Question For The Painting Gurus
Old 08-03-2006, 03:52 PM   #1
ricpacer69's Avatar
This restaurant that I usually do work for, had someone else come in and paint their front display counter. The counter was originally stained and polyed. They just painted right over the poly and you guessed it the paint is chipping off. My question is can anything else short of stripping it down be done to remedy this. The counter is pine wainscotting with a lot of moulding pieces to dress it up.
It looks good painted except for the chipping. I couldn't get in there in the time frame they wanted originally. They said next time they will wait. Thanks in advance.
Do you know the muffin man?
www.rhcontracting.net
ricpacer69 is offline
Old 08-03-2006, 05:10 PM   #2
KellyPainting's Avatar
Trade: Painting Contractor
Re: Question For The Painting Gurus
Stripping it would be the right way..... but you could always sand with 80 grit sanpaper.... take it down so that the poly is roughed up... then prime w/ oil... then 2 coats finish latex. let the oil dry for at least 24 hours though. the better the primer... the better the finish.
KellyPainting is offline
Old 08-03-2006, 05:19 PM   #3
Painting Contractor
Humble Abode's Avatar
Send a message via AIM to Humble Abode
I don't think you can get around stripping it. If they didn't have the sense to at least scuff the poly they probable didn't prime either. It's just a matter of time before it all comes off whether you paint over it or not.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 08-03-2006, 05:54 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
Strip it
Signature Quote
slickshift is offline
Old 08-03-2006, 06:07 PM   #5
My custom title
Brushslingers's Avatar
Strip. You can't get around that.
Benn
Originally Posted by Brian
Brushslingers is offline
Old 08-03-2006, 06:30 PM   #6
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
I'll third the motion for the pole dancer......er.....stripper.
ProWallGuy is offline
Old 08-03-2006, 08:05 PM   #7
Pro Painter
AAPaint's Avatar
Yup....think I just lost a job (we'll see) because it turned out to be well over $1500 for one room with paneling on the walls, and stain/poly tongue and groove boards on the ceiling, stained doors, and stained trim to do it right. I just couldn't stomach bidding the job cheaper and not being able to do the right thing which is sanding thoroughly, cleaning, priming, sanding, and top coating in my situation.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 08-04-2006, 07:43 AM   #8
ricpacer69's Avatar
Thanks, that's just what I thought. The other company didn't prime it or scuff it. The owner told me they just painted right over it. Thanks again I'll give him the bad news. There will be a lot of stripping going on I hope he has a lot of ones!
Painting Question lunaassoc Painting & Finish Work 1 06-29-2006 09:34 PM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 11:25 PM
Pricing for painting HELP!! Keefer Painting & Finish Work 9 03-16-2006 11:46 AM
