Trade: Painting / Decorative Concrete
Question For The Spray Guys
I don't spray exteriors, however on a job coming up i need to spray drip edge, fascia, soffit and the piano keys.
How do you guys protect the over spray from getting all over the roof? I would think laying cardboard on their and letting a little hang over the drip edge would stop it?? Thanks in advance for any tips. |
Trade: commercial building restoration
Re: Question For The Spray Guys
there are a couple ways.
1) if you are a really bad sprayer you should cover the entire roof. 2) you can put a guy on the roof (if its walkable) with a large piece of cardboard and have him hold it following along with you - watching for overspray 3) use a spray shield on a pole and move it along as you spray 4) if your a good spray guy just cut a line with the spray gun - wind may prevent this option 5) hire a professional make sure you pay attention to the wind. don't just run a couple runner tarps along the edge and think it will catch everything - you can end up with a line where the tarp stops that looks worse than a light mist covering the whole area. |
Thanks NAV! The roof is walkable so i think i'll go that way.
Trade: Painting & Flooring
I think Nav covered it. Using a 311 tip will help alot too.
Trade: painting
Another thing you can do is turn down the pressure.
#6 | |
Youngster
Trade: Builder / Consultant / Designer
Re: Question For The Spray GuysQuote:
HAHA... seen that one a few times. The line does look worse. Never on a soffit/facia paint though. My painter usually uses a 311 tip for soffit/facia. Not enough overspray to cause a problem. It's always the guys with the 517 tip spraying the siding who end up misting the roof.
native floridian
Trade: Aluminum Contractor & Painting Contractor
i use a 411 tip, new one works best
Screen Room, Pool Enclosure specialist |
#8 | |
Side Effects May Vary
Trade: Professional Painting
A 311 is what I go with also, that 517 tip is standard issue when you buy a new gun or pump, I have tons of them, too small to prime drywall, too big for anything else. |
Trade: Painting Contractor
Yep Nav covered it. I am a 310 guy myself.
Sean |
Trade: Painter
Check out the fine finish tips (Graco) you'll have reduced pressure and control.
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
517 here. I don't have any issues with it. Turning down the pressure a bit and angling it just right and cutting the trigger off at the drip edge prevents a full shot onto the roof. Lots of mini shots when close to the edge.
| question for tile guys | Hook131 | General Discussion | 7 | 02-10-2009 08:16 PM |
| Question for Vinyl Siding Guys | premierpainter | General Discussion | 12 | 02-10-2009 02:16 PM |
| Contract question | MACEXCAVATING | Excavation & Site Work | 4 | 12-20-2008 09:24 PM |
| Question for you siding guys | fr8train | Windows, Siding and Doors | 11 | 03-19-2008 03:41 PM |
| Quick question for you guys | 98mustangguy | Ceramic & Stone Tile | 1 | 03-16-2008 01:45 PM |
