Purdy Colossus Roller Covers
Old 01-27-2009, 08:52 PM   #61
Youngster
Cache's Avatar
Trade: Builder / Consultant / Designer
Re: Purdy Colossus Roller Covers
Originally Posted by Workaholic View Post
Because of the finish application. When a wall is damaged by the electricians or the plumbers then the HO will have to accept some roller work when the wall is repainted.
Ahh .. I see what you are getting at.
Touch-up of satin and semi-gloss paints = not fun but doable.
Touch-up of satin and semi-gloss paints without use of roller = nightmare!!!!
Cache is offline
Old 01-27-2009, 08:52 PM   #62
A bit abrasive.
WisePainter's Avatar
we were all typing at the same time.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 01-27-2009, 08:53 PM   #63
A bit abrasive.
Yes.
Touching up a semi is about the worst.
Old 01-27-2009, 08:53 PM   #64
Workaholic's Avatar
Trade: Painting Contractor
Originally Posted by WisePainter View Post
What is a "PITA"?
Pain In The Ass
Sean
Workaholic is offline
Old 01-27-2009, 08:53 PM   #65
Youngster
Cache's Avatar
I spray the garage and closet walls when spraying new work i back roll everything though. Other than that it is all brush and roll (except for the trim that is)
You spray trim?
Cache is offline
Old 01-27-2009, 08:54 PM   #66
A bit abrasive.
Pain In The Ass
Not a bread like customer that makes a great avocado sandwich then?
I will use that term in the future.
Old 01-27-2009, 08:57 PM   #67
Workaholic's Avatar
You spray trim?
Absolutly as much as i can. Top layer of crown where the crown is at the ceiling gets brushed lower is sprayed. Windows are brushed. wainscott and doors jambs and anything else is usually sprayed. This is new construction i am talking about. If it is an occupied repaint that is a different deal.
Sean
Old 01-27-2009, 08:58 PM   #68
Youngster
Cache's Avatar
I would recommend the Colossus because the nap is more like yarn, so it is possible to tip off the wall on the finish back roll which in turn does not leave a stipple. The average roller cover piles up on itself and becomes matted, almost like rolling a wet terrier all over the walls.
That may be what your HO is afraid of having had a painter in the past neglect to back roll.
Ask them why they desire a smoother than smooth finish and listen carefully to his words.
Maybe, what she described when I spoke to her sounded sorta like what happens with a cheap cover and and "single-coat" paint. But she kept calling it stiple.
I'm not a painter, but rather just have a close relationship with my painter and help out sometimes. Not familiar with the term "tip off"?!
Cache is offline
Old 01-27-2009, 09:03 PM   #69
Youngster
Cache's Avatar
I've seen a couple different procedures for painting. As I mentioned, I have a close relationship with the painter and we work together frequently. Sometimes I look at his process and it seems like it could be sped up a bit if he changed the order of things. Especially since I will work with him on the trim install. I don't want to hijack this thread with off-topic requests, but would you mind PMing me your usual procedure so I can compare and see if I can save hime some unnecessary masking/brushwork?
Cache is offline
Old 01-27-2009, 09:03 PM   #70
Workaholic's Avatar
Well what is your painters plan of attack? Or is he not feeling up to the task?
Sean
Old 01-27-2009, 09:08 PM   #71
A bit abrasive.
Strike 1
Never micromanage your subs, I have a GC that is tries that cr@p everyday.
Strike 2
Sorry buddy, gigs up. You are trying to find ways to micromanage your painter.
I cannot help you any further.
Strike 3
Just because there technically has to be 3 strikes.
Old 01-27-2009, 09:09 PM   #72
Workaholic's Avatar
Strike 1
Strike 2
Strike 3
Sean
Old 01-27-2009, 09:13 PM   #73
Youngster
Cache's Avatar
Basically, he wants to:
  1. Prime/backroll everything.
  2. Caulk
  3. Spray trim (crown, base, door/window casings, etc)
  4. Mask base
  5. Cut in ceilings; roll
  6. Cut in walls; roll two coats
The amount he would charge to mask and spray everything is probably a deal breaker. He is thinking he would have to.
  1. Spray Prime everything
  2. Spray trim
  3. Mask Trim
  4. Spray Walls while shielding Ceiling (3 coats)
  5. Mask Walls
  6. Spray ceiling (3 coats)
Cache is offline
Old 01-27-2009, 09:17 PM   #74
A bit abrasive.
  2. Caulk
  4. Mask base
  2. Spray trim
  3. Mask Trim
  5. Mask Walls
Darn you, only this once...
You have a smart painter listen to him, stand up to the HO and get the job done.
Old 01-27-2009, 09:19 PM   #75
Youngster
Cache's Avatar
Strike 1
Strike 2
Strike 3
Not trying to micromanage him. He is a family member and his work is really slow right now so he's helping me with trim work lately. Just wondering if I could do trim differently (ie a different process) that would eliminate some of the time consuming aspects of painting. The situation with the smooth walls is legit. Sorry to hijack your thread and upset you.
Cache is offline
Old 01-27-2009, 09:20 PM   #76
Workaholic's Avatar
That is a very unusal relationship. You mean you actually help him do his job? I did not even know that GC's work.
If he is brushing trim in new work no doubt things could be speeded up.
This is some pretty pricey info do you have a PayPal account.
I do all my prep work first.
Sean
Old 01-27-2009, 09:23 PM   #77
A bit abrasive.
No problem, it would have helped if you were more forthcoming with the info up front.
Old 01-27-2009, 09:27 PM   #78
Youngster
Cache's Avatar
One time I saw a remodeler who painted ceiling and walls first, kinda sloppy at the wall/ceiling juncture. Then rather than mark lines for crown moulding on the painted wall, he would run a strip of 2" blue tape along the wall and ceiling so that when the crown was intalled it overlapped the tape strips by 1/2" and there was still 1 1/2' of tape showing on the walls and ceiling. Then he would brush the trim without taking his time next to the walls and ceiling as there was already tape there. When finished, he would take his knife anad trim off the tape.
He claimed it saved him time on the cut in and solved the problem of bleed around the tape on textured walls. It was no problem for him because he was doing both the trim and the paint. Just wondering if there were similar things that could be done if a painter and trim carpenter are working side-by-side.
Cache is offline
Old 01-27-2009, 09:33 PM   #79
Youngster
Cache's Avatar
That's below the belt. Try to keep the gloves up. But to be honest, he helps me more often than I help him. Anyway, you want to know weird relationship. My drywaller shows up the other day and brings one of the other local homebuilders with him because the guy had no houses going and needed the extra cash. Not a half bad taper for a builder.
No, he usually sprays trim. But I've seen him brush certain trim like windows and doors.
Sorry, times being what they are and everything. You know how we stingy GCs are.
Cache is offline
Old 01-27-2009, 09:38 PM   #80
A bit abrasive.
They should never be mixed.
I need the trim guy finished and out of my way when it comes time to sling paint.
Cutting tape means cutting into the wall, not a good solution.
Storing roller covers Teetorbilt Painting & Finish Work 11 01-01-2009 08:15 AM
Sheepskin roller covers... Really this tough?? steve-in-kville Painting & Finish Work 11 05-24-2007 08:45 PM
What kind of Roller Covers do you prefer dwbrooks Painting & Finish Work 79 02-25-2007 06:58 PM
Roller covers Cat_painter Painting & Finish Work 5 02-22-2007 11:46 PM
What size roller covers? metomeya Painting & Finish Work 10 11-28-2006 06:48 AM
