Re-coating FPOE Door
Old 06-12-2013, 07:27 AM   #1
Pray4Surf's Avatar
Door was painting black brilliant about 10 years ago.
Anything special needed to prep?
Can I use a deglosser and then apply one coat or should I do two coats.
First time worki g with FPOE.
Thanks
Pray4Surf is offline
Old 06-12-2013, 08:56 PM   #2
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
Re: Re-coating FPOE Door
unable to interpret, could ya write in Russian or perhaps Chinese characters ?
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 06-12-2013, 09:34 PM   #3
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 482
Thanks
If oil based paint and using the same color, sand with fine sandpaper and use a deglosser, then one coat it. If surface is water based paint, sand and one coat it.
Caslon is offline
Old 06-13-2013, 04:19 AM   #4
or greek , how about latin ?
Old 06-13-2013, 06:16 AM   #5
Pray4Surf's Avatar
lol sorry. I just figured most painters were familiar with the brand, Fine Paints of Europe. I've never used it but all I hear is how difficult it is to work with. Not sure why. Guess I'm about to find out.
Caslon - I hope I can recreate that glossy finish with one coat. thanks
Old 06-13-2013, 03:15 PM   #6
Caslon's Avatar
Rewards Points: 482
Ah! FPOE can also mean First Point of Entry (as meaning the front door to a residence)
Additional coats don't relate to glossy-ness, unless you want to go CSI at the paint film level.
A primer might soak up some of the top coat and cause less gloss, but not usually.
Caslon is offline
Old 06-17-2013, 05:37 AM   #7
I had to google for ten minutes to figure the mystery and made a risky guess. It was foreign , that much was true.
fire rated door questions rtztgue Construction 1 04-10-2012 09:32 PM
Pre hung or slab door joekool02 Windows, Siding and Doors 8 02-29-2012 08:20 AM
shinny coating on front door ACLARK17 Painting & Finish Work 2 01-13-2012 11:17 PM
Door sill repair sbcontracting Windows, Siding and Doors 6 11-04-2011 01:06 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 12:27 AM
