Old 05-01-2006, 08:12 PM   #1
Trade: Painting Contractor
Question about man hour rates
I'm getting ready to bid a deck job that I will pressure wash and stain. It's going to take roughly 30 man hours from start to finish. For my rates that equates to 30 X 40.00 = 1200.00 for the job. The stain I'm buying will be close to 300.00 in material. Should I add that 300 on to the 1200 or is that typically included in someone's man hour rate. Another words, is the material included in your man hour rates or do you add the material on after you've figured your man hour rates?
Dorman Painting is offline   Reply With Quote
Old 05-01-2006, 08:22 PM   #2
Don
donb1959's Avatar
Trade: Paint Contractor
The matierial is seperate, you're talking 1200.00 labor 300.00 matierial.
I fish therefore I am
http://www.shimmerz.biz
donb1959 is offline   Reply With Quote
Old 05-01-2006, 08:30 PM   #3
joasis's Avatar
Did you also consider the equipment cost in the bid or are you providing the power washing with the $40/pr/hr.? Sounds like you are just getting started or fishing a bid.
joasis is online now   Reply With Quote
Old 05-01-2006, 10:28 PM   #4
...jammin
slickshift's Avatar
Trade: Rock Disciple
...is the material included in your man hour rates or do you add the material on after you've figured your man hour rates?
Material is added to the man hours
As is equipment rental, sundries, any fudge factors or PITA charges
Oh yeah, and profit
Seriously, don't forget to add 15% for profit
Signature Quote
slickshift is offline   Reply With Quote
Old 05-02-2006, 09:22 AM   #5
Professional Remodeler
firemike's Avatar
Oh yeah, and profit
Very Correct! Otherwise you are giving the customer 7.5 hours for free if you include materials in the labor rate.
Also,
It takes time to pick the material up, time to load and unload the powerwasher and other equipment, the wear and tear on the equipment (someone has to pay for gasoline, oil changes, repairs, etc.)
What about material or equipment to apply the stain, that is a direct cost too.
Gas for the vehicle.
It all comes out of your pocket, so don't cut yourself short.
firemike is offline   Reply With Quote
Old 05-02-2006, 06:51 PM   #6
Pro Painter
AAPaint's Avatar
Just out of curiousity, when you say pressure wash....what do you mean? What type of wood is it? Is it new wood? Un-treated, or previously stained? Pressure treated or not? The only time I would just pressure wash and stain is if it's relatively new wood. Otherwise, you might need to use at least a percarbonate cleaner followed by a brightener. Keep the pressure between 800-1200 psi MAX and hopefully you won't have much furring.
I just get nervous when I hear "pressure wash and stain" when it comes to exterior wood. There are too many people destroying beatiful wood with the wrong processes.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline   Reply With Quote
Old 05-02-2006, 08:50 PM   #7
Trade: Painting / Decorative Concrete
AA...Would you explain the procedure with the percarbonate cleaner and brightener... Are you applying with a pump sprayer or with PW. We have a log cabin that is cedar and what painted, with what else HD bear stain... Gosh I hate to see such nice wood painted...
Guardi Pro is offline   Reply With Quote
Old 05-02-2006, 10:14 PM   #8
Pro Painter
AAPaint's Avatar
You can apply with pump up sprayers. We are using them on a cedar home right now. Make sure it's all plastic!! Or you can invest in a sureflo pump setup which is basically a tank, hoses, pump, and battery that pumps chems for you.
If it's got Behr stain on it, it's gonna be hell, but you'll need a sodium hydroxide stripper like Timberstrip Pro and probably a couple of applications. You simply spray it on, let it dwell 15-20 mins keeping it wet, do NOT let it dry. Once it's sat, hit it with the pw and the 800-1200psi I mentioned. The old stain should just run right off if you're lucky. Strip it all down quickly with the pw, then rinse, rinse, rinse. Once you're done, spray on the brightener (you can use TimberBright Pro, both found here: http://www.deckguide.com/product2-1....on%20Chemicals Let it dwell for the same amount of time, and give it a good rinsing again. When you apply it, the wood will literally change colors right before your eyes. When it dries, you have brand new wood, if done right.
TEST with a moisture meter to be sure it's below 12% moisture and then stain with your favorite penetrating oil stain.
-AAPaint
Jacksonville, FL.
-James Madison
Old 05-03-2006, 04:42 PM   #9
Thanks AA
Old 05-03-2006, 06:35 PM   #10
It is a fifteen year old deck that is totally greyed out for the most part. It is treated wood which is the standard for building decks. I pressure washed it yesterday and it came out fine. All of the grey came off and it's ready to seal up. I use much more pressure than 1200 PSI and don't have problems with furring. Hell, if I used just 1200 PSI I'd be on the deck for a week trying to clean it. No sense in making the job tougher than it already is IMO. Furthermore, it's an exterior deck, not an interior door jamb that should be smooth as silk.
Question about bidding vinyl wallcovering kanadaeh Painting & Finish Work 9 02-19-2009 05:29 PM
How to go from Low to HIGH/RIGHT pricing! Paul Burns Painting & Finish Work 2 08-27-2006 05:18 PM
Day Rates donb1959 Painting & Finish Work 20 02-20-2006 01:37 AM
