Priming After Trim/doors Installed
Old 11-30-2006, 08:45 AM   #1
icfbunt's Avatar
Trade: General bldg contractor
Is there any advantage of waiting until all the trim and doors are installed to prime and paint? All trim and doors are pre primed. I was thinking on waiting until all the drim and doors were up, then caulking,filling nail holes, priming all drywall, painting ceilings, then spray trim doors, then tape trim/remove doors and paint walls. The walls and clg all are the same color. (egshell). Just like to see what others think on this process. I am doing all the trim and paint, so I can do in any order. Seems this way I could set up to paint and do most of it all at once.
The disadvanage to this would be having to paint around the kitchen cabinets, etc
Thks for the input!!
icfbunt is offline
Old 11-30-2006, 10:48 AM   #2
toddcla2002's Avatar
Trade: Paint Contractor
Send a message via AIM to toddcla2002
Re: Priming After Trim/doors Installed
Personally I think anything "pre-primed" or "factory primed" needs a new primer coat. I like to have the trim pack installed using hardware that I can paint over and replace later, caulk it, fill the nail holes and then prime everything (walls, ceiling and trim pack) from there. I don't see a need for the cabinets to be in while you are painting. Then I usually do the ceilings in one coat flat and then brush and roll 2 coats eggshell on the walls. With an 18" roller and some skill this should go faster than you think. Good luck!
~todd
toddcla2002 is offline
Old 11-30-2006, 12:12 PM   #3
LennyV-NHSNOLA's Avatar
Trade: Residential Renovations/Remodeling
If this is new construction or a kitchen remodel, then I would definitely paint first before the cabinets go up. You may still have to do some touch up work after the cabinets are installed and if caulked along the counter tops but that's a lot easier than trying to tape off and paint around NEW cabinets that the customer just paid thousands of dollars for.
On a separate note, did they really want the walls and trim to be all the same color and type of paint? Or is this just a rental property?
LennyV-NHSNOLA is offline
Old 11-30-2006, 12:40 PM   #4
icfbunt's Avatar
Thanks for the reply guys! You are correct, I dont need the cabinets in while I am painting. However, the only way to properly install the trim is to have the cabinets in so I can but the trim to them. Oops,....I didn't mean walls and trim the same color, I meant the walls and clg would be the same color ,....sorry. The trim will be white and the walls/clg will be an off white (I forget the name of the color). Walls and clg will be eggshell. I kept the clg eggshell to keep things simple. This is a spec home, although I may actually be moving in. I have a sprayer (magnum xr7) that I would like to spray the walls and clgs, then backroll. I would like to spray the doors and trim as well. I like the spray look on trim and doors vs brush.
thks!!
icfbunt is offline
Priming New construction $ per square foot dwbrooks Painting & Finish Work 20 09-19-2008 03:30 PM
Installed Sales dvon104 Remodeling 2 07-07-2007 10:49 AM
Vertically installed suspended ceiling Maplehead Remodeling 13 03-29-2007 10:06 PM
Getting a fence installed on Monday!! Luke's Dad Decks & Fencing 4 02-20-2007 06:33 AM
Priming Drwall and Texture remodelnut Painting & Finish Work 25 01-12-2006 08:09 AM
