Primer Needed On Metal Garage Door???
Old 08-17-2006, 07:07 AM   #1
Zeebo's Avatar
Trade: Painter
I will be painting a metal garage door that has been painted in the past. The door was originally bought from the factory and had a baked on enamel finish. The factory paint was white, but the customer painted it green about 8 years ago. He can't remember if he used primer. The paint is not flaking or blistering, it's just dull.
I would usually use a bonding type primer on top of the factory baked enamel followed with 2 coats of exterior semi gloss paint (latex).
However, this door has 2 coats of latex green on top of the enamel. I will be applying 2 coats of the same colour.
I'm not sure if I should be using a primer for this job??? Obviously surface prep is needed - power wash, degrease and sand.
Should I be using a primer??
Also, if you think a primer is required, have you ever used XIM primer?
Thanks
Zeebo
Zeebo is offline
Old 08-17-2006, 09:51 AM   #2
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Re: Primer Needed On Metal Garage Door???
You shouldn't need a primer if the paint is in good shape. Paint tends to hold up real good on those doors unless something was done to compromise that when it was first painted. XIM is a good primer, but I think it would be unnecessary in this case. Now, if you proposed a primer for the door when you bid the job...prime it. Other than that, you should be ok to just recoat it, of course, after cleaning it.
-AAPaint
Jacksonville Painters
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 08-17-2006, 12:24 PM   #3
Zeebo's Avatar
Trade: Painter
Thanks for the info...This is what I thought too...no primer but do a really detailed prep job.
What's your experience with XIM primer?? I have never used it....heard it's runny and dries very quickly. Does it stick to anything...as it says it does??
Zeebo
Zeebo is offline
Old 08-17-2006, 02:28 PM   #4
Pro Painter
AAPaint's Avatar
XIM is an awesome primer really. I use it on stuff where I'm worried about adhesion like cheap laminated cabinets, etc. It's a bit like using BIN as far as runny goes, but not as bad.
-AAPaint
Jacksonville, FL.
-James Madison
AAPaint is offline
Old 08-17-2006, 04:18 PM   #5
Zeebo's Avatar
Trade: Painter
thanks...I use BIN and the Zinnser products...like them...but I also hear that XIM is that one step up for better adhension on tricky surfaces...I need to pick up a quart and try it out.
Zeebo
Zeebo is offline
Old 08-17-2006, 11:55 PM   #6
Painting Contractor
Humble Abode's Avatar
Send a message via AIM to Humble Abode
The XIM UMA product is really nice. The nice thing about it is it's a bonding primer that can be used in low temp and top coated with anything...
I never had a problem with it being runny, it's a little thinner than Bullseye...
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 08-19-2006, 09:42 AM   #7
paintr56's Avatar
Trade: paint contractor since 1974
Have you ever used Gripper from ICI? It is a latex product that isn't runny. Works real well on a lot of surfaces. Much nicer to work with then traditional xim.
Jim Bunton
paintr56 is offline
Old 08-19-2006, 10:11 AM   #8
Painting Contractor
Jim Bunton
Never used it. Is ICI the company that makes Behr or the company that makes Drylock?
The NAPP
Old 08-19-2006, 10:47 AM   #9
My custom title
Brushslingers's Avatar
Never heard of ICI? You know them - Devoe, Glidden... They just closed the ICI store here but, hit www.icipaints.com
Benn
Originally Posted by Brian
Brushslingers is offline
Old 08-19-2006, 02:26 PM   #10
Zeebo's Avatar
Trade: Painter
Jim Bunton
Hi Jim. I have used this product here in Mississauga, Ontario Canada (which is where I am located). It's a fast drying 100% Acrylic primer. I do like it and it tends to be less cost for me vs. BIN 123. However, I would use BIN 123 over Gripper any day, especially for outside work.
However, I prefer to use a better "Bonding" type primer with metal....and I here that XIM is the way to go.
Zeebo
Zeebo is offline
Old 08-19-2006, 02:33 PM   #11
Zeebo's Avatar
Trade: Painter
ICI does not make Behr. ICI group is know internationally and make the following paints: ICI Dulux, CIL, Weather guard, Glidden Paints, Colour Your World, Smart Paint (sold in Home Depot) and Devoe Coatings. There are over 450 stores in North America.
Zeebo
Zeebo is offline
Old 08-19-2006, 05:35 PM   #12
Class A Contractor "BLD"
Gordo's Avatar
Trade: Remodeling and home improvements
Jim Bunton
Aqua Gripper. They sell it at Home Depot. It is a water clean up primer. Make sure to clean your brush regularly because it dries fast.
Been using it for years. A great product.
Looks like some pros were here.
Gordo is offline
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
Garage Door Opener Screwed Up Woz the Painter General Discussion 8 04-19-2006 07:48 AM
Door hanging Nick H Carpentry 4 02-27-2006 02:22 AM
Garage door help shingler Construction 7 02-15-2006 08:44 PM
