bulk of your painting business as it really dulls the senses after the 30th rental house, almost to the point of irreversible damage. I avoid "polishing turds" like the plague. Even the finest paint manufacturers have yet to formulate a white that covers perfectly in one coat. SW is the closest with their "Pure White" base. I feel like I am debating the use of drop cloths...
#57 | |
I agree with you!!
#58 | |
I have never seen anyone cut as straight as a good tape job, I have heard people say they could, but it was always BS. If you tape or dont tape, as another painter I couldnt care less, just keep the customers happy and make that money. |
#59 |
I like Green things
You painters are still bickering about tape? Quit huffing the fumes man!!
#60 | |
Trade: painting
| Does anyone use the Duratape Wet&Stick joint tape? | Adv.wall.tech | Drywall | 16 | 05-10-2009 09:11 PM |
| What tape to use? | nwksremodeler | Drywall | 12 | 02-04-2009 08:47 PM |
| Best Tape Measure | Journeyman T | Tools & Equipment | 39 | 02-26-2008 02:14 PM |
| Help. Self Adhesive paper tape problem. | jstrand23 | Drywall | 1 | 11-28-2007 02:09 PM |
| 18 inch rollers and Tape Question | dwbrooks | Painting & Finish Work | 52 | 09-08-2006 09:22 AM |
