Trade: interior paint contractor and window treatment workroom
Ralph Lauren Metallic Paint
Have to give an estimate for a room painted with Ralph Lauren Metallic paint. Never used this before and was wondering if their were any special requirements for putting this on the wall. Does it have to be sprayed?? Rolled?? Thanks lorna
Trade: Painter
Re: Ralph Lauren Metallic Paint
I've used it to paint a small bedroom cabinet. we only brushed it, it was fairly crappy stuff but very expensive. Take that into consideration when bidding.
Trade: Painting Contractor
I have rolled for stripes and have used it in faux finishes haven't had any big problems with it. Are you doing whole walls? I don't think that the roller marks will look good on a whole walls it doesn't level off on large areas very well, unless you are doing some type of decorative finish a stipple brush, cheese cloth etc..
MAK Deco |
rolling it on a whole wall....i heard from someone that you might get roller marks...any way to prevent that??
#5 | |
Re: Ralph Lauren Metallic PaintQuote:
No I haven't seen it done on a whole that looked good
MAK Deco |
Mike Danahy
Trade: Signature Painter
What is the end result supposed to look like? A solid metal? Like a nice piece of foil applied to the wall?....
If so... then I can suggest only that you tape everything, use a roller only, and roll like a mad man... multiple coats may be required. I have only fauxed using metallics myself... |
Can't say on the mettalic, although i have used RL on a whole room years back ( deep red ) Not my brand of choice, though not a whole lot bad to say either. They may have changed the formula since then
Sean |
Ya, i uesd it before also...
I applied it with a oustridge feather duster. (Over a base color) came out pretty cool.... ladies bathroom, could only see the effect from an angle or when light hit it... not head on. I have never rolled it... but I would guess you would treat it like gloss paint (wet edge) they also make a variety of rollers. you might want to check to see if ones suggested. |
| Ralph Lauren "suede" paint???? | bayoupainter | Painting & Finish Work | 10 | 09-03-2008 02:15 PM |
| ralph lauren suede paint | gjs | Painting & Finish Work | 12 | 06-05-2006 10:16 PM |
| Ralph Lauren Regent metalic paint | saucedo80 | Painting & Finish Work | 2 | 03-21-2006 11:22 AM |
| Dealing with flaking paint....help!!!! | Zeebo | Painting & Finish Work | 9 | 11-28-2005 11:03 PM |
