"Real Painters" Don't Use Tape
Old 04-07-2009, 02:14 AM   #1
Honest GC
Im50bound's Avatar
Im50bound is offline
Old 04-07-2009, 02:17 AM   #2
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Re: "Real Painters" Don't Use Tape
You aint no real GC are you?
willworkforbeer is offline
Old 04-07-2009, 03:00 AM   #3
Organic Painter
Mr. Mike's Avatar
Trade: Painting Contractor
We don't use it for everything a DIY'er would use it for. We don't put it around the trim, or around the glass, or around the hinges and many other things...
Mr. Mike is offline
Old 04-07-2009, 03:14 AM   #4
What the hell do you use it for then? A "GC" wants to know.
Old 04-07-2009, 03:34 AM   #5
Error Corrector
olyteddy's Avatar
Trade: Maintenance Manager
I'm not a real painter, I just play one at work...But I don't use tape. It takes too long to apply it and remove it. Heck, I don't even use a brush most of the time...
olyteddy is offline
Old 04-07-2009, 09:32 AM   #6
DavidC
DavidC's Avatar
As a teenager my freinds and I were painting rooms for family freind. After numerous trips to the hardware store for more tape the owner took me aside. "If you need that much tape, you need to learn to paint" he said.
He showed me how to hold the brush and I went back to practice. We use painters tape extensively today, to hold up plastic sheets or secure drop cloths, etc. Rarely to protect an adjoining surface.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 04-07-2009, 09:59 AM   #7
A bit abrasive.
WisePainter's Avatar
I use tape only along baseboards, 1 1/2" to protect the trim from spatter caused by rolling.
I am not a painter though...I am a wall "technician".
My advice: Hire a real painter to do it.
WisePainter is offline
The Following User Says Thank You to WisePainter For This Useful Post:
NAV (04-07-2009)
Old 04-07-2009, 02:13 PM   #8
Traditions2's Avatar
Trade: painting and refinishing
I will stir up controversy on this one. I use tape in certain situations. Where door trim meets the wall I like to see a lazor straight line. I can run tape down each side, run a small bead of caulk down to seal so no bleed through then paint and pull pretty darn quick. I'm not sure the best painter in the world could consistently make a line straighter than that. Plus, any guy on my crew can "cut" those lines. This is normally on new construction with white trim. If it is just a repaint I'll normally just cut it by hand. I never tape ceiling lines or anything like that.
My name is Traditions and I am a tape user/abuser
Traditions2 is offline
The Following User Says Thank You to Traditions2 For This Useful Post:
sparehair (04-07-2009)
Old 04-07-2009, 07:51 PM   #9
Organic Painter
Mr. Mike's Avatar
I'm going to tell my guys to start cutting in with an 18 inch roller. Let's move painters!
Mr. Mike is offline
Old 04-07-2009, 08:31 PM   #10
mad mike's Avatar
Trade: painting contractor
I use tape to hold up my wet paint signs (if I can find it).
mad mike is offline
Old 04-07-2009, 08:52 PM   #11
Workaholic's Avatar
The original OP has started a thread and then deleted his statement. Lame.
I use tape for masking off for stripes and what not, otherwise it is almost always a freehand day.
Sean
Workaholic is offline
Old 04-07-2009, 10:03 PM   #12
Organic Painter
Mr. Mike's Avatar
You will like this Workaholic,
I use frog tape when I paint stripes like the one on my profile picture.
Mr. Mike is offline
Old 04-07-2009, 11:11 PM   #13
sparehair's Avatar
Trade: Painting, flooring
Is the frog tape really worth it? 13.75 a roll? I could hire two mexicans to MAKE me tape for less than that. One to cut the paper. The other to apply the glue and roll it back up!
sparehair is offline
Old 04-08-2009, 05:20 AM   #14
A bit abrasive.
When I saw the price at SW, I couldn't think of one single use for it. Then I thought of my past vertical striping jobs and if I had used Frog tape, there is no way I could've price it in.
They must be crazy slinging tape at that price...unless it applies itself.
Old 04-08-2009, 06:49 AM   #15
Dan-Liquid Art Design
LAD's Avatar
Trade: Decorative Finisher
The plastic container it comes in makes for a perfect margarita salt rimmer.
www.LiquidArtDesign.com
LAD is offline
Old 04-08-2009, 07:30 AM   #16
Dave Mac's Avatar
I prefer the green tape myself, use it for base boards, when doing only the walls, wich is very often
Dave Mac is offline
Old 04-08-2009, 09:22 PM   #17
Side Effects May Vary
ModernStyle's Avatar
Trade: Professional Painting
I use tape ............
It keeps sprinkles off the base and if the room takes mutiple coats then it is worth it to me to tape it off. I have never used the frog tape, if I needed it then I would charge extra to cover it.
ModernStyle is offline
Old 04-08-2009, 09:44 PM   #18
I like Green things
WarnerConstInc.'s Avatar
The Frog tape is awesome. It is the only tape that will not pull the 'finish' off of cheap cabinets. No, I wasn't cutting in along the cabinet, I had plastic taped up over them, held on in a few spots with tape.
The blue tape pulls off the finish, froggy doesn't.
If you have an Ace hardware near you, they carry their own brand of green tape for about 1/2 the price and almost as good as the real thing.
What about the purple tape?
WarnerConstInc. is offline
Old 04-10-2009, 11:45 PM   #19
House Painters Reading PA
4thGeneration's Avatar
I use the blue tape as a shield when I tape off the top of the base line to the wall. I never buy into the spatter proof line from any paint producer because everything will have a drip of some kind. If you say you do not experience this then IMO you are not being truthful. This goes out to anyone who might say they have no drips from rolling.
Of coarse you could be slow as snail snot and could not possibly even pry your roller from the wall after it dries?
House Painting and Roof Cleaning by Sutton provides
House Painting Services in Berks county PA
for all Interior and Exterior Projects
484-334-3999
4thGeneration is offline
The Following User Says Thank You to 4thGeneration For This Useful Post:
WisePainter (04-11-2009)
Old 04-11-2009, 12:41 AM   #20
sparehair's Avatar
The type of paint and the roller determine how much splatter and mist you get. Crappy paint + crappy roller cover = half the paint on the wall and half everywhere else.
Does anyone use the Duratape Wet&Stick joint tape? Adv.wall.tech Drywall 16 05-10-2009 09:11 PM
What tape to use? nwksremodeler Drywall 12 02-04-2009 08:47 PM
Best Tape Measure Journeyman T Tools & Equipment 39 02-26-2008 02:14 PM
Help. Self Adhesive paper tape problem. jstrand23 Drywall 1 11-28-2007 02:09 PM
18 inch rollers and Tape Question dwbrooks Painting & Finish Work 52 09-08-2006 09:22 AM
