01-09-2006, 10:30 AM
#1
Trade:
Carpentry
Priming Drwall and Texture
I have a house that I am remodeling and have some questions regarding priming.
I have one room that had wood paneling in it that I took down and had to tape and float the sheetrock that was behind it and the other rooms had wallpaper that I removed. I am going to apply a knock down texture to all the walls and was wondering if I should prime first then texture and prime again, or if it is OK to just paint after I apply the texture?
Thanks for the advice.
01-09-2006, 05:48 PM
#2
Pro Painter
Trade:
Painting Contractor
The proper way to do it would be to prime, texture, prime and then paint. Anything less is a shortcut, honestly. I'm doing a job now that is exactly as you mentioned. The walls had panelling which was removed along with a lot of the paper. Another contractor mudded the place including areas where the paper was still lifting. I spent my day today cutting out their patches and priming. Tommorow, skim, sand all the other stuff they did, then re-prime and paint.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
“Knowledge will forever govern ignorance; and a people who mean to be their own governors must arm themselves with the power which knowledge gives.” -James Madison
01-09-2006, 06:22 PM
#3
Trade:
Carpentry
Do you put anything on the skim coat before you prime? I have seen where some people put gardz and then prime. Also, do you tint the prime that you paint over the texture, or just basic white?
I am remodeling a 3,000SF house that had tons of wallpaper and wood paneling throughout, and one bathroom that they had removed the wallpaper along with the sheetrock paper that I am skimming before I paint.
Thanks for the info.
01-09-2006, 07:11 PM
#4
Guest
Trade:
Priming Drywall and texture...
AA Paint is right with the priming, texture, then prime and paint. However your primer should be an oil based primer (para600 ceiling is great for this and is inexpensive) then do your texture then Prime again with an oil based primer for it is ready to receive either latex or oil based paints. If you just prime with a latex primer you risk the glue coming through if any left and also the texture coming off. Remeber Latex primer is water based and if it moistens the textuire the texture will come off.
01-09-2006, 07:17 PM
#5
Pro Painter
Trade:
Painting Contractor
If you're using guardz you don't really have to prime over top of it but you can....because it is a sealer, not necessarily a primer. Priming over top of the guardz may be overkill depending on your situation though.
As far as tinting primers. It really depends on the color I'm doing. Since I always do two topcoats, a tinted primer is not always necessary. If I'm doing something like RED then I'll either use a tinted primer, or if applicable SW's color prime system which is basically grey primers designed to give proper color appearance.
EDIT: Zinsser's website says no need for oil based primers....ready for topcoat after guardz.
-AAPaint
Jacksonville, FL.
01-09-2006, 08:57 PM
#6
Chief Toilet Mover
Trade:
Bathroom Remodeling
Damn! What is with the primer then texture than prime again? Why wouldn't you texture then prime?
01-09-2006, 09:33 PM
#7
Pro Painter
Trade:
Painting Contractor
On both new and previously painted, chipped, peeling, or otherwise compromised surfaces such as this it is always best to prime before texturing. This is another one of those topics that people have argued until the cows come home. Priming seals the surface giving even porosity, ensures a stronger bond, and even drying of the texture. It also ensures that no areas of your texture will fail prematurely. If you've ever seen a texture come off in sheets.......there's either dust or no primer underneath.
-AAPaint
Jacksonville, FL.
01-09-2006, 10:01 PM
#8
...jammin
Trade:
Rock Disciple
Originally Posted by Mike Finley
...What is with the primer then texture than prime again? Why wouldn't you texture then prime?
Originally Posted by AAPaint
... Priming seals the surface giving even porosity, ensures a stronger bond, and even drying of the texture. It also ensures that no areas of your texture will fail prematurely...
Now that's one of those things I don't often see done properly
It might be fine skipping the first prime step
But it will be fine, and will stay fine if you do it right
Keep up the good work Double A!
01-10-2006, 01:45 AM
#9
Chief Toilet Mover
Trade:
Bathroom Remodeling
AA - Maybe I missed something? I thought we were talking texture sprayed to new drywall. Remodelnut said he is going to skim coat the walls first.
Let me just re-ask my question.
If I am doing new drywall and am going to texture and paint it, are you saying to prime the drywall before texturing it? This is where I'm getting confused. I have always textured then primed then painted.
01-10-2006, 09:34 AM
#10
Trade:
Carpentry
Actually I have a combination of many different wall scenerios. I have skim coated areas of walls that the sheet rock paper has come off after removing wallpaper that was previously painted, I have some new drywall, and have some walls that were painted with holes in them that I have mudded over.
I am in the process of priming all of the walls and then texturing. Then evidently I need to prime the walls again and then paint. I am using Zinsser 123 latex primer, but someone stated that I should be using an oil base primer. I am going to regret that?
