Priming Drwall And Texture
Old 01-11-2006, 11:25 AM   #21
remodelnut's Avatar
Re: Priming Drwall And Texture
I did not backroll right away. I came back after I finished spraying all the rooms and started backrolling. I would say it was about 30 minutes when I tried to back roll the hallway and the other areas.
remodelnut is offline
Old 01-11-2006, 12:33 PM   #22
...jammin
slickshift's Avatar
Trade: Rock Disciple
Originally Posted by remodelnut
Just the 123 was coming off....
container...said to use ammonia and water and not TSP
....I did not backroll right away.... I would say it was about 30 minutes when I tried to back roll the hallway and the other areas.
It's probably the time delay
That would do it, espescially if you add in any of the other things mentioned
Though I've not done the the ammonia/tsp thing myself, I'm sure that's not helping
Back-rolling should be done right away
To the point of have a helper back-roll behind you as you spray
slickshift is offline
Old 01-11-2006, 07:18 PM   #23
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
I never use 123 over wallpaper I have removed. You can reactivate the adhesive with any water based primer. In fact I had to repaint a bathroom from 6 months ago today for that very reason... we used 123 religiously back then.
Now I use BIN for previously wallpapered walls, it's cheaper than gardz and has a 45 minute recote time.
I realize I am a little late to the conversation but I figured it was relevant because no one has mentioned BIN yet...
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 01-11-2006, 10:15 PM   #24
remodelnut's Avatar
Well I went to inspect the damage tonight.
The paint in the hallways looks like it attached pretty well. I tried to scrape off the areas with a wallpaper scraper that were exposed after I tried to back roll and the only way I was able to get the paint off is if I took the sheetrock paper behind it. I guess the paint became too tacky to backroll and that was my problem.
In the bedrooms I did have some problems. In some of the areas were I started to backroll the paint and it started coming off, I had problems with the areas that were skimmed coated. The areas that were just the paint after I removed the wallpaper and cleaned seemed to stick pretty well.
The paint would come off like wallpaper when I scraped it with a wall paper scraper in the areas of skim coating. I did find that Sherwin Williams has something similiar to Gardz that I am going to put on the areas that I scraped off and see if that helps. The layers of paint that came off did feel a little dusty on the back. I guess the areas that have skim coating and did not come off yet, I will have to cross my fingers
I appreciate everybodies input! I really enjoy reading the post on this forum.
Old 01-12-2006, 12:56 AM   #25
Pro Painter
AAPaint's Avatar
Yup, sounds like the roller lifted the paint....the rest is positively from the dust.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 01-12-2006, 08:09 AM   #26
...jammin
slickshift's Avatar
Yup, that did it
