Rain After Staining Deck
Old 04-25-2005, 09:39 AM   #1
NormZ's Avatar
Trade: Enginieer
Question
After washing my deck with oxylic acid and waiting 48 hours, I stained my deck yesterday evening. No clouds and no rain in forcast. I awoke this morning finding that it rained most of the night and continues to rain now. I looked at my deck and found that the stain is peeling off in many places and everywere else it rubs off on my palm.
After the rain stops & it dries, what's the best solution to fix it. Can I just clean & apply a second coat? Or wash with oxylic acid again? Or do I need to use a stripping compound to entirely remove the first coat?
NormZ is offline
Old 04-25-2005, 11:39 AM   #2
premierpainting's Avatar
Re: Rain After Staining Deck
2nd coat should be fine
premierpainting is offline
Old 04-25-2005, 04:57 PM   #3
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
In my opinion it depends on the stain you used. Was it a penetrating stain or film stain? What was it?
Mike Finley is offline
Old 04-25-2005, 09:33 PM   #4
fez-head's Avatar
Trade: Contractor/ Business Owner/ Entrepreneur
Unhappy
I’m with Mike….if it was a film former strip it…if it was an oil based penetrating stain lightly power wash to even out the blotchiness and give it a very light recoat.
I would only use oxicilac acid to remove mill glaze and open up the pores of brand new decks. To clean unfinished decks that have weathered or for maintenance cleanings, I recommend a good deck wash containing oxygenated bleach (not regular bleach)
Sounds like a film former. I wish you luck
Jesse R. Kirchhoff
Advanced Power Washing and Restoration Solutions LLC
Professional Products ~ Professional Service ~ Professional Results
www.advancedpw.com
Kirchhoff Handyman Solutions LLC
“Making Your Life A Lot Less Complicated”
www.midmohandyman.com
fez-head is offline
Old 04-27-2005, 12:08 PM   #5
Richie-C's Avatar
Hate to sound ignorant, but what is a "film former"?? A latex-based product?
Richie-C is offline
Old 04-27-2005, 04:09 PM   #6
NormZ's Avatar
Trade: Enginieer
I used a latex based semi-transparent stain. As you noted, it did form a film which peeled of in places after the rain. So, I guess I should strip it off & start over
The deck was previously stained with a similar color semi-transparent stain (not sure if oil or latex) but was badly worn. My paint salesperson recommended the oxicilic acid wash before my initial application to make sure that the stain could soak into the wood.
Thanks for your advice!
NormZ is offline
Old 04-27-2005, 05:47 PM   #7
Chief Toilet Mover
The advice that we didn't get to is to avoid the film forming stain and just go with a penetrating stain. No matter what you put on it, sooner or later you will have to deal with it again so why not start with a product that will be way easier to deal with at that time?
Old 04-27-2005, 10:01 PM   #8
jiriki87's Avatar
I agree, avoid using a film forming stain on a deck. I'm a big fan of the Diamond Vogel Grain stain semi-transparent stain line. In Stbt Springs, CO the sun, snow combination is utterly brutal on exterior wood.
What do you other Colorado guys perfer?
Peter
jiriki87 is offline
Old 04-28-2005, 12:38 AM   #9
Chief Toilet Mover
Peter I have been using Penofin Exotic Hardwood stain on Ipe decking. Looks great but as usual out here in Colorado doesn't last very long. I would like to try some Cabots Timber oil and TWP, or is TWP a film too?
Old 04-30-2005, 09:46 PM   #10
S.W.C's Avatar
Yeah, if it's peeling you need to strip it again, otherwise you'll end up with a spotty deck.
Let in dry for a day afterwards, then apply a good stain.
I use Olympic Maxximum, semi-transparent, or solid.
It's guaranteed for 3 years. I have several decks I did with it 2 years ago, and they still look good. We've had a lot of bad weather since, but their still holding up well.
Also, if you use oxalic acid to strip, or anything else for that matter, make sure you rinse the deck very well to remove any excess chemical, then let it dry for a day before you apply the stain.
Usually that's what takes the longest, waiting for the weather to cooperate.
I've got one now that took me about 4 hours to get ready for stain, and I've been waiting over a week for the rain to stop long enough to stain it.
Believe me, it's worth the wait though. :Thumbs:
S.W.C is offline
Old 10-18-2009, 01:08 AM   #11
dejure's Avatar
Trade: finish carpentry
Mike Finley said it well. Said another way, it's not if you have to maintain it, it's when and how hard the maintenance will be.
Customers, and most of us in general, don't tend them as they should be (whether due to time constraints, cost, ignorance or whatever). As such, they become part of the problem.
Wood dries out over time, causing it to crack and split. That includes treated wood, which many homeowners and too many contractors think, of, erroneously, as some kind of magic solution to their degradation problems.
Some otherwise very knowledgeable pros say you can't "feed wood." That's bull. Wood impregnated with oils don't split and crack from drying. As an additional benefit, it won't rot. If hardening oil was used, it can be surface coated, if that is later desired.
I avoid treating horizontal surfaces with just surface sealers, which includes paint, every chance I get. I use oils, both hardening and non-hardening, depending on circumstance. For example, I would NEVER treat cedar roof shingles or shakes with other than unpigmented non-hardening oil. I would treat window sills and such with hardening oil, allow it to dry, then apply my prime and paint.
A penetrating hardening oil is going to give a second layer of defense. It can even be modified, such as by thinning with non hardening, oil to increase its flexibility under changing weather conditions.
Oils don't wear as good as paint and other sealers, but they are maintained with a fraction of the effort. They never require stripping of a prior coat before applying a new one, unless you are trying to remove the pigments added to them, which just rest on the surface (and in the pours). Straight oils don't leave lap marks. You can brush them, roll them, or spray them, even using a pump up garden sprayer (you are likely to have to thin), or a regular commercial sprayer.
In the end, oils need more frequent application than paint, but the simplicity of applications makes that tolerable in many circumstances.
dejure is offline
Old 10-18-2009, 12:53 PM   #12
House Painters Reading PA
4thGeneration's Avatar
You must have used a latex stain for it to wash off like that. Especially since you had it coated and it did not rain til after you went to bed. thats my guess since you said you did not know of the rain til you awoke.
I use Armstrong Clark and even after the rain it did not wash off.
House Painting and Roof Cleaning by Sutton provides
House Painting Services in Berks county PA
for all Interior and Exterior Projects
484-334-3999
4thGeneration is offline
Old 11-02-2009, 05:20 PM   #13
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
The finish can still get ruined. I have an A/C deck that was rained on. Stain applied in June, in September it was covered in black mold. Southern exposure..
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 11-02-2009, 05:37 PM   #14
Chris G's Avatar
Trade: Porch and Deck Builder
Should be about time for that 2nd coat. 3 years between application should do it, yep.
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is offline
Old 11-04-2009, 10:10 AM   #15
Kuba's Avatar
Trade: Painting - Restoration
solid stains > all
Kuba is offline
Tags
deck staining, deck washing
Solid body deck staining Mike Finley Painting & Finish Work 5 05-30-2007 10:52 PM
deck staining bigdawg Painting & Finish Work 9 03-06-2007 01:25 AM
Deck Staining Methods? JMG1959 Painting & Finish Work 11 02-22-2007 12:07 PM
Opinions on product for staining deck dwbrooks Painting & Finish Work 4 06-21-2006 07:13 PM
Deck Restoration & staining AHS Painting & Finish Work 2 05-10-2006 09:19 PM
