Proposals......
Old 11-20-2006, 12:04 AM   #1
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Proposals......
Here is what a typical proposal from my company looks like. Please feel free to post others. This is part of the topic from Sunday's chat.
5291 Collins Rd. #337
Jacksonville, FL US 32244
Phone: (904)622-8466
Web Site: www.aaqualitypainting.com
Email: info@aaqualitypainting.com
Contract #6112
November 01, 2006
Mr. Customer
123 Your St.
Jacksonville, FL 32205
Dear Mr. Customer,
In regards to the single family home, located at 123 Your St., Jacksonville FL, the undersigned proposes to complete all work described below:
This contract includes the following materials and/or labor.
·Surface preparation as detailed in this proposal. Our preparation processes leave nothing out. Painting is 90% preparation, 10% paint.
·Door frames puttied, caulked, sanded, wiped with a tack cloth and painted.
·Trim puttied, caulked, sanded, wiped with a tack cloth and painted.
·Baseboards puttied, caulked, sanded, wiped with a tack cloth and painted.
·This contract will include one trim color and 5 wall colors of the customer’s choice.
·All necessary materials including but not limited to primers, paints, sanding materials, putties, caulks, tape, plastic, drywall compound, rags, roller "naps", etc.
·All necessary labor to complete entire scope of work outlined in this contract.
·Miscellaneous repairs. We will fix all noticeable minor imperfections in the walls including nail holes and dings or gouges.
·All switch plate and outlet covers will be removed during painting, and re-installed when complete.
·All areas will be thoroughly vacuumed once painting is complete and large furniture moved by us will be returned to it’s proper place.
·Tarps, poly, drop cloths and coverings. Anything not being painted will be properly protected or masked in a professional manner. We use only clean drop cloths in your home that we reserve for interior use only. We have other drop cloths specifically for use outside, and wouldn't think of using those in your home.
·Previously painted surfaces where the existing coating is not failing: Walls with heavy nicotine build-up, grease, dirt, dust, grime, etc. will be cleaned with a tsp/water or an ammonia/water solution to remove any contaminants and provide a clean surface for the new paint to adhere to. All previously painted walls will be pole sanded with 150 grit sandpaper to de-gloss the surface and ensure good adhesion of our new paint. Pole sanding also removes most “trash” or foreign objects attached to the wall during any previous painting. The walls will then be wiped down or vacuumed to remove any dust from sanding. All nail holes will be filled and any imperfections will be skimmed and sanded. After all patches have been applied and sanded those areas will be primed with Sherwin Williams Prep Rite Pro Block Interior Latex primer. Two top-coats of the specified paint will be applied for proper color representation, surface coverage, and film thickness.
·All trim will be puttied to fill nail holes and imperfections. Trim will then be sanded to ensure a smooth, clean finish. After sanding is complete all trim will be wiped with a tack cloth to remove any dust, and will then be caulked as needed prior to finishing.
·Sherwin Williams Duration Home Interior Latex paint will be applied to all wall surfaces in the customer specified colors for each area. This is a low VOC, low odor “green friendly” paint. It was rated #1 by Consumer Reports. This paint goes on twice the thickness of normal paints, and uses a patented cross linking technology to give it supreme durability and burnish resistance, as well as stain hiding capabilities. Duration is Sherwin Williams’ top of the line interior paint, and as such has received the benefit of the company’s 140 years of paint technology. Sherwin Williams backs Duration Home Interior with a Lifetime Guarantee on the paint. It is our preferred paint for good reason!
·Trim will be painted with Sherwin Williams Pro Classic Waterborne paint. This is a high quality paint that will provide a beautiful, lasting finish on any trim surfaces. Pro Classic gives the look and durability of an oil based finish in a product that cleans up with water.
·Caulk used will be Sherwin Williams 1100A 55 year siliconized latex caulk.
Detailed Project Specifications:
Included Warranty Period: 2 Year Guaranteed against defects in the quality of our workmanship.
Living Room Approx. Area: (336 sq.ft.)
Includes the following:
2 coat(s) of Duration Home Interior Satin Latex.
Foyer Approx. Area: (336 sq.ft.)
1 coat(s) 3" Crown Moulding - SW Pro Classic Waterborne Semi-Gloss.
1 coat(s) 3" Trim, SW Pro Classic Waterborne Semi-Gloss.
1 coat(s) of Popcorn ceiling, ProMar 400 Flat White Latex.
