Old 04-11-2006, 12:53 AM   #1
Trade: General
quarter round for wall/ceiling joints? (merged)
I'm in the process of building my own home and have run into a small problem of sorts. Where the ceiling and the walls meet in certain darker colored rooms I'm having a tough time cutting the colored wall paint to the white ceiling. The ceilings and walls are both knockdown texture, and it's really hard (for me anyway) to make that crisp straight paint line. I was thinking of running a straight piece of quarter round (1/2") around the ceiling to create the straight line look. I could paint it ceiling white or the color of the particular room to blend it in. Is this a viable solution or has anyone ever done this before? I don't really have the extra money for regular crown molding, but I don't want the quarter round to look cheap either. Any solutions or help would be appreciated.
pmbarber is offline   Reply With Quote
Old 04-11-2006, 01:15 AM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
For me it would be using a paintable caulk with the tape, but the pro painters will be along, and those guys could paint it using a white washing brush on a 10 foot pole standing in the middle of the room and get a perfect line.
bathroom remodeling - Denver, Lakewood, Littleton, Arvada, Westminster, Centennial, Highlands Ranch, Lone Tree, Englewood Colorado.
Originally Posted by Ahren View Post
Citibank BK Jan 2010, Dow 3000 Q1 2010,FAZ is about to go through the roof, stagflation, hyper-inflation, Jan 2010 $2.00 C puts
Mike Finley is online now   Reply With Quote
Old 04-11-2006, 02:08 AM   #3
Redman's Avatar
Trade: Remodeling/Painting
Send a message via MSN to Redman
Are You Using A Top Quality Brush, And Are You Trying To Cut It In Perfect In One Coat?
One day at a Time.
Redman is offline   Reply With Quote
Old 04-11-2006, 11:11 AM   #4
Heavy Weight Champ
King of Crown's Avatar
Trade: finish carpentry
1/4 round is very thin, and unless you are putting it against a wood beam, it looks like crap. also, becasue of how thin the 1/4 round is, it will expose how uneven the drywall is. so dont do it.
Real nice guys
King of Crown is offline   Reply With Quote
Old 04-12-2006, 02:44 PM   #5
MODERATOR
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Without sounding like an a$$, the best fix for this is:
Hire a good painter.
ProWallGuy is offline   Reply With Quote
Old 04-12-2006, 03:02 PM   #6
Trade: Hanger taper finisher painter
Thin your paint with water (assuming its waterbased paint) so its not so thick. Also it might be difficult but often the actual corner of drywall is uneven so even if you do go exactly in the corner it will still look uneven to the eye. So you may try staying away from the corner a 1/16 or an 1/8 of an inch. Look at the line of unpainted surface your leaving and not the actual paint line. As long as your ceiling paint was on your wall a little before you do this. They eye will see the line of ceiling paint on the wall as the straight line. So its what your not painting that is what your eye sees. The quality of these pictures are not very good. But maybe you get they idea??
johnjamesalaska is offline   Reply With Quote
Old 04-12-2006, 03:39 PM   #7
jack of all, master of 1
Trade: carpenter/roofer
Or get a roll of tape?
snapper21 is offline   Reply With Quote
Old 04-12-2006, 05:52 PM   #8
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
I wouldn't recommend the staying away bit if that's what it looks like. It's absolutely blatantly obvious your line is run down on the wall, and IMHO, it looks bad. Cutting in a ceiling line properly takes proper perspective. You need to constantly watch as you drag your brush looking from one angle straight on at the ceiling and the other angle, straight on at the top of the wall. It's an art, and I agree with PWG...if you want it RIGHT, hire a professional. Those lines should look like this:
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline   Reply With Quote
Old 04-12-2006, 06:14 PM   #9
I agree that running your paint lines down the wall a bit looks bad. Even when the line is perfectly straight, it still looks like the painter didn't finish painting the wall. If the drywall lines are bad, it's best to run your wall paint up onto the ceiling a bit and make your own line there IMO.
CarlW is offline   Reply With Quote
Old 04-12-2006, 08:54 PM   #10
I knew I was going to get some negative responses for that suggestion.
Its really easy to cut a straight line up to the ceiling for a painter but I guess one would have to see it in person to get the idea. Pictures dont really do it justice. I see alot of jobs were the painter cuts that perfect line up to the ceiling but because the inside corner is not perfect you can see the that its uneven ...even more. It just depends on the circumstances. It sounds likes a bad way to do it but 9 out of 10 of my customers really like the look. Its a small line that i'm talkin about. About this wide (arrow to arrow) ----- > <-------- .....Its an optional illusion But really cutting into the ceiling exactly like the above post suggest is alot easier and alot better than quarter round. Juice up yer paint. Just a little.
Old 04-13-2006, 07:14 AM   #11
Pro Painter
AAPaint's Avatar
According to those pictures, there is no optical illusion. It looks like a half inch wide line of white at the top of the walls, and is far from a professional finish. Your customers may be ok with it, but if anybody did that on one of my jobs I'd fire them. It looks like you completely missed the top of the wall, and the over-run of ceiling paint is way to obvious.....just going off your pictures, it sticks out like a sore thumb.
-AAPaint
Jacksonville, FL.
-James Madison
Old 04-13-2006, 09:39 AM   #12
Ya your right about the line being to thick on the second picture. Its my house and I wouldnt do it that thick on a customers home. But I did notice your paint line is uneven to the left side of your picture which is why I some times ..not in all situations ..come down a touch. I dont do this line on all walls. Just certain situations.
Old 04-13-2006, 07:27 PM   #13
Pro Painter
AAPaint's Avatar
Actually, that line is straight, what you see is where the popcorn protrudes over which is common. There is a small gap behind the popcorn from the knife the texture guys used to scrape the walls...nothing more.
-AAPaint
Jacksonville, FL.
-James Madison
Old 04-14-2006, 01:11 AM   #14
Oh IC I was wondering what that was. Its hard to tell with digital pictures like on the inside corner ..it looks wavey but digital pictures can have that effect .
Azek butt joints holding up? LeonardDB Finish Carpentry 39 11-28-2009 08:30 PM
Question with quarter round haskl33 Carpentry 14 05-31-2008 06:49 AM
Tiling over Concrete Expansion Joints Clueless Ceramic & Stone Tile 16 11-25-2007 11:48 PM
Hardwood Floor Pattern and End Joints 4yanx Flooring 25 07-29-2007 06:14 AM
quarter round Ian Flooring 17 11-20-2005 11:57 PM
