Trade: painting and pressure cleaning
Primer On Repaints
do you use primer on repaints if the origenal paint is sound?and if origanel is a lighter or simaler color?
Trade: Painting Contractor
Re: Primer On Repaints
allways count on at least two coats, your reputation is on the line. Word of mouth is your best advertisment
painterofeverything
I always prime,even if its a similar color.
#4 | |
...jammin
Trade: Rock Disciple
Nope
Signature Quote Quote:
#5 | |
My custom title
Nope.
Benn Quote:
Thom
nope
nope
#8 | |
Re: Primer On RepaintsQuote:
Trade: Painter, plaster repair
when I prime I only use a roller, you can prime any area like that in no time. When you cut in with the final color the two coats will cover the nonprimed area.
Back from the dead...
Trade: Paperhanger/Painter
Ditto
Trade: PAINTER
Spot prime patches, then 2 coats of paint.
Thanks Dan |
Painting Contractor
If love is blind, why do they make Lingerie? |
Re: Primer On Repaints |
Trade: Painting & Remodeling
No way! 2 coats will do it.
Trade: Painter
Depends on the color, sheen and customer. Oh, and price.
I just bid a new construction with frazee velvin on the walls. I don't trust that paint, but the walls are all knock down. No need to prime. With a sheen the high spots will still contrast with the low spots. If the walls were smooth, I'd prime over it. Good existing paint gets pole sanded. If it's semi-gloss, I would probably prime a respectable paying repaint. |
| Drywall primer peeling problem?? | DeanV | Painting & Finish Work | 23 | 02-02-2008 11:02 AM |
| 2 coats of primer on ceiling rather than paint? | Zeebo | Painting & Finish Work | 20 | 12-25-2006 01:05 PM |
| Tinting primer question | icfbunt | Painting & Finish Work | 5 | 12-12-2006 06:44 PM |
| Primer needed on metal garage door??? | Zeebo | Painting & Finish Work | 11 | 08-19-2006 05:35 PM |
| alkyd primer or not | cowtown | Wallpaper | 8 | 08-11-2006 12:46 AM |