Den Approx. Area: (416 sq.ft.)
Dining Room Approx. Area: (432 sq.ft.)
1 coat(s) 2" Trim, SW Pro Classic Waterborne Semi-Gloss.
Sun Room Approx. Area: (528 sq.ft.)
1 coat(s) 4" Trim, SW Pro Classic Waterborne Semi-Gloss.
Comment: Include sanding/stripping skylight boxes and rear french doors, and other trim to be color matched (customer must approve color prior to complete staining) and re-polyurethane in a high gloss sheen. Color: Early American Minwax stain.
Family Room Approx. Area: (480 sq.ft.)
Bathroom Approx. Area: (256 sq.ft.)
Master Bedroom Approx. Area: (528 sq.ft.)
Master Bathroom Approx. Area: (208 sq.ft.)
Master Walk-In Closet Approx. Area: (256 sq.ft.)
1 coat(s) of Duration Home Interior Satin Latex.
Hall Approx. Area: (352 sq.ft.)
Kitchen Approx. Area: (544 sq.ft.)
Includes ceiling only. All walls will be draped with plastic to protect them from damage and sprinkles during the painting process.
Hall Approx. Area: (624 sq.ft.)
Bedroom Approx. Area: (928 sq.ft.)
Bedroom Approx. Area: (384 sq.ft.)
Work Room Approx. Area: (336 sq.ft.)
Extras
Sand old finish and re-stain trim around skylights in sunroom
Move furniture (per job)
Tarp and cover furniture
Paint trim in downstairs hall bathroom with specified trim paint.
All of the above work to be completed in a professional manner that shall meet or exceed accepted industry standards for the sum of:
SUB TOTAL: $***X.XX
TOTAL: $***X.XX
You are hereby authorized to furnish all materials and labor to complete the work mentioned in the above proposal, for which the undersigned agrees to pay the amount mentioned in said proposal, and according to the terms thereof:
Payments are to be made as follows:
First draw: $***X.XX Due: This payment is required as a deposit to be put on our schedule. Deposits must be received immediately to reserve a spot on our schedule. Please remember our scheduling is on a first come, first serve basis. Due to high demand, we can not guarantee a spot on our schedule without your deposit.
Second draw: $***X.XX Due: This payment is due after completion of all prep work as outlined in this proposal, or at a halfway point to be determined by the job supervisor from our company. For all projects, second payment will be due no later than 7 calendar days after the commencement of work.
Third draw: $***X.XX Due: This payment is due immediately upon substantial completion of the scope of work as outlined in this proposal. At time of completion a walk-through will be performed with the customer. Any defects, touch ups, and ONE final “bump” are included as part of this contract. These items will be addressed at this time, but shall not delay this final payment.
Some of this stuff I learned or got from other people, but the format is done by my estimating software, and most of the outline is my own. This is pretty much exactly what the customer sees minus all my contract terms and disclosures.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 11-20-2006, 12:10 AM   #2
Painting & Restoration
GoodPainter's Avatar
Re: Proposals......
this is my simple proposal
Job Location: Penn Valley Village, Manheim
General Work to be performed:
____Farmhouse Exterior Trim--- All One coat Primer, One coat Finish______________________
____Trim work at roof line- 3 up to peaks 2 stretches_____________________________________
_____15ft and 5ft of Overhang/Soffit __________________________________________________ __
____7 Posts___________ _ ________________________________
_____1st Fl___4 door trim Front Bay Window___________________________________
_____2nd Fl 1 door trim and Appox. 6ftx8ft Wood siding______________________$1500.00___
Other:____Additional 18 1st FL and 15 2nd FL windows _________________________________
_______Customer/Tenant to remove storm windows____For Painting/Prep_ ___$1100.00____
Comments / Conditions:_______________________________________ ___________________________
________Additional___4 Attic Windows__and Approx 6 Old-Style Farmhouse Windows(9-pane)
Special Instructions:_____________________________________ ___________________$400.00_____
___BenMoore Fresh Start Primer--BenMoore SoftGloss Ext Brilliant White_________________________
__________________________________________________ _______________________
ROBERT GOOD PROFESSIONAL PAINTING
25 S 9th ST 1st FL
AKRON, PA 17501
717-278-2663
717-278-2400
CONTRACT FOR PROFESSIONAL SERVICES
CONTRACTOR AGREES TO PROVIDE ALL LABOR, MATERIALS, SUPPLIES, TOOLS AND EQUIPMENT TO PERFORM AND COMPLETE THE WORK DESCRIBED IN THIS AGREEMENT
TOTAL CONTRACT PRICE:
START DATE:
PROPOSED FINISH DATE:
PAYMENT SCHEDULE:
1/3 OF TOTAL PRICE DUE UPON SIGNING $
1/3 OF TOTAL PRICE DUE AT SPECIFIED DATE: $
1/3 OF TOTAL PRICE OR REMAINING BALANCE DUE AT COMPLETION $
TERMS AND CONDITIONS
ACCESS TO THE JOB SITE:
Customer understands and agrees that access to the job site must be provided between 7 a.m. and 5 p.m. Monday thru Friday, for the whole duration of this job. Any hours other than these expressed will be agreed upon, either written or verbal, between the Customer and the Contractor. Customer agrees and grants permission to Contractor and Agents to enter upon said job site and property. If for any reason access is not available, the Customer must give 24 hours with verbal notification either in person or phone/voice mail at telephone numbers above.
