Re-Staining Wood Trim?
Old 08-06-2006, 10:45 AM   #1
ContractorTalk Flunkie
dayspring's Avatar
Question
I had a client ask me to re-stain and poly some edge trim on his countertop. Can this be successfully accomplished? The trim has been there several years and has has poly applied after staining when it was new. Seems to me the stain wouldn't penetrate the wood.
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 08-06-2006, 11:25 AM   #2
My custom title
Brushslingers's Avatar
Re: Re-Staining Wood Trim?
We refinish cabinets and doors all the time, trick is sanding down to nothing and reapplying the stain and finish.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 08-06-2006, 11:39 AM   #3
Teetorbilt's Avatar
It's done all of the time. I prefer to scrape instead of sand. For me, it's faster and doesnt leave behind 'the fuzzies' that sanding does.
For a color change, you'll need to bleach prior to staining.
Albert Einstein
Teetorbilt is offline
Old 08-06-2006, 12:33 PM   #4
My custom title
True, I use 250 grit for a final sand and then sandingsealer to kill the fuzzies.
Benn
Old 08-06-2006, 01:51 PM   #5
dayspring's Avatar
OK. I'll give it a shot. and they do want a darker stain.
T.C.
Old 08-06-2006, 01:54 PM   #6
dayspring's Avatar
Also, by sanding, are we talking all the way down to bare wood, or just removing the poly finish? Doen't seem to me that scraping would take all of the poly off, as some would get into the grain wouldn't it?
T.C.
Old 08-06-2006, 01:58 PM   #7
My custom title
I normally take it to bare and re-work it, but for something as small as you are talking about AND they want darker... i'd prolly hand sand enough for the wood to open up and run with it.
Benn
Old 08-06-2006, 02:05 PM   #8
dayspring's Avatar
Thanks man. Appreciate your advise.
T.C.
Old 08-06-2006, 02:13 PM   #9
unlicensed hack
maj's Avatar
Trade: wood butcher
I would be leary scraping on countertops. You could inadvertantly catch the laminate edge and gouge it or split it out. Sanding that little area won't create too much dust. It will mostly be poly dust which will most likely stick to the sandpaper anyway. As long as you are going darker, just remove the poly. Then even out the entire edge before staining.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread.
maj is offline
Old 08-06-2006, 02:18 PM   #10
unlicensed hack
maj's Avatar
Trade: wood butcher
Also, be very careful when staining the wood edging. The laminate top WILL absorb the stain. You may want to mask the edge so as not to get any stain on the top itself.
maj is offline
Old 08-06-2006, 02:23 PM   #11
dayspring's Avatar
Good point maj. I will indeed make sure it is masked off.
T.C.
wood filler vs. caulk for trim fabiano Painting & Finish Work 13 07-29-2006 03:09 PM
Staining interior Cherry trim cowtown Painting & Finish Work 8 04-25-2006 09:41 PM
trim coil over pressure treated wood?? Lt.H Windows, Siding and Doors 7 04-14-2006 12:12 AM
Staining a vinyl door that has wood trim (faux graining help) nahudso Painting & Finish Work 13 01-03-2006 10:04 AM