01-10-2006, 09:55 AM
#11
...jammin
Trade:
Rock Disciple
Originally Posted by remodelnut
...I am using Zinsser 123 latex primer... I am going to regret that?
No
But technically Guardz would be a better Zinsser product for your situation
01-10-2006, 10:35 AM
#12
Trade:
Wood working in spare time.
Slickshift is correct. I seen that stuff when i went to get what he recomended to paint my bathroom with. (bulleyes 123 and perma white) That Guardz if i recall was like a high preformance sealer for problem drywall and i believe when i read the back of the can it did say specially designed to seal so wallpaper residue won't come through. I was thinking about getting it because it look so awesome. But slick said bulleye 123 and perma white so thats what i got and the walls in bathroom LOOK OUTSTANDING.
01-10-2006, 11:36 AM
#13
Trade:
Carpentry
The problem for me is that I have tried to find some Gardz, but no one carries that in my area. I am hoping the Zinsser 123 will do the trick.
01-10-2006, 06:59 PM
#14
Pro Painter
Trade:
Painting Contractor
Yes, most texture manufacturers recommend priming prior to the application of the texture....even on new drywall! I know there is the argument that sheetrock compound is meant to stick tenaciously to drywall, but...it's still better to prime/seal the surface for the reasons I mentioned above. Not only that, but you can guaran-dam-tee that it will be bullet-proof, which is how I like to do things.
remodelnut: You will be just fine with the 1-2-3. It is an equally great primer, just not the best of the best for this particular application.
The job I'm doing now had almost the same deal. One room, panelling ripped down, sheetrock destroyed, paper peeling everywhere. Foyer, 40 year old texture....wants flat walls. My method exactly? One coat of Guardz, 2 skim coats, second coat of guardz then paint. Guardz will seal all that old wallpaper adhesive, fuzzy drywall, patches, etc in one shot.
-AAPaint
Jacksonville, FL.
01-10-2006, 07:01 PM
#15
Chief Toilet Mover
Trade:
Bathroom Remodeling
Thanks AA, now I know!
01-10-2006, 08:05 PM
#16
...jammin
Trade:
Rock Disciple
You should be fine
I used that in my sister's home
Local didn't have it, I was too far from my regular suppliers, it was a freebie job
lol
I had an open can of 123....
It worked fine
It's just that the Guardz is a little better for that type of deal
01-10-2006, 10:54 PM
#17
Trade:
Carpentry
OK boys and girls, Sprayed the 123 in all the rooms tonight and was pretty satisfied except I noticed a few runs so I decided to roll them out. This is where the fun starts.
In the hallway where I did nothing, I started rolling and the paint started coming off in patches  .
In one of the bedrooms where I removed wallpaper. I was rolling out the paint and the paint started coming off where I did not skim coat and only washed with TSP,
Some of the walls did come out all right though so there is a silver lining.
Any clues? I really appreciate the responses.
01-11-2006, 07:47 AM
#18
...jammin
Trade:
Rock Disciple
Rut Roh...
To be clear, there were no repairs in this hall, it was previously painted
It is not textured
You sprayed 123, then back-rolled it
When back-rolling the previous paint came up?
Or just the 123?
Same Q...the 123 was lifting or the old paint/primer/whatever they used before?
There's possibly some contaminate left on the old paint, not sanded enough or dust from sanding was left on the surface
Or the previous paint was too glossy and needs a de-glosser
In the bedroom if it's just the 123 that was lifting, I'd say the walls weren't cleaned/sanded/cleaned enough and some glue residue is/was still there
Unless the prev. paint is glossy, it may need de-glossing
We'll need some more specifics/details
Just to be sure, there's not a chance any of these walls are oil is there?
I doubt it, but because you are having problems we'll want to cover all the bases
01-11-2006, 09:47 AM
#19
Trade:
Carpentry
The hall that I am working on did not have any wallpaper when I started the project. There could have been wallpaper there before, but I saw no evidence of any remaining adhesive.
Just the 123 was coming off.
In the bedroom I can see where it is possible that the adhesive is an issue even though we did clean the walls with TSP. Of course I have always been told to clean the walls with TSP to remove any residue, but I looked at the container and it said to use ammonia and water and not TSP
We washed the walls down with water after cleaning with TSP.
As far as the walls being oil, I don't know. Not sure how to tell.
I will be going to inspect it this evening to see how the paint drys and see what I am going to have to do. I will be looking to see if there is dust on the backside of the paint on the walls in the hall if it is still coming off.
01-11-2006, 11:00 AM
#20
Dripless
Trade:
Painting and exterior wood care
How long between spraying and backrolling? If you don't backroll right away and the paint is starting to tack, you can kinda lift some of it off...just guessing.
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