CUSTOMER RESPONSIBILITIES:
Customer will assume all responsibility to remove any and all household and personal items from work area during the duration of the job. Contractor will not be held liable for damage to such valuable or personal items not removed from the work area. Large items such as sofas, beds, dressers, etc. will be moved by the Contractor at no charge to the Customer (unless specified otherwise). Contractor will not be held liable for any damage caused by moving any items.
Due to safety procedures and insurance regulations, the Customer agrees to not allow children, pets, and any individual to enter the work area unless agreed upon by Customer and Contractor. The Customer shall not schedule or allow activities by other contractors, worker, pets or individuals that will interfere with the timely and successful completion of the work by the Contractor. The Contractor will not be held liable for any damage caused to the work or work area by anyone other than the Contractor or Employees/Agents. The Customer is liable to the Contractor at the rate of $50.00 per man hour to correct all such damage.
CUSTOMER RIGHTS:
The Customer has the right to cancel this service agreement within Three (3) business days from the date of signing. If the Customer wishes to do so, they must contact the Contractor and complete a Cancellation Form. Upon signing the Form, the Contractor will return 100% of any deposit within Seven (7) business days. If cancellation is made after midnight of the Third (3rd) business day, the Contractor will retain 10% of the Total Contract Price.
CHANGE ORDERS/EXTRA COSTS:
This written contract may only be changed in writing. Additional work will only be performed at extra cost to the Customer. Additional work to be approved by the Customer and the Contractor by signing of a Change Order Form.
If Customer would like something in addition or added services, this Change Order Form will be in writing and signed.
PROMOTION:
The Customer authorizes the Contractor to display a sign for the duration of the job and up to Five(5) days after completion. The Customer authorizes the Contractor to take and use photographs of the job site for display, promotion and advertising, without compensation to the Customer. (Unless otherwise noted)
INSPECTION OF COMPLETED WORK:
Upon significant completion of all work, the Customer agrees to conduct an inspection of the work contracted with the Contractor. At this time, all defects and uncompleted areas should be noted to the Contractor. This inspection must occur under normal lighting conditions, from a normal viewing position, without magnification.
MANUFACTURERS SPECIFICATIONS/ INDUSTRY STANDARDS:
Al materials will be applied, installed or used according to the manufacturers specifications, directions and instructions. All surface preparation, coating application and installation of all materials will follow industry standards.
INSURANCE:
Robert Good Professional Painting Contractor holds a personal One Million Dollar ($1,000,000) Liability Insurance Policy to insure the Customers home and property that any liable claims the Contractor is held responsible for. A copy of this Insurance Certificate is available upon request from the Contractor.
WARRANTY:
Contractor warrants that all products or material will be of standard or above standard quality. Labor is warranted for a period of two (2) years after the date of completion. All product and material warranties vary, but will be extended to the Customer after full payment for work completed. Contractor liability under this warranty claim will not exceed the Total Contract Price charged for the work performed. Customer must make warranty claims immediately upon discovering the defect, failure or performance problem. In the event that the substrate or any prior coating fails beneath what the Contractor has installed or applied, the Contractor will not be held liable for the failure. The Contractor makes all necessary effort to prepare and omit future failure, but cannot warrant or guarantee any prior coating or substrate.
Failure to comply with the terms, conditions and payment schedule of this agreement will void any and all warrantees.
