Priming MDF Edges
Old 09-21-2008, 09:35 AM   #1
mpt1123's Avatar
Priming MDF Edges
Hello:
We're re-building a set of stairs and planning to use MDF for the risers. The stairs are boxed on the sides so the MDF edges won't show. Nonetheless, I want to seal them before priming and painting. I see a lot of mention on the internet about applying a thinned carpenters glue solution to the edging first, followed by a good oil based primer. I'm hesitant to use anything water based around MDF - including a thinned glue solution.
Anyone have any experience with priming MDF, particularly cut edges?
Thanks.
mpt1123 is offline
Old 09-21-2008, 10:10 AM   #2
Tom R's Avatar
Re: Priming MDF Edges
Thinning the glue is fine, - - it makes it more workable and it penetrates further.
In your case, though, - - I don't see it as necessary. Just prime the edges with oil base.
It's even OK to prime with latex, - - but then you have to lightly sand the swelled fibers.
Tom R is offline
Old 09-21-2008, 06:25 PM   #3
mpt1123's Avatar
Thanks, Tom.
mpt1123 is offline
Old 09-21-2008, 06:31 PM   #4
LRG WoodCrafting
Leo G's Avatar
I would never use MDF as a riser on a staircase. Won't take the abuse.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 09-21-2008, 06:54 PM   #5
Full Service Renovations
MAD Renovations's Avatar
I would give this a second thought aswell!!!
MAD Renovations is offline
Old 09-21-2008, 08:08 PM   #6
If you're the last trade out,
it might look good 'til you leave.
neolitic is offline
priming ceilings problem raven2006 Drywall 26 08-09-2010 06:34 AM
self priming exterior paints painterdude Painting & Finish Work 21 12-04-2008 10:11 PM
Priming New construction $ per square foot dwbrooks Painting & Finish Work 20 09-19-2008 03:30 PM
Self Priming Traps? mellison1 Plumbing 13 08-12-2008 11:47 PM
Cutting in curved drywall edges aoc Painting & Finish Work 4 02-20-2006 07:55 AM