LEGAL NOTICE: UNLESS AGREED TO IN WRITING PRIOR TO START OF WORK: PAYMENTS MUST BE RECEIVED PROMPTLY. ANY PAYMENTS DELINQUENT SEVEN (7) DAYS FROM DUE DATE, WILL BE ADDED WITH A LATE CHARGE OF $25.00. ANY PAYMENTS DELINQUENT THIRTY (30) DAYS FROM DUE DATE, WILL BE ADDED A MONTHLY FEE AND IF NESSESARY THE UNDERSIGNED CUSTOMER WILL BE RESPONSIBLE FOR COLLECTION, COURT AND ATTORNEYS FEES.
DISCLAIMER NOTICE: WORK TO BE PERFORMED AS SPECIFIED, PRACTICING IN A PROFESSIONAL MANNER, AT OR EXCEEDING WHAT IS CONSIDERED AS NORMALLY ACCEPTED INDUSTRY STANDARDS. THE CONTRACTOR CAN NOT BE HELD RESPONSIBLE FOR UNAVAILABLE MATERIALS, WORK STOPPAGES, RIOTS, MISCHIEF, THEFTS, ABNORMAL AND/OR SERVERE WEATHER OR ACTS OF GOD. THIS NATURE IS OUTSIDE OF THE CONTRACTORS CONTROL.
EVERY EFFORT IS PRACTICED TO STOP OR CONTROL MOLD/FUNGI. THE CONTRACTOR WILL NOT BE HELD LIABLE FOR THE REOCCURANCE OR GROWTH OF ANY FORM OR TYPE OF MOLD/FUNGI.
The Customer has read, understands and agrees with the total payment schedule and the terms and conditions as shown in this Agreement and Contract for Professional Services.
In understanding with the above stated agreement, we do hereby agree to the terms as outlined, and authorize the Contractor to commence work.
________________________ ____________ ________________________ ____________
Robert Good Contractor Date Customer Owner Date
Robert
Robert Good
It's Your Life-Make Fun Of It!
http://www.robertgoodpainting.com
GoodPainter is offline
Old 11-20-2006, 12:35 AM   #3
My custom title
Brushslingers's Avatar
Re: Proposals......
This is my simple one, I always type in "see attached" for the scope of work.
QUOTATION, PROPOSAL AND CONTRACT
Person to perform work (Supplier) Brushslingers1540 Glenway Dr.Tallahassee, FL. 32301 Person authorizing work (Owner)
Date Prepared for: Credit Terms
Description of work:
1. Total Price of Labor............................................. .............................................. $ _____________
2. Materials Required:No. Description Cost per Item Amount1. __________________________________________________ _______________________________2. __________________________________________________ _______________________________3. __________________________________________________ _______________________________4. __________________________________________________ _______________________________5. __________________________________________________ _______________________________6. __________________________________________________ _______________________________7. __________________________________________________ _______________________________ [ ] Additional Pages AttachedTotal Cost of Material $________________
[ ] Materials to be furnished by workmanTotal Cost of Material $________________
[ ] Materials to be furnished by owner.Total Cost of Material $______________________
[ ] The quotation shall not be considered final at this time.
[ ] The quotation shall be used as an agreement for work.
For valuable consideration, owner does authorize supplier to perform specified work as described above. All work shall be performed in a substantial and workman?like manner. Compensation will be paid in accordance with the terms listed for a total of $_____________
Payment Terms.
Additional Provisions:
Any additions, alterations or deviations for the above specifications involving additional cost to owner shall be executed only by written authorization of owner.Disputes. All disputes will be handled by the parties as quickly and fairly as possible. All information regarding the dispute shall be held confidential until the matter is resolved, and every effort will be made to keep the matter out of court.
Man my formats all messed up... well you get the picture I suppose.....
Benn
Originally Posted by Brian
Brushslingers is offline
Old 08-25-2007, 09:47 AM   #4
Central Building Finish
roddy's Avatar
Trade: paint
Re: Proposals......
Central painter / what is a good software for estimating that you guys have found thats not overly priced
roddy is offline
Lack of details in compeititors proposals... ruskent Business 29 03-20-2010 03:08 AM
Commercial proposals 4thGeneration Painting & Finish Work 4 10-22-2007 12:46 AM
Quick books for proposals or agreements? ultimatetouch Business 7 01-09-2007 11:31 PM
Bids, Quotes, Proposals.... TonyD Business 27 09-26-2006 09:44 PM
Do you figure permit fees into your proposals? Melissa General Discussion 13 06-25-2006 01:19 PM
